Error compiling for board ATtiny13
hi
this is my code:
pinMode(4, OUTPUT);
digitalWrite(4, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(4, LOW); // turn the LED off by making the voltage LOW
I just try " verify "
Who can advise me about this problem
recipe.preproc.macros pattern is missing
Error compiling for board ATtiny13 @ 9.6MHz (interne 9.6 MHz clock).
I've downloaded the ATtiny13 core files for Arduino
and
Extract the zipped file in the above location, (Arduino>Hardware folder).
amkoshesh:
I’ve downloaded the ATtiny13 core files for Arduino
From where?
Use this one instead:
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
pert:
From where?
GitHub - MCUdude/MicroCore: An light-weight Arduino hardware package for ATtiny13
Thank you very much
Thank you for your advice
But still the same error
The virus PC is the cause of error?
[code][code][code][/code][/code][/code]
amkoshesh:
Did you select the MicroCore board from the Tools > Board menu? MicroCore definitely does have recipe.preproc.macros defined.
amkoshesh:
Definitely not. The problem is most likely that you installed a very old hardware package that is not compatible with the version of the Arduino IDE you're using. I can't say for sure because you didn't say which package you installed originally or where you got it from.
pert:
yes
Please see the Picture
http://forum.arduino.ir/4/12/3348.html#post16540
Please post the picture here. I don't want to visit some random website.
pert:
excuse me
can you see in the picture?
Since I put up my picture
picture is ide Windows
for better understanding
Where is upload ? for you
You posted a link to some website named arduino.ir that I've never heard of. I don't know or trust that website so I'm not going to visit it. You can embed the image with the picture icon on the toolbar or you can attach the photo by clicking "Reply" and then "Attachments and other options". Better yet, attach and embed the picture by following the instructions at:
When you post links please use the chain links icon to make them clickable.
amkoshesh:
I get this when I click on untitled.jpg. I think the forum requires me to sign in before I can see it.
Finally I could send my picture
You're still using the old ATtiny13 package that you originally installed, that's why you're still getting the same error. If the MicroCore board isn't showing in the Tools > Board menu then the old package may be interfering with MicroCore, please uninstall the old package and then restart the Arduino IDE.
pert:
Good news
Great great great
Very good
Thank you
How I appreciate you
Hardware folders of old files got deleted and new files placed on your attiny13
I'm questions
Files related to the attiny45, attiny85, .... atmega8, atmega16, atmega128, pic ic , se ic
Link the most?
Where is?
Very grateful
Very grateful
How disable the divide clock by 8؟
Because the disorder Runtime
Hex code has already been made. In this way it is possible to transfer?
STMicroelectronics IC core for Arduino. There is?
amkoshesh:
amkoshesh:
atmega8
amkoshesh:
atmega16
amkoshesh:
atmega128
amkoshesh:
pic ic
Not sure, maybe someone else knows of a good PIC package for Arduino
amkoshesh:
se ic
What's that? Intel Quark SE?
amkoshesh:
GitHub - rogerclarkmelbourne/Arduino_STM32: Arduino STM32. Hardware files to support STM32 boards, on Arduino IDE 1.8.x including LeafLabs Maple and other generic STM32F103 boards (for STM32)
amkoshesh:
If I'm reading the fuse settings in MicroCore it should do that by default. Here they are for the Tools > Clock > 9.6 MHz internal osc., Tools > B.O.D. > 2.7v board setting:
http://eleccelerator.com/fusecalc/fusecalc.php?chip=attiny13&LOW=3A&HIGH=FB&LOCKBIT=3E
The chip comes from the factory with the fuses set to divide the clock by 8. Did you do Tools > Burn Boorloader? This is required to set the fuses according to your selections in the Tools menus, even though there is no bootloader in MicroCore. Sketch > Upload Using Programmer does not set the fuses
pert:
GitHub - SpenceKonde/ATTinyCore: Arduino core for ATtiny 1634, 828, x313, x4, x41, x5, x61, x7 and x8
GitHub - MCUdude/MiniCore: Arduino hardware package for ATmega8, ATmega48, ATmega88, ATmega168, ATmega328 and ATmega328PB
GitHub - MCUdude/MightyCore: Arduino hardware package for ATmega1284, ATmega644, ATmega324, ATmega324PB, ATmega164, ATmega32, ATmega16 and ATmega8535
GitHub - MCUdude/MegaCore: Arduino hardware package for ATmega64, ATmega128, ATmega640, ATmega1280, ATmega1281, ATmega2560, ATmega2561, AT90CAN32, AT90CAN64 and AT90CAN128
What’s that? Intel Quark SE?
https://github.com/rogerclarkmelbourne/Arduino_STM32 (for STM32)
If I’m reading the fuse settings in MicroCore it should do that by default. Here they are for the Tools > Clock > 9.6 MHz internal osc., Tools > B.O.D. > 2.7v board setting:
AVR Fuse Calculator for ATtiny13
that was perfect
Thankful
one question
Hex code has been made in the past. In this way it is possible to transfer? Using Arduino as isp
amkoshesh:
that was perfect
Thankful
Glad I was able to help! Please take the time to update your post on arduino.ir with what you learned so that others can benefit from this information.
amkoshesh:
Yes, if the hex file was compiled for the hardware you're using, but you can't do it using the Arduino IDE. You will need to use AVRDUDE from the command line. AVRDUDE is included with the Arduino IDE, it's the tool used for Upload, Upload Using Programmer, and Burn Bootloader on all AVR microcontrollers.
To make it super easy you can use the Arduino IDE to generate the command you need to run from the command line by uploading a blank sketch to the microcontroller:
  • Plug the Arduino as ISP into your computer.
  • File > New
  • File > Preferences > Show verbose output during: > upload(check) > OK
  • Tools > Board > ATtiny13
  • Tools > Programmer > Arduino as ISP
  • Tools > Port > select the port of the Arduino as ISP
  • Sketch > Upload Using Programmer
  • After the upload completes scroll up the black console window in the bottom of the Arduino IDE window until you see the AVRDUDE command at the start of the uploading process. It will look something like:
E:\ArduinoIDE\arduino-1.8.1\hardware\tools\avr/bin/avrdude -CE:\ArduinoIDE\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf -v -pattiny13 -cstk500v1 -PCOM21 -b19200 -Uflash:w:C:\Users\per\AppData\Local\Temp\arduino_build_882863/sketch_feb05a.ino.hex:i
  • Highlight that command in the console and copy it to the clipboard.
  • Open the command line on your computer.
  • Paste the command to the command line but change the filename (C:\Users\per\AppData\Local\Temp\arduino_build_882863/sketch_feb05a.ino.hex in my example) to the hex file you want to upload.
pert:
[/li]
[/list]
How?
This is the correct choice?
amkoshesh:
How?
I'm assuming the post you linked above (پروگرام کردن avr با آردوینو uno) is regarding your question about ATtiny13. Add a summary of the solution you found to the problem you had on that thread so that if someone else has the same problem and finds your post on that forum they will be helped. This is the great thing about forums. I helped you solve your problem but many other people may find this thread in search results over the years and also be helped without me having to make any extra effort.
