Error compiling for board ESP32 Wrover Module
I have tried ti uninstall the arduino IDE app and download it again, but the error still occurs.
This is my code:
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
//isi dengan alamat dan password wifi
const char* ssid = "Awan";
const char* password = "__o8z3__";
//konfigurasi komponen
const int knockSensor = 12;
const int programSwitch = 15;
const int Solenoid = 14;
const int greenLED = 4;
const int threshold = 100;
const int rejectValue = 25;
const int averageRejectValue = 15;
const int knockFadeTime = 150;
const int lockTurnTime = 2000;
const int maximumKnocks = 20;
const int knockComplete = 1200;
int secretCode[maximumKnocks] = {25, 25, 35, 50, 40, 50, 0, 0, 0, 0};
int knockReadings[maximumKnocks];
int knockSensorValue = 0;
int programButtonPressed = false;
int buzzerDoor = 2;
//kamera
String BOTtoken = "6986562297:AAFp-ujtEgNaSWB_GeQhlY5A9VGuJoTuWmc"; // isi dengan token dari botfather telegram
String chatId = " "; //isi dengan id chat dari id bot
bool sendPhoto = false;
WiFiClientSecure clientTCP;
UniversalTelegramBot bot(BOTtoken, clientTCP);
//pintu
const String label1 = "Pintu terkunci";
const String label2 = "Initialize...";
const String label3 = "Silahkan masuk";
const String label4 = "Merekam";
const String label5 = "Program Siap";
const String label6 = "Silahkan Ketuk";
const String label7 = "Ketukan tersimpan";
//konfigurasi pin
#define SDA_PIN 0
#define SCL_PIN 16
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#define FLASHpin 4
bool flashState = LOW;
bool adaGerakan = false;
int botRequestDelay = 1000;   // setiap 1 detik akan check bot
long lastTimeBotRan;
void handleNewMessages(int numNewMessages);
String sendPhotoTelegram();
static void IRAM_ATTR detectsMovement(void * arg){
  //Serial.println("ADA GERAKAN!!!");
  adaGerakan = true;
void setup(){
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  pinMode(FLASHpin, OUTPUT);
  digitalWrite(FLASHpin, flashState);
  WiFi.mode(WIFI_STA);
  Serial.print("menghubungkan wifi: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  clientTCP.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.print("ESP32-CAM IP Address: ");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  // Drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_CIF);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  // PIR Motion Sensor mode INPUT_PULLUP
  //err = gpio_install_isr_service(0);
  err = gpio_isr_handler_add(GPIO_NUM_13, &detectsMovement, (void *) 13);  // pin sensor yg di gunakan
  if (err != ESP_OK){
    Serial.printf("handler add failed with error 0x%x \r\n", err);
  err = gpio_set_intr_type(GPIO_NUM_13, GPIO_INTR_POSEDGE);
  if (err != ESP_OK){
    Serial.printf("set intr type failed with error 0x%x \r\n", err);
  //pintu
  lcd.backlight();
Wire.begin(SDA_PIN, SCL_PIN);
  lcd.begin(16, 2);
  pinMode(Solenoid, OUTPUT);
  //pinMode(redLED, OUTPUT);
  pinMode(greenLED, OUTPUT);
  pinMode(buzzerDoor, OUTPUT);
  pinMode(programSwitch, INPUT);
  Serial.println("mulai program");
  digitalWrite(greenLED, HIGH);
  clearLCDLine(0);
  lcd.print(label2);
   delay(2000);
  clearLCDLine(0);
  lcd.print(label5);
  clearLCDLine(0);
  lcd.print(label6);
  clearLCDLine(1);
  lcd.print(label1);
void loop(){
  if (sendPhoto){
    Serial.println("persiapan foto");
    sendPhoto = false;
  if(adaGerakan){
    bot.sendMessage(chatId, "ADA GERAKAN !!!", "");
    Serial.println("Ada gerakan");
    adaGerakan = false;
  if (millis() > lastTimeBotRan + botRequestDelay){
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    while (numNewMessages){
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    lastTimeBotRan = millis();
  //pintu
   knockSensorValue = analogRead(knockSensor);
  if (digitalRead(programSwitch)==HIGH){
    programButtonPressed = true;
    clearLCDLine(1);
    lcd.print("Recording");
    Serial.println("Recording");
    clearLCDLine(1);
    lcd.print("Pintu Terkunci");
    Serial.println("Pintu Terkunci");
  if (knockSensorValue >=threshold){
    listenToSecretKnock();
void handleNewMessages(int numNewMessages){
  Serial.print("Handle New Messages: ");
  Serial.println(numNewMessages);
  for (int i = 0; i < numNewMessages; i++){
    // Chat id of the requester
    String chat_id = String(bot.messages[i].chat_id);
    if (chat_id != chatId){
      bot.sendMessage(chat_id, "Unauthorized user", "");
      continue;
    // Print the received message
    String text = bot.messages[i].text;
    Serial.println(text);
    String fromName = bot.messages[i].from_name;
    if (text == "/flash") {
      flashState = !flashState;
    if (text == "/foto") {
      sendPhoto = true;
      Serial.println("New photo  request");
    if (text == "/start"){
      String welcome = "at-mo production\n";
      welcome += "klik tulisan biru\n";
      welcome += "/foto : untuk ambil gambar langsung\n";
      welcome += "/flash : untuk on off lampu flash\n";
      welcome += "system ini otomatis kirim foto saat terjadi gerakan.\n";
      bot.sendMessage(chatId, welcome, "Markdown");
//pintu
void listenToSecretKnock(){
  clearLCDLine(1);
  lcd.print("Silahkan Ketuk Pintu");
  Serial.println("silahkan ketuk pintu");
  int i = 0;
  for (i=0;i<maximumKnocks;i++){
    knockReadings[i]=0;
  int currentKnockNumber=0;
  int startTime=millis();
  int now=millis();
  digitalWrite(greenLED, LOW);
  if (programButtonPressed==true){
  delay(knockFadeTime);
     digitalWrite(buzzerDoor, HIGH);
     tone(buzzerDoor, 1000);
  do {
      clearLCDLine(1);
      lcd.print("mengetuk");
      Serial.println("mengetuk");
      now=millis();
      knockReadings[currentKnockNumber] = now-startTime;
      currentKnockNumber ++;
      startTime=now;
    now=millis();
  } while ((now-startTime < knockComplete) && (currentKnockNumber < maximumKnocks));
  if (programButtonPressed==false){
    if (validateKnock() == true){
      triggerDoorUnlock();
      clearLCDLine(1);
      lcd.print("ketukan salah");
      Serial.println("ketukan salah");
      for (i=0;i<4;i++){
        delay(100);
        digitalWrite(buzzerDoor, LOW);
        noTone(buzzerDoor);
        delay(100);
      clearLCDLine(1);
    validateKnock();
    clearLCDLine(0);
   lcd.print("Silahkan ketuk");
   clearLCDLine(1);
   lcd.print(label7);
  lcd.print("Ketukan tersimpan");
   clearLCDLine(1);
   lcd.print(label1);
   lcd.print("Pintu terkunci");
    Serial.println("ketukan baru");
    for (i=0;i<3;i++){
      delay(50);
      delay(100);
      noTone(buzzerDoor);
void triggerDoorUnlock(){
  clearLCDLine(1);
  lcd.print(label3);
  lcd.print("Silahkan masuk");
  Serial.println("Silahkan Masuk");
  int i=0;
  digitalWrite(Solenoid, HIGH);
  delay (lockTurnTime);
  digitalWrite(Solenoid, LOW);
  for (i=0; i < 5; i++){
      delay(100);
      delay(100);
  clearLCDLine(1);
  lcd.print("pintu terkunci");
  Serial.println("pintu terkunci");
boolean validateKnock(){
  int i=0;
  int currentKnockCount = 0;
  int secretKnockCount = 0;
  int maxKnockInterval = 0;
    if (knockReadings[i] > 0){
      currentKnockCount++;
    if (secretCode[i] > 0){
      secretKnockCount++;
    if (knockReadings[i] > maxKnockInterval){
      maxKnockInterval = knockReadings[i];
        secretCode[i]= map(knockReadings[i],0, maxKnockInterval, 0, 50);
      delay(50);
      for (i = 0; i < maximumKnocks ; i++){
          delay( map(secretCode[i],0, 50, 0, maxKnockInterval));
        delay(50);
    return false;
  if (currentKnockCount != secretKnockCount){
    return false;
  int totaltimeDifferences=0;
  int timeDiff=0;
    knockReadings[i]= map(knockReadings[i],0, maxKnockInterval, 0, 50);
    timeDiff = abs(knockReadings[i]-secretCode[i]);
    if (timeDiff > rejectValue){
      return false;
    totaltimeDifferences += timeDiff;
  if (totaltimeDifferences/secretKnockCount>averageRejectValue){
    return false;
  return true;
void clearLCDLine(int line){
 for(int n = 0; n < 20; n++) {    // 20 indicates symbols in line. For 2x16 LCD write - 16
   lcd.setCursor(n,line);
   lcd.print(" ");
 lcd.setCursor(0,line);          // set cursor in the beginning of deleted line
and this is the eror compiling:
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\codingan_finish__sempurna_.ino.cpp.o:(.literal.Z4loopv+0x24): undefined reference to sendPhotoTelegram()' c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\codingan_finish__sempurna_.ino.cpp.o: in function loop()':
C:\Users\acer\OneDrive\Documents\File Kurniawan\HASIL TUGAS AKHIR\codingan_finish__sempurna
/codingan_finish__sempurna_.ino:358: undefined reference to sendPhotoTelegram()' c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\File Kurniawan\HASIL TUGAS AKHIR\codingan_finish__sempurna_/codingan_finish__sempurna_.ino:369: undefined reference to sendPhotoTelegram()'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "WiFi.h"
Used: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Error compiling for board ESP32 Wrover Module.
This function does not seem to be in the sketch or the UniversalTelegramBot library but there is a function named sendPhoto() and one named sendPhotoByBinary()
Where did you get the sketch from ?
I moved your topic to a more appropriate forum category @kurniawantakulowa_1.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
but when i try this code without door lock code,it is work. or maybe i have something wrong when i combine these two codings? i mean camera code and door lock code.
please help me to combine the two codings.
sorry, i have two codings, between camera code and door lock code. when i tried both code separately, they worked fine, but when i tried to combine the two codings, there was an error (error compiling of board ESP32 Wrover Module).
please help me dude.
how do I combine the coding below? I want to make a project to monitor the house to remain safe with two methods, namely monitoring via camera and also providing a password on the door.
#include <WiFi.h>
#include <Wire.h>
//isi dengan alamat dan password wifi kalian
String chatId = "0000000000"; //isi dengan id chat dari id bot
#define FLASHpin 4
  adaGerakan = true;
void setup(){
    Serial.print(".");
  if(psramFound()){
  // camera init
    ESP.restart();
  if (err != ESP_OK){
  if (err != ESP_OK){
void loop(){
  if (sendPhoto){
    sendPhoto = false;
  if(adaGerakan){
    adaGerakan = false;
String sendPhotoTelegram(){
  const char* myDomain = "api.telegram.org";
  String getAll = "";
  String getBody = "";
  camera_fb_t * fb = NULL;
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("kamera gagal ambil gambar");
    ESP.restart();
    return "kamera gagal ambil gambar";
  Serial.println("Connect to " + String(myDomain));
  if (clientTCP.connect(myDomain, 443)) {
    Serial.println("berhasil terhubung");
    String head = "--RandomNerdTutorials\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + chatId + "\r\n--RandomNerdTutorials\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--RandomNerdTutorials--\r\n";
    uint16_t imageLen = fb->len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    clientTCP.println("POST /bot"+BOTtoken+"/sendPhoto HTTP/1.1");
    clientTCP.println("Host: " + String(myDomain));
    clientTCP.println("Content-Length: " + String(totalLen));
    clientTCP.println("Content-Type: multipart/form-data; boundary=RandomNerdTutorials");
    clientTCP.println();
    clientTCP.print(head);
    uint8_t *fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n=0;n<fbLen;n=n+1024) {
      if (n+1024<fbLen) {
        clientTCP.write(fbBuf, 1024);
        fbBuf += 1024;
      else if (fbLen%1024>0) {
        size_t remainder = fbLen%1024;
        clientTCP.write(fbBuf, remainder);
    clientTCP.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;   // timeout 10 seconds
    long startTimer = millis();
    boolean state = false;
    while ((startTimer + waitTime) > millis()){
      Serial.print(".");
      delay(100);
      while (clientTCP.available()) {
        char c = clientTCP.read();
        if (state==true) getBody += String(c);
        if (c == '\n') {
          if (getAll.length()==0) state=true;
          getAll = "";
        else if (c != '\r')
          getAll += String(c);
      if (getBody.length()>0) break;
    clientTCP.stop();
    Serial.println(getBody);
  else {
    getBody="Connected to api.telegram.org failed.";
    Serial.println("Connected to api.telegram.org failed.");
  return getBody;
      continue;
      sendPhoto = true;
Your code tags worked for the first sketch but did not work for the second sketch.
I just finished changing it, please take a look again :cry:
Now I see only one sketch. Did you combine them?
between CODINGAN 1 and CODINGAN 2
Please post each sketch in its own code tags.
This is the second coding. please help me :cry:
#include <Wire.h>
int buzzerDoor = 2;
#define SDA_PIN 0
#define SCL_PIN 16
lcd.backlight();
  lcd.begin(16, 2);
  clearLCDLine(0);
  lcd.print(label2);
   delay(2000);
  clearLCDLine(0);
  lcd.print(label5);
  clearLCDLine(0);
  lcd.print(label6);
  clearLCDLine(1);
  lcd.print(label1);
    clearLCDLine(1);
    clearLCDLine(1);
  clearLCDLine(1);
  int i = 0;
    knockReadings[i]=0;
  int now=millis();
  do {
      clearLCDLine(1);
      now=millis();
      startTime=now;
    now=millis();
      clearLCDLine(1);
      for (i=0;i<4;i++){
        delay(100);
        noTone(buzzerDoor);
        delay(100);
      clearLCDLine(1);
    validateKnock();
    clearLCDLine(0);
   clearLCDLine(1);
   lcd.print(label7);
   clearLCDLine(1);
   lcd.print(label1);
    for (i=0;i<3;i++){
      delay(50);
      delay(100);
      noTone(buzzerDoor);
  clearLCDLine(1);
  lcd.print(label3);
  int i=0;
      delay(100);
      delay(100);
  clearLCDLine(1);
  int i=0;
      secretKnockCount++;
      delay(50);
        delay(50);
    return false;
    return false;
  int timeDiff=0;
      return false;
    return false;
  return true;
   lcd.print(" ");
The first step for combining two sketches is to understand the meaning and purpose of each line of code in each sketch. Have you done this?
If so:
  1. combine the global variables from the second sketch into the first sketch, removing any duplications.
  2. combine the added functions (not setup() or loop()) from the second sketch into the first sketch
  3. combine the contents of setup() from the second sketch into setup() of the first sketch, removing any duplicate lines. Same for loop().
I combine like this, but i got eror (error board ESP32 Wrover Module) :cry:
#include <WiFi.h>
#include <Wire.h>
int buzzerDoor = 2;
//kamera
String chatId = "6465172692"; //isi dengan id chat dari id bot
//pintu
//konfigurasi pin
#define SDA_PIN 0
#define SCL_PIN 16
#define FLASHpin 4
  adaGerakan = true;
void setup(){
    Serial.print(".");
  if(psramFound()){
  // camera init
    ESP.restart();
  if (err != ESP_OK){
  if (err != ESP_OK){
  //pintu
  lcd.backlight();
  lcd.begin(16, 2);
  clearLCDLine(0);
  lcd.print(label2);
   delay(2000);
  clearLCDLine(0);
  lcd.print(label5);
  clearLCDLine(0);
  lcd.print(label6);
  clearLCDLine(1);
  lcd.print(label1);
void loop(){
  if (sendPhoto){
    sendPhoto = false;
  if(adaGerakan){
    adaGerakan = false;
  //pintu
    clearLCDLine(1);
    clearLCDLine(1);
      continue;
      sendPhoto = true;
//pintu
  clearLCDLine(1);
  int i = 0;
    knockReadings[i]=0;
  int now=millis();
  do {
      clearLCDLine(1);
      now=millis();
      startTime=now;
    now=millis();
      clearLCDLine(1);
      for (i=0;i<4;i++){
        delay(100);
        noTone(buzzerDoor);
        delay(100);
      clearLCDLine(1);
    validateKnock();
    clearLCDLine(0);
   clearLCDLine(1);
   lcd.print(label7);
   clearLCDLine(1);
   lcd.print(label1);
    for (i=0;i<3;i++){
      delay(50);
      delay(100);
      noTone(buzzerDoor);
  clearLCDLine(1);
  lcd.print(label3);
  int i=0;
      delay(100);
      delay(100);
  clearLCDLine(1);
  int i=0;
      secretKnockCount++;
      delay(50);
        delay(50);
    return false;
    return false;
  int timeDiff=0;
      return false;
    return false;
  return true;
   lcd.print(" ");
Post the full set of error messages, using code tags.
I GOT THIS:
exit status 1
Please see post #11
Up to now you have not mentioned that you are trying to merge two sketches into one
Please post the 2 separate sketches that you say work OK
I have merged your cross-posts @kurniawantakulowa_1.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Since you inappropriately created the cross-post in the Nano ESP32 category even after I have repeatedly told you not to do that, I have given you a temporary account suspension. I hope that when you return to the forum you'll be more respectful of our community.
Thanks in advance.
