Error Compiling for board Arduino Uno [SOLVED]
Hello all,
I've been working on code that controls a "skydiving" aircraft, but when I compile it says, Error compiling for board Arduino Uno. The code seems fine and I can upload other sketches, and I think I removed all the bugs. Any ideas on what is happening?
Thanks so much!
P.S Am I using this forum correctly? I'm a bit new here.
//Tuning Variables, PID gains for pitch and yaw, timing, etc.
int PpG = 0;
int IpG = 0;
int DpG = 0;
int PyG = 0;
int IyG = 0;
int DyG = 0;
int IntegralCutoff = 10;
int timeDelayAscent = 6;
int timeDelayBellyflop = 10;
int frequency = 50;
int PitchGoal = 0;
int YawGoal = 0;
//Libraries
#include <Arduino.h>
#include <TinyMPU6050.h>
#include <Wire.h>
#include <Servo.h>
MPU6050 mpu (Wire);
Servo front;
Servo back;
//Other variables
long timer = 0;
int Pitch;
int Yaw;
int LEDpin = 4;
int AccX;
int AccY;
int AccZ;
  mpu.Calibrate();
  pinMode(LEDpin, OUTPUT);
  front.write(90);
  back.write(90);
//PHASES OF FLIGHT
void preLaunch();
void ascentPhase();
void bellyflopPhase();
void landingPhase();
void sensorData () {
  mpu.Execute();
  AccX = int(mpu.GetAccX());
  AccY = int(mpu.GetAccY());
  AccZ = int(mpu.GetAccZ());
  Pitch = int(mpu.GetAngX());
  Yaw = int(mpu.GetGyroZ());
void landingPhase () {
  for (;;) {
    digitalWrite(LEDpin, HIGH);
    delay(2000);
    digitalWrite(LEDpin, LOW);
    delay(2000);
void bellyflopPhase () {
  int k = 0;
  int l = 0;
  int PitchErrorIntegral = 0;
  int YawErrorIntegral = 0;
  int PitchError = 0;
  int YawError = 0;
  while (k < (timeDelayBellyflop * (1000 / frequency))) {
    k++;
    int PrevPitchError = PitchError;
    int PrevYawError = YawError;
    sensorData();
    int PitchError = Pitch - PitchGoal;
    int YawError = Yaw - YawGoal;
    if (abs(PitchErrorIntegral) < IntegralCutoff) {
      int PitchErrorIntegral = PitchErrorIntegral + PitchError;
    if (abs(YawErrorIntegral) < IntegralCutoff) {
      int YawErrorIntegral = YawErrorIntegral + YawError;
    int PitchErrorDerivative = PitchError - PrevPitchError;
    int YawErrorDerivative = YawError - PrevYawError;
    back.write(cos((PitchError * PpG) + (PitchErrorIntegral * IpG) + (PitchErrorDerivative * DpG)) * (180 / 3.14159));
    front.write((YawError * PyG) + (YawErrorIntegral * IyG) + (YawErrorDerivative * DpG));
    delay (frequency);
void ascentPhase() {
  int j = 0;
  while (j < (timeDelayAscent * (1000 / frequency))) {
    delay(frequency);
    front.write(90);
    back.write(170);
void preLauch () {
  int i = 0;
  front.write(90);
  back.write(170); //all the way deployeed
  while (i < 20) {
    i = i + 1;
    sensorData();
    delay(200);
    delay(800);
  while ((abs(AccY) < 1.5) or (abs(AccZ) < 1.5) or (abs(AccX) < 1.5)) {
    delay(200);
    delay(200);
Please upload the full error message
I can't post the entire error message. When I try to copy it over, the forum doesn't allow me to send it as it has more than 9000 characters. What information are you looking for?
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link that will allow you to make the attachment.
Its more usual to put your #include statements at the top of the file.
-jim lee
akevkev:
If you have that many errors, then you are probably missing a library file. (Or using the wrong library). Post the first and last 20-lines of the error messages.`
You don't have a 'loop()' function. After I added an empty one at the end, the sketch compiled without error. The only warning is that the 'bellpFlopPhase()' function declares the unused variable 'l'.
Thanks johnwasser! I added a loop and it worked! To everyone else, thanks for the advice!
