#include <WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
#include<ArduinoJson.h>
#include <SPI.h>
#include <LoRa.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
bool a;
char hfhnfgh[1024];
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
const char* ssid = "Zeptogreens";
const char* password = "Zeptogreens@2023";
// Add your MQTT Broker IP address, example:
//const char* mqtt_server = "192.168.1.144";
const char* mqtt_server = "192.168.0.186";
const char* mqttUsername = "Zeptogreens";
const char* mqttpsw = "123456";
const char* TOPIC = "KIKIK";
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Client", mqttUsername, mqttpsw)) {
Serial.println("connected");
// Subscribe
// client.subscribe(ZoneNSensor);
a = true;
a = false;
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void sensor()
DynamicJsonDocument doc(500);
JsonObject mydoc = doc.createNestedObject("info");
mydoc["rollnum"]=1233;
mydoc["name "]="sensor";
mydoc["school"]="didnt go";
serializeJson(doc,Serial);
serializeJson(doc,hfhnfgh);
client.publish(TOPIC,hfhnfgh);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (!client.connected()) {
reconnect();
client.loop();
delay(3000);
sensor();
Arduino: 1.8.19 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\assert.h:10,
from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\sys\reent.h:503,
from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\stdlib.h:18,
from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\cstdlib:75,
from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\stdlib.h:36,
from C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:27,
from C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.h:23,
from C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:20:
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:37:17: error: 'const char OK []' redeclared as different kind of entity
37 | const char OK[] PROGMEM = "OK";
In file included from C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/esp8266_peri.h:27,
from C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:38,
C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include/c_types.h:71:5: note: previous declaration 'STATUS OK'
71 | OK = 0,
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:38:21: error: 'const char STATUS []' redeclared as different kind of entity
38 | const char STATUS[] PROGMEM = "STATUS";
C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include/c_types.h:76:3: note: previous declaration 'typedef enum STATUS STATUS'
76 | } STATUS;
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'int EspAtDrvClass::staStatus()':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:180:26: error: expected primary-expression before ')' token
180 | if (!sendCommand(STATUS))
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'bool EspAtDrvClass::remoteParamsQuery(uint8_t, IPAddress&, uint16_t&)':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:855:28: error: expected primary-expression before ')' token
855 | if (!sendCommand(STATUS))
In file included from c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\string.h:175,
from C:\Users\DELL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:33,
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'size_t EspAtDrvClass::sendData(uint8_t, const uint8_t*, size_t, const char*, uint16_t)':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1090:42: error: cannot convert 'STATUS' to 'const char*'
1090 | if (strcmp_P(buffer + strlen("SEND "), OK) != 0) {// FAIL
| STATUS
c:\users\dell\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\sys\string.h:38:30: note: initializing argument 2 of 'int strncmp_P(const char*, const char*, size_t)'
38 | int strncmp_P(const char *, const char *, size_t);
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'size_t EspAtDrvClass::sendData(uint8_t, Stream&, const char*, uint16_t)':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1147:70: error: cannot convert 'STATUS' to 'const char*'
1147 | if (!readRX(PSTR("SEND ")) || strcmp_P(buffer + strlen("SEND "), OK) != 0) {// FAIL
| STATUS
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'size_t EspAtDrvClass::sendData(uint8_t, SendCallbackFnc, const char*, uint16_t)':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1204:42: error: cannot convert 'STATUS' to 'const char*'
1204 | if (strcmp_P(buffer + strlen("SEND "), OK) != 0) {// FAIL
| STATUS
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'bool EspAtDrvClass::readRX(const char*, bool, bool)':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1543:46: error: cannot convert 'STATUS' to 'const char*'
1543 | } else if (listItem && !strcmp_P(buffer, OK)) { // OK ends the listing of unknown items count
| STATUS
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'bool EspAtDrvClass::readOK()':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1560:17: error: cannot convert 'STATUS' to 'const char*'
1560 | return readRX(OK);
| STATUS
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1393:34: note: initializing argument 1 of 'bool EspAtDrvClass::readRX(const char*, bool, bool)'
1393 | bool EspAtDrvClass::readRX(PGM_P expected, bool bufferData, bool listItem) {
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp: In member function 'bool EspAtDrvClass::checkLinks()':
C:\Users\DELL\Documents\Arduino\libraries\WiFiEspAT\src\utility\EspAtDrv.cpp:1677:26: error: expected primary-expression before ')' token
1677 | if (!sendCommand(STATUS))
exit status 1
Error compiling for board Generic ESP8266 Module.
option enabled in File -> Preferences.
I have created JsonPackage and sending data to MQTT server but esp8266 board is not supporting can any one check this error.
the ESP8266 WiFi library is ESP8266WiFi.h not WiFi.h
