Error compiling for board Arduino UNO o Uno
The error "Error compiling for board Arduino Uno." came when I compile the code, need help please:
#include "esp_camera.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Select camera model
//  #define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
byte x,y;
uint8_t oldpixel, newpixel;
int quanterror,i;
#define OLED_MOSI  13
#define OLED_CLK   15
#define OLED_DC    14
#define OLED_RESET 2
#define OLED_CS    12
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH,SCREEN_HEIGHT, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
// the setup function runs once when you press reset or power the board
 //  display.begin(SSD1306_SWITCHCAPVCC);
 display.clearDisplay();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_GRAYSCALE; //PIXFORMAT_JPEG;
  config.frame_size =  FRAMESIZE_QQVGA2; // 128x160
  config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  //initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);//flip it back
    s->set_brightness(s, 1);//up the blightness just a bit
 // capture camera frame
camera_fb_t *fb = esp_camera_fb_get();
i=0;
for (y=0;y<SCREEN_HEIGHT;y++)
  for(x=0;x<SCREEN_WIDTH;x++)
    oldpixel= fb->buf[i]; // keep original greyscale value
    newpixel = (255 * (oldpixel >> 7));  // threshold of 128
    fb->buf[i] = newpixel;  // cam buffer now mono, either 0 or 255
    // floyd-steignburg dithering:
    quanterror = oldpixel - newpixel; // error difference between pixels
    // distribute this error to neighbouring pixels:
   //right
      if (x < SCREEN_WIDTH-1) // bounds checking...
        fb->buf[(x+1) +(y*SCREEN_WIDTH)] +=  ((quanterror * 7)>>4);
      //leftdown
      if ((x > 1) && (y < SCREEN_HEIGHT-1)) // bounds checking...
        fb->buf[(x-1) +((y+1)*SCREEN_WIDTH)] += ((quanterror * 3)>>4);
      //down
      if (y < 63) // bounds checking...
         fb->buf[(x) + ((y + 1) * SCREEN_WIDTH)] += ((quanterror * 5) >> 4);
      //rightdown
      if ((x < SCREEN_WIDTH-1) && (y < SCREEN_HEIGHT-1)) // bounds checking...
         fb->buf[(x + 1) + ((y + 1) * SCREEN_WIDTH)] += (quanterror >> 4);
    // draw this pixel
    display.drawPixel( x,y,  fb->buf[i]%2);
    i++;
display.display();
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
In file included from E:\ENGINEERING\DIY\ESP32 CAM\ESP32 CAM OLED\ESP32-CAM_OLED-A\ESP32-CAM_OLED-A.ino:6:0:
C:\Program Files (x86)\Arduino\libraries\esp32-camera-master/esp_camera.h:68:10: fatal error: esp_err.h: No such file or directory
 #include "esp_err.h"
compilation terminated.
exit status 1
option enabled in File -> Preferences.
do you realize the Arduino and ESP32 are different types of boards.
if the ESP32 tools are installed, ESP32 Arduino Board should be one of the choices under Tools->Board:
Thank you.
You got it.
There is another error: 'FRAMESIZE_QQVGA2' was not declared in this scope
Arduino: 1.8.13 (Windows 7), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_may06b\sketch_may06b.ino: In function 'void setup()':
sketch_may06b:61:24: error: 'FRAMESIZE_QQVGA2' was not declared in this scope
Multiple libraries were found for "Adafruit_SSD1306.h"
 Used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Adafruit_SSD1306
 Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Adafruit_SSD1306-master
exit status 1
That was probably supposed to be defined in one of the libraries you are using. I found it in "sensor.h" in the ESP32 Camera library. Try adding "#include <sensor.h>" before including esp_camera.h.
Looks like you have two copies of a library. You should probably get rid of one.
Thanks.
I'll test it.
I tested quite few of Libs, all failed.
I removed that line, the code compiling passed and uploaded and the OLED shown some thing, some thing means can't see any thing except noise, which parameter effect?
