Hi, I am trying to make a project where I can use and IR remote to make lights turn on, so I got an Arduino and started looking up tutorials. I found one and downloaded its library and wired the IR receiver according to the code but when I tried to compile it, it said "Error Compiling for board Arduino Uno" and just to let you know, I had another problem with #include <IRremote.h> with the Arduino coder saying unknown directory. I fixed this by changing it to #include "C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0/IRremote.h". IR receiver is a VS1838B. Thank you in advance.
Code:
* IRrecord: record and play back IR signals as a minimal
* An IR detector/demodulator must be connected to the input RECV_PIN.
* An IR LED must be connected to the output PWM pin 3.
* A button must be connected to the input BUTTON_PIN; this is the
* send button.
* A visible LED can be connected to STATUS_PIN to provide status.
* The logic is:
* If the button is pressed, send the IR code.
* If an IR code is received, record it.
* Version 0.11 September, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
int RECV_PIN = 11;
int BUTTON_PIN = 12;
int STATUS_PIN = 13;
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
irrecv.enableIRIn(); // Start the receiver
pinMode(BUTTON_PIN, INPUT);
pinMode(STATUS_PIN, OUTPUT);
// Storage for the recorded code
int codeType = -1; // The type of code
unsigned long codeValue; // The code value if not raw
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
int toggle = 0; // The RC5/6 toggle state
// Stores the code for later playback
// Most of this code is just logging
void storeCode(decode_results *results) {
codeType = results->decode_type;
int count = results->rawlen;
if (codeType == UNKNOWN) {
Serial.println("Received unknown code, saving as raw");
codeLen = results->rawlen - 1;
// To store raw codes:
// Drop first value (gap)
// Convert from ticks to microseconds
// Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
for (int i = 1; i <= codeLen; i++) {
if (i % 2) {
// Mark
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK - MARK_EXCESS;
Serial.print(" m");
else {
// Space
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK + MARK_EXCESS;
Serial.print(" s");
Serial.print(rawCodes[i - 1], DEC);
Serial.println("");
else {
if (codeType == NEC) {
Serial.print("Received NEC: ");
if (results->value == REPEAT) {
// Don't record a NEC repeat value as that's useless.
Serial.println("repeat; ignoring.");
return;
else if (codeType == SONY) {
Serial.print("Received SONY: ");
else if (codeType == PANASONIC) {
Serial.print("Received PANASONIC: ");
else if (codeType == JVC) {
Serial.print("Received JVC: ");
else if (codeType == RC5) {
Serial.print("Received RC5: ");
else if (codeType == RC6) {
Serial.print("Received RC6: ");
else {
Serial.print("Unexpected codeType ");
Serial.print(codeType, DEC);
Serial.println("");
Serial.println(results->value, HEX);
codeValue = results->value;
codeLen = results->bits;
void sendCode(int repeat) {
if (repeat) {
irsend.sendNEC(REPEAT, codeLen);
Serial.println("Sent NEC repeat");
else {
irsend.sendNEC(codeValue, codeLen);
Serial.print("Sent NEC ");
Serial.println(codeValue, HEX);
irsend.sendSony(codeValue, codeLen);
Serial.print("Sent Sony ");
irsend.sendPanasonic(codeValue, codeLen);
Serial.print("Sent Panasonic");
irsend.sendJVC(codeValue, codeLen, false);
Serial.print("Sent JVC");
else if (codeType == RC5 || codeType == RC6) {
if (!repeat) {
// Flip the toggle bit for a new button press
toggle = 1 - toggle;
// Put the toggle bit into the code to send
codeValue = codeValue & ~(1 << (codeLen - 1));
codeValue = codeValue | (toggle << (codeLen - 1));
Serial.print("Sent RC5 ");
irsend.sendRC5(codeValue, codeLen);
else {
irsend.sendRC6(codeValue, codeLen);
Serial.print("Sent RC6 ");
else if (codeType == UNKNOWN /* i.e. raw */) {
// Assume 38 KHz
irsend.sendRaw(rawCodes, codeLen, 38);
Serial.println("Sent raw");
int lastButtonState;
// If button pressed, send the code.
int buttonState = digitalRead(BUTTON_PIN);
if (lastButtonState == HIGH && buttonState == LOW) {
Serial.println("Released");
irrecv.enableIRIn(); // Re-enable receiver
if (buttonState) {
Serial.println("Pressed, sending");
digitalWrite(STATUS_PIN, HIGH);
sendCode(lastButtonState == buttonState);
digitalWrite(STATUS_PIN, LOW);
delay(50); // Wait a bit between retransmissions
else if (irrecv.decode(&results)) {
storeCode(&results);
irrecv.resume(); // resume receiver
lastButtonState = buttonState;
Error Message:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino Uno"
C:\Users\Rory\AppData\Local\Temp\cc62CSbW.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_IRrecord.ino.cpp.o.1819':
<artificial>:(.text.startup+0x60): undefined reference to `IRrecv::IRrecv(int)'
C:\Users\Rory\AppData\Local\Temp\cc62CSbW.ltrans0.ltrans.o: In function `setup':
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:32: undefined reference to `IRrecv::enableIRIn()'
C:\Users\Rory\AppData\Local\Temp\cc62CSbW.ltrans0.ltrans.o: In function `loop':
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:166: undefined reference to `IRrecv::enableIRIn()'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:176: undefined reference to `IRrecv::decode(decode_results*)'
C:\Users\Rory\AppData\Local\Temp\cc62CSbW.ltrans0.ltrans.o: In function `sendCode':
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:109: undefined reference to `IRsend::sendNEC(unsigned long, int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:113: undefined reference to `IRsend::sendNEC(unsigned long, int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:119: undefined reference to `IRsend::sendSony(unsigned long, int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:124: undefined reference to `IRsend::sendPanasonic(unsigned int, unsigned long)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:129: undefined reference to `IRsend::sendJVC(unsigned long, int, bool)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:144: undefined reference to `IRsend::sendRC5(unsigned long, int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:147: undefined reference to `IRsend::sendRC6(unsigned long, int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:154: undefined reference to `IRsend::sendRaw(unsigned int const*, unsigned int, unsigned int)'
C:\Users\Rory\Documents\Arduino\Arduino-IRremote-2.4.0\Arduino-IRremote-2.4.0\examples\IRrecord/IRrecord.ino:179: undefined reference to `IRrecv::resume()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
