Error below was displayed when i tried to compile wifiscan sample code in the ide. I tried with another sample codes but the same error appeared.
Error:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
In file included from c:\users\user\onedrive - universiti teknologi mara\documents\arduinodata\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2\xtensa-esp32-elf\include\c++\8.4.0\stdlib.h:36,
from C:\Users\User\OneDrive - Universiti Teknologi MARA\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/include/newlib/platform_include/assert.h:21,
from c:\users\user\onedrive - universiti teknologi mara\documents\arduinodata\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2\xtensa-esp32-elf\sys-include\sys\reent.h:503,
from C:\Users\User\OneDrive - Universiti Teknologi MARA\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.2/tools/sdk/esp32/include/newlib/platform_include/sys/reent.h:17,
from c:\users\user\onedrive - universiti teknologi mara\documents\arduinodata\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2\xtensa-esp32-elf\sys-include\stdio.h:60,
from C:\Users\User\OneDrive - Universiti Teknologi MARA\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.2\cores\esp32/Arduino.h:27,
from sketch\Blink.ino.cpp:1:
c:\users\user\onedrive - universiti teknologi mara\documents\arduinodata\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2\xtensa-esp32-elf\include\c++\8.4.0\cstdlib:41:10: fatal error: bits/c++config.h: No such file or directory
#include <bits/c++config.h>
compilation terminated.
exit status 1
Error compiling for board DOIT ESP32 DEVKIT V1.
option enabled in File -> Preferences.
in0
May 17, 2022, 3:31am
2
Hi @malware_exe . I'm going to ask you to provide some additional information that might allow us to determine the cause of the problem.
Please do this:
Select File > Preferences from the Arduino IDE menus.
Check the box next to "Show verbose output during: ☐ compilation ".
Click the OK button.
Select Sketch > Verify/Compile from the Arduino IDE menus.
After the compilation fails you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages . Click that button.
This copies the full output to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the </>
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
Press Ctrl +V .
This will paste the compilation output into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
i have already uploaded the full error message🤨
in0
May 18, 2022, 6:23pm
4
Was that the output with verbose compilation output enabled?
Arduino: 1.8.19 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cotys\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cotys\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cotys\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\cotys\AppData\Local\Temp\arduino_build_155915 -warnings=none -build-cache C:\Users\cotys\AppData\Local\Temp\arduino_cache_376347 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\cotys\Desktop\ESP32-Radio-master\ESP32-Radio-master\ESP32-Radio\ESP32-Radio.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cotys\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cotys\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cotys\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\cotys\AppData\Local\Temp\arduino_build_155915 -warnings=none -build-cache C:\Users\cotys\AppData\Local\Temp\arduino_cache_376347 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\cotys\Desktop\ESP32-Radio-master\ESP32-Radio-master\ESP32-Radio\ESP32-Radio.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\cotys\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\Users\\cotys\\Desktop\\ESP32-Radio-master\\ESP32-Radio-master\\ESP32-Radio\\partitions.csv" copy /y "C:\\Users\\cotys\\Desktop\\ESP32-Radio-master\\ESP32-Radio-master\\ESP32-Radio\\partitions.csv" "C:\\Users\\cotys\\AppData\\Local\\Temp\\arduino_build_155915\\partitions.csv"
cmd /c if not exist "C:\\Users\\cotys\\AppData\\Local\\Temp\\arduino_build_155915\\partitions.csv" copy "C:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\cotys\\AppData\\Local\\Temp\\arduino_build_155915\\partitions.csv"
Detecting libraries used...
"C:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"doitESP32devkitV1\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\doitESP32devkitV1" "C:\\Users\\cotys\\AppData\\Local\\Temp\\arduino_build_155915\\sketch\\ESP32-Radio.ino.cpp" -o nul
"C:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"doitESP32devkitV1\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\cotys\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\doitESP32devkitV1" "C:\\Users\\cotys\\AppData\\Local\\Temp\\arduino_build_155915\\sketch\\src\\main.cpp" -o nul
Alternatives for PubSubClient.h: []C:\Users\cotys\Desktop\ESP32-Radio-master\ESP32-Radio-master\ESP32-Radio\src\main.cpp:193:26: fatal error: PubSubClient.h: No such file or directory
ResolveLibrary(PubSubClient.h)
-> candidates: []
exit status 1
system
Closed
March 6, 2023, 6:10am
6
