error compiling for board arduino nao
Error:
Arduino: 1.8.6 Hourly Build 2018/06/18 03:33 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:18:0,
from C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkSerial.h:18,
from C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/BlynkSimpleStream.h:18,
from C:\Users\Aaghav\Documents\Arduino\ir_switch\ir_switch.ino:10:
C:\Users\Aaghav\Documents\Arduino\ir_switch\ir_switch.ino: In function 'void setup()':
C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:152:5: error: expected initializer before 'void'
void BlynkWidgetWrite ## pin (BlynkReq BLYNK_UNUSED &request, const BlynkParam BLYNK_UNUSED &param)
C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:160:31: note: in expansion of macro 'BLYNK_WRITE_2'
#define BLYNK_WRITE(pin) BLYNK_WRITE_2(pin)
C:\Users\Aaghav\Documents\Arduino\ir_switch\ir_switch.ino:44:3: note: in expansion of macro 'BLYNK_WRITE'
BLYNK_WRITE(state2)
C:\Users\Aaghav\Documents\Arduino\ir_switch\ir_switch.ino: In function 'void loop()':
C:\Users\Aaghav\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:152:5: error: expected ';' before 'void'
C:\Users\Aaghav\Documents\Arduino\ir_switch\ir_switch.ino:94:7: note: in expansion of macro 'BLYNK_WRITE'
BLYNK_WRITE(state3);
exit status 1
Error compiling for board Arduino/Genuino Uno.
Code:
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT DebugSerial
// You could use a spare Hardware Serial on boards that have it (like Mega)
#include <SoftwareSerial.h>
SoftwareSerial DebugSerial(2, 3); // RX, TX
#include <BlynkSimpleStream.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "71221bb38c82462891a2c30a4d805d69";
int ir1=A0;//defining all the pins
int ir2=A1;
int ir3=A2;
int ir4=A3;
int state1=LOW;
int state2=LOW;
int state3=LOW;
int state4=LOW;
Blynk.run();
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(13, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(13, LOW);
BLYNK_WRITE(state1)
BLYNK_WRITE(state2)
BLYNK_WRITE(state3)
BLYNK_WRITE(state4)
// Debug console
DebugSerial.begin(9600);
// Blynk will work through Serial
// Do not read or write this serial manually in your sketch
Blynk.begin(Serial, auth);
if (digitalRead(ir1)==LOW) {
if (state1==LOW) {
state1=HIGH;
BLYNK_WRITE(state1);
digitalWrite(8,HIGH); //turns high
else {
state1=LOW;
digitalWrite(8,LOW);
if (digitalRead(ir2)==LOW) {
if (state2==LOW) {
state2=HIGH;
BLYNK_WRITE(state2);
digitalWrite(9,HIGH); //turns high
else {
state2=LOW;
digitalWrite(9,LOW);
if (digitalRead(ir3)==LOW) {
if (state3==LOW) {
state3=HIGH
digitalWrite(10,HIGH); //turns high
else {
state3=LOW;
digitalWrite(10,LOW);
if (digitalRead(ir4)==LOW) {
if (state4==LOW) {
state4=HIGH;
BLYNK_WRITE(state4);
digitalWrite(11,HIGH); //turns high
else {
state4=LOW;
digitalWrite(11,LOW);
digitalWrite(13,HIGH);
You're missing semicolons.
Missing semi colons in the void setup section
