Error compiling for board Arduino Nano.pls help!
Hello I was trying to upload my remote control car controller sketch and it said I had a issue "compiling" it.
here is the code:
`[code]
#include <SPI.h>
#include <RHReliableDatagram.h>
#include <RH_NRF24.h>
#include <Servo.h>
// Define the Joystick Connections
int joyY(0);
int joyX(1);
int joyposY = 512; //to use with the actual joystick
int joyposX = 512;
int valY;
int valX;
// Define addresses for radio channels
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
// Create an instance of the radio driver
RH_NRF24 RadioDriver;
// Sets the radio driver to NRF24 and the client address to 1
RHReliableDatagram RadioManager(RadioDriver, CLIENT_ADDRESS);
// Define the Message Buffer
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
Servo myservo1;
Servo myservo2;
void setup(){
// Setup Serial Monitor
// Initialize RadioManager with defaults - 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!RadioManager.init())
Serial.println("init failed");
myservo1.attach(3);
myservo2.attach(4);
void loop(){
if (valX < 460) // turn left
valY = analogRead(joyY);
valY = map(valY, 0, 1023, 0, 180);
valX = analogRead(joyX);
valX = map(valX, 0, 1023, 0, 90);
myservo1.write(valY-2valX); // servo 1 slows
myservo2.write(180-valY);
delay(15);
else if (valX > 564) // turn right
myservo1.write(valY);
myservo2.write((180-valY)-2
valX); // servo 2 slows
delay(15);
[/code]`
and here are the error messages:
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware -hardware /Users/jethrocrooke/Library/Arduino15/packages -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/jethrocrooke/Library/Arduino15/packages -built-in-libraries /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries -libraries /Users/jethrocrooke/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483 -warnings=none -build-cache /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_cache_683517 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware -hardware /Users/jethrocrooke/Library/Arduino15/packages -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/jethrocrooke/Library/Arduino15/packages -built-in-libraries /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries -libraries /Users/jethrocrooke/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483 -warnings=none -build-cache /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_cache_683517 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino
Using board 'nano' from platform in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for RHReliableDatagram.h: [RadioHead@1.112]
ResolveLibrary(RHReliableDatagram.h)
-> candidates: [RadioHead@1.112]
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Servo.h: [Servo@1.1.6]
ResolveLibrary(Servo.h)
-> candidates: [Servo@1.1.6]
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHCRC.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHDatagram.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHEncryptedDriver.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHGenericDriver.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHGenericSPI.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSP12.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSP1I.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSPI.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHMesh.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHNRFSPIDriver.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHReliableDatagram.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHRouter.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHSPIDriver.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHSoftwareSPI.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_ABZ.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_ASK.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_CC110.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_E32.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_MRF89.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF24.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF51.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF905.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF22.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF24.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF69.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF95.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_Serial.cpp
Using cached library dependencies for file: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_TCP.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/avr/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/mbed/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/megaavr/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/nrf52/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/sam/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/samd/Servo.cpp
Using cached library dependencies for file: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src/stm32f4/Servo.cpp
Generating function prototypes...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo/src /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/SPI/SPI.cpp.o
Compiling library "RadioHead"
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHGenericDriver.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHDatagram.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHCRC.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHGenericSPI.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHEncryptedDriver.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSP1I.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSP12.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHNRFSPIDriver.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHMesh.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSPI.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHReliableDatagram.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_ABZ.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHSoftwareSPI.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHRouter.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHSPIDriver.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_ASK.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_E32.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_CC110.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_MRF89.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF24.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF22.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF51.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF24.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_Serial.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF95.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF69.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_TCP.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF905.cpp.o
Compiling library "Servo"
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/avr/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/mbed/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/megaavr/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/nrf52/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/sam/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/samd/Servo.cpp.o
Using previously compiled file: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/stm32f4/Servo.cpp.o
Compiling core...
Using precompiled core: /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_cache_683517/core/core_arduino_avr_nano_cpu_atmega328_d55431a42aeaa2fd0b80d8a99ec43d17.a
Linking everything together...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/rc_car_controller.ino.elf /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/SPI/SPI.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHCRC.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHDatagram.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHEncryptedDriver.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHGenericDriver.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHGenericSPI.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSP12.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSP1I.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHHardwareSPI.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHMesh.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHNRFSPIDriver.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHReliableDatagram.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHRouter.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHSPIDriver.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RHSoftwareSPI.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_ABZ.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_ASK.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_CC110.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_E32.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_MRF89.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF24.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF51.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_NRF905.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF22.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF24.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF69.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_RF95.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_Serial.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_TCP.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/avr/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/mbed/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/megaavr/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/nrf52/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/sam/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/samd/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/stm32f4/Servo.cpp.o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/../arduino_cache_683517/core/core_arduino_avr_nano_cpu_atmega328_d55431a42aeaa2fd0b80d8a99ec43d17.a -L/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483 -lm
/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/Servo/avr/Servo.cpp.o (symbol from plugin): In function ServoCount': (.text+0x0): multiple definition of __vector_11'
/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/libraries/RadioHead/RH_ASK.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Using library RadioHead at version 1.112 in folder: /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead
Using library Servo at version 1.1.6 in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries/Servo
exit status 1
I have tried almost every thing and nothing has worked.
Thank you
-Jethro Crooke
You've got two libraries trying to use the same interrupt vector.
Try eliminating the Servo references and see if it compiles .
Please remember to use code tags when posting code
by servo references do you mean words in the servo.h library
I mean anything that refers to a Servo object.
I tried that and it worked but I need to use the servo library for the project
do you know any ways that I could get around this error
Yes, use a different Servo library, like ServoTimer2
If you'd told us you'd already tried that, we could have saved a ton of time
ok ill try that thank you!
I tried and it has the same result
I can't see your code
sorry wrong code
This is too much like hard work.
Post code, not pictures.
Post error messages, not pictures.
Why isn't such a simple concept obvious?
#include <SPI.h>
#include "ServoTimer2.h"
int joyY(0);
int joyX(1);
int joyposX = 512;
int valY;
int valX;
Servo myservo1;
Servo myservo2;
void setup(){
myservo1.attach(3);
myservo2.attach(4);
void loop(){
delay(15);
myservo2.write((180-valY)-2valX); // servo 2 slows
delay(15);
And the error messages?
#include <ServoTimer2.h>
#include <SPI.h>
int joyY(0);
int joyX(1);
int joyposX = 512;
int valY;
int valX;
Servo myservo1;
Servo myservo2;
void setup(){
myservo1.attach(3);
myservo2.attach(4);
void loop(){
delay(15);
delay(15);
Where are the error messages?
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware -hardware /Users/jethrocrooke/Library/Arduino15/packages -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/jethrocrooke/Library/Arduino15/packages -built-in-libraries /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries -libraries /Users/jethrocrooke/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483 -warnings=none -build-cache /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_cache_683517 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware -hardware /Users/jethrocrooke/Library/Arduino15/packages -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/jethrocrooke/Library/Arduino15/packages -built-in-libraries /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/libraries -libraries /Users/jethrocrooke/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483 -warnings=none -build-cache /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_cache_683517 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino
Alternatives for ServoTimer2.h: [ServoTimer2-master]
ResolveLibrary(ServoTimer2.h)
  -> candidates: [ServoTimer2-master]
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master/ServoTimer2.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHCRC.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHDatagram.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHEncryptedDriver.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHGenericDriver.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHGenericSPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSP12.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSP1I.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHHardwareSPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHMesh.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHNRFSPIDriver.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHReliableDatagram.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHRouter.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHSPIDriver.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RHSoftwareSPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_ABZ.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_ASK.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_CC110.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_E32.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_MRF89.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF24.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF51.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_NRF905.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF22.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF24.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF69.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_RF95.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_Serial.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /Users/jethrocrooke/Documents/Arduino/libraries/RadioHead/RH_TCP.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src -I/Users/jethrocrooke/Documents/Arduino/libraries/RadioHead /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp.o
rc_car_controller:34:1: error: 'Servo' does not name a type; did you mean 'servo_t'?
 Servo myservo1;
 servo_t
rc_car_controller:35:1: error: 'Servo' does not name a type; did you mean 'servo_t'?
 Servo myservo2;
 servo_t
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino: In function 'void setup()':
rc_car_controller:48:3: error: 'myservo1' was not declared in this scope
   myservo1.attach(3);
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:48:3: note: suggested alternative: 'servo_t'
   myservo1.attach(3);
   servo_t
rc_car_controller:49:3: error: 'myservo2' was not declared in this scope
   myservo2.attach(4);
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:49:3: note: suggested alternative: 'servo_t'
   myservo2.attach(4);
   servo_t
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino: In function 'void loop()':
rc_car_controller:63:5: error: 'myservo1' was not declared in this scope
     myservo1.write(valY - 2valX); // servo 1 slows
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:63:5: note: suggested alternative: 'servo_t'
     servo_t
rc_car_controller:63:27: error: unable to find numeric literal operator 'operator""valX'
sorry that wasn't all of it
Using board 'nano' from platform in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/private/var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/AppTranslocation/FFAFD87A-2460-4F60-8E5E-7E40BE99F24C/d/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/vf/w4486g250475d1rc2rhdfst80000gq/T/arduino_build_521483/sketch/rc_car_controller.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
Alternatives for RHReliableDatagram.h: [RadioHead@1.112]
ResolveLibrary(RHReliableDatagram.h)
  -> candidates: [RadioHead@1.112]
Compiling sketch...
 Servo myservo1;
 servo_t
 Servo myservo2;
 servo_t
   myservo1.attach(3);
   myservo1.attach(3);
   servo_t
   myservo2.attach(4);
   myservo2.attach(4);
   servo_t
     servo_t
rc_car_controller:64:5: error: 'myservo2' was not declared in this scope
     myservo2.write(180 - valY);
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:64:5: note: suggested alternative: 'servo_t'
     servo_t
rc_car_controller:73:5: error: 'myservo1' was not declared in this scope
     myservo1.write(valY);
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:73:5: note: suggested alternative: 'servo_t'
     servo_t
rc_car_controller:74:5: error: 'myservo2' was not declared in this scope
     myservo2.write((180 - valY) - 2valX); // servo 2 slows
/Users/jethrocrooke/Documents/Arduino/rc car/rc_car_controller/rc_car_controller.ino:74:5: note: suggested alternative: 'servo_t'
     servo_t
rc_car_controller:74:35: error: unable to find numeric literal operator 'operator""valX'
Using library ServoTimer2-master in folder: /Users/jethrocrooke/Documents/Arduino/libraries/ServoTimer2-master (legacy)
exit status 1
