i have a problem with my code Error compiling for board Arduino Uno. keep coming up and i installed the Adafruit SSD1306 i don't know what to do im also using the audino R3 my code is
// ultramegabombasticfuze on https://projecthub.arduino.cc/
// Screen: VCC-5V GND-GND SCL-A5 SDA-A4
//Button: 1pin-GND (with a resistor 10KO) 2pin-5V 3pin-D7 4pin-empty
#include <Adafruit_SSD1306.h>
#define BUTTON_PIN 7 // Pin connected to the button
bool isJumping = false;
int dinoY = 40;
int velocity = 0;
const int gravity = 2;
const int groundY = 40;
int cactusX = 128;
Adafruit_SSD1306 display(128, 64, &Wire, -1);
pinMode(BUTTON_PIN, INPUT); // Set BUTTON_PIN as input
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
while (1); // If the display is not initialized, stop the program
display.clearDisplay();
static bool buttonPressed = false;
// Button is pressed when the signal is HIGH (due to direct connection to 5V)
if (digitalRead(BUTTON_PIN) == HIGH && !buttonPressed) {
buttonPressed = true;
isJumping = true;
velocity = -10; // Jump power
delay(50); // Debounce delay to avoid multiple presses
if (digitalRead(BUTTON_PIN) == LOW) {
buttonPressed = false; // Reset when button is released
// Handle jumping physics
if (isJumping) {
dinoY += velocity;
velocity += gravity;
if (dinoY >= groundY) {
dinoY = groundY;
isJumping = false;
// Move cactus
cactusX -= 3;
if (cactusX < -10) cactusX = 128;
// Draw scene
display.fillRect(10, dinoY, 10, 10, SSD1306_WHITE); // Dino
display.fillRect(cactusX, groundY, 10, 15, SSD1306_WHITE); // Cactus
display.drawLine(0, 58, 128, 58, SSD1306_WHITE); // Ground
display.display();
// Collision detection
if (cactusX < 20 && cactusX > 5 && dinoY == groundY) { // Check if the dino is on the ground and cactus is near
display.setTextSize(2);
display.setTextColor(SSD1306_WHITE);
display.setCursor(20, 20);
display.print("Game Over");
display.display();
while (1); // Stop the game after Game Over
delay(50); // Delay for smooth gameplay
