Can someone please help me with this code , I'm new to Arduino , trying to program Pro Mini to send an audio Output when object detected by any of the three ultrasonic sensors. Please help me to update thi code.
#define trigPin3 8 // These lines assign names to values
#define echoPin3 7 // so they can be easily identified.
#define trigPin2 6 // These lines assign names to values
#define echoPin2 5 // so they can be easily identified.
#define trigPin1 4 // These lines assign names to values
#define echoPin1 3 // so they can be easily identified.
#define buzzer 12 // These are set before the code
#include "SD.h"
#define SD_ChipSelectPin 10
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
/* This section of code below runs only one time.
It enables the serial monitor to see output and
sets the pins to input or output.
tmrpcm.speakerPin = 9;
if (!SD.begin(SD_ChipSelectPin))
Serial.println("SD fail");
return;
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(trigPin2, OUTPUT);
pinMode(trigPin3, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(echoPin2, INPUT);
pinMode(echoPin3, INPUT);
pinMode(buzzer, OUTPUT);
/* The remaining part of the code runs in a constant loop.
It triggers the ultrasonic sensor and calculates the
time it took for the sound waves to return. It converts
the time in milliseconds into distance in centimeters.
void sonar1() {
long duration, distance;
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin1, HIGH);
distance = (duration / 2) / 29.1;
Serial.print(distance);
Serial.println(" cm");
// This part of the code below determines whether to
// beep depending on the distance detected. If the object
// is within 62 start the beeps.
if (distance > 30 and distance < 100) {
tmrpcm.setVolume(6);
tmrpcm.play("test.wav");
if (distance > 0 and distance < 31) {
else {
delay (500);
void sonar2() {
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration = pulseIn(echoPin2, HIGH);
else {
delay (500);
void Sonar3() {
digitalWrite(trigPin3, LOW);
digitalWrite(trigPin3, HIGH);
duration = pulseIn(echoPin3, HIGH);
else {
delay (500);
