Error compiling for board Arduino MKR WAN 1300- Display wireless data to OLED
Hello everyone,
I am having a bit of trouble writing the code to display data received through the MKR Wan 1300 (915MHz).
I have two MKRs which both talk wirelessly in the serial port but I would like to have one collect data and the other display that data (temp and humidity). When I try to verify the code below I am prompted with an error of "Error compiling for board Arduino MKR WAN 1300" Exit Status 1. Maybe it is a space issue? when I change the board type to Arduino nano or uno it compiles just fine.
I have borrowed this code from Eric on GitHub at GitHub - MKme/lora: Simple LORA communications code for Arduino after watching many videos on youtube and trying to write the code myself to no avail.
I know the OLEDs work and are hooked up correctly as I started out using them to just display their own data to verify I had the connections correct.
My original problem was that I could get the two devices to talk with each other wirelessly through the serial port but could not display it on an OLED. (I don't think I was trying the right method by just saying display.print((char)(LoRa.read()) so I tried the new versions from Erik.)
Any help would be greatly appreciated.
Github Code Giving Compiling Error:
 * Moved to PUBLIC GIT Feb 2020 YAY!!!! finally
 * OLED draws 10 mA when in use
 * Button pins are A=9 (same as batt pin ugh) B=6, C=5
 * I2C add=0x3C
 * Compare string values https://www.arduino.cc/en/Tutorial/StringComparisonOperators
 * Antenna 915 MHz - 3 inches or 7.8 cm
 * Feather Pinouts: https://learn.adafruit.com/adafruit-feather-32u4-radio-with-rfm69hcw-module/pinouts
 * Power Management: https://learn.adafruit.com/adafruit-feather-32u4-radio-with-rfm69hcw-module/power-management
 * V1.0
 * Renamed to version IDs as is first functional build with radios communicating
 * Beginning to add I/O functionality from here
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_FeatherOLED.h>
#include <SPI.h>
#include <RH_RF95.h>
//Toggle this to determine master or slave code to be used-------------------------------------
int mode = 0;  // Mode 0 is TX code   Mode 1 is RX code
String msg; // Eric added this to globalize the message from buffer received
int signalreceived; //Globalized to define rssi gone when not received
int count = 0;// debugging counter
Adafruit_FeatherOLED oled = Adafruit_FeatherOLED();
#define VBATPIN A1
/* for feather32u4 */
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
#define LED 13
#define RF95_FREQ 915.0 // Define LORA board freq
RH_RF95 rf95(RFM95_CS, RFM95_INT); //radio driver
  delay(1000);  //This MUST be here and increased to 1000 from 100, or OLED wont init- no fricken clue why
  oled.init();
  oled.setBatteryVisible(true);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
int16_t packetnum = 0;  // packet counter, we increment per xmission
dooledstuff(); //read battery level and do OLED update
  if (mode == 0) {
     doradiotx(); //Run TX MASTER code
      // Edited out for testing doradiorx(); //Run RX SLAVE Code
float getBatteryVoltage() {
  float measuredvbat = analogRead(VBATPIN);
  measuredvbat *= 2;    // we divided by 2, so multiply back
  measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
  measuredvbat /= 1024; // convert to voltage
  return measuredvbat;
void dooledstuff()
  oled.clearDisplay(); // clear the current count
  float battery = getBatteryVoltage();
   // update the battery icon
  oled.setBattery(battery);
  oled.renderBattery();
  oled.print("C: "); //print out to OLED
  oled.println(count);
  oled.print("RSSI: ");
     if (signalreceived >0) //This is toggled on a valid packet receive
      oled.println(rf95.lastRssi(), DEC);
     oled.println ("0");
  oled.println (msg); //will dislay received msg OR defined error text below
  //oled.println("---");
  oled.display(); //update oled screen
  count++; //debugging counter only
//_______________________________MASTER_____________________________________
void doradiotx() //TX Module code here
  Serial.println("Sending to rf95_server");
  char radiopacket[20] = "TX Online"; //Send the text string I'm here!
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  radiopacket[19] = 0;
  Serial.println("Sending..."); delay(10);
  rf95.send((uint8_t *)radiopacket, 20);
  Serial.println("Waiting for packet to complete..."); delay(10);
  rf95.waitPacketSent();
    // wait for a reply from another radio
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply..."); delay(10);
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))
      Serial.print("Got reply: ");
      msg = ((char*)buf); //sore the message into msg string for OLED use
      Serial.println (msg);
      //Erics code to check message received to see if it is an alarm- if so- trigger alarm=1
      //Move this code in to receiver module to trigger flash/buzzer
        if (msg == "RX Online")
            Serial.println ("Alarm Text Detected!");
            digitalWrite(LED, HIGH);
      //--------------------------End maching code
      signalreceived =1; //set flag so OLED code can display that connection is alive
      Serial.println (signalreceived); //debugging only
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
      Serial.println("Receive failed");
      msg = "ReceiveFail"; //set message to display properly on oled for status
      signalreceived = 0; //set flag so OLED can show connection is bad
      digitalWrite(LED, LOW);
    Serial.println("No reply. Slave node is not online........");
    msg = "No Connection"; //to display connection is dead on oled
    signalreceived = 0; //set flag so OLED can show connection is dead
I had to edit the actual code due to character limits. The rest of the code was used for the "slave" portion and can be found on the GitHub link provided above. Thanks again for any help you can provide!
