I am testing the ESP8266 built-in MEGA2560 and got ERROR need help please.
Thanks
Adam
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char* ssid = "haha";
const char* password = "cumakamu";
ESP8266WebServer server(80);
MDNSResponder mdns;
String webPage = "";
int led_pin = 13;
void setup(void){
// подготовка:
pinMode(led_pin, OUTPUT);
digitalWrite(led_pin, LOW);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// информация о контроллере
Serial.println("");
Serial.println("ESP8266 board info:");
Serial.print("\tChip ID: ");
Serial.println(ESP.getFlashChipId());
Serial.print("\tCore Version: ");
Serial.println(ESP.getCoreVersion());
Serial.print("\tChip Real Size: ");
Serial.println(ESP.getFlashChipRealSize());
Serial.print("\tChip Flash Size: ");
Serial.println(ESP.getFlashChipSize());
Serial.print("\tChip Flash Speed: ");
Serial.println(ESP.getFlashChipSpeed());
Serial.print("\tChip Speed: ");
Serial.println(ESP.getCpuFreqMHz());
Serial.print("\tChip Mode: ");
Serial.println(ESP.getFlashChipMode());
Serial.print("\tSketch Size: ");
Serial.println(ESP.getSketchSize());
Serial.print("\tSketch Free Space: ");
Serial.println(ESP.getFreeSketchSpace());
// тело веб-страницы
webPage += "<h1>ESP8266 Web Server</h1>";
webPage += "<p>Chip ID: ";
webPage += ESP.getFlashChipId();
webPage += "</p>";
webPage += "<p>Core Version: ";
webPage += ESP.getCoreVersion();
webPage += "</p>";
webPage += "<p>Chip Real Size: ";
webPage += ESP.getFlashChipRealSize()/1024;
webPage += " Kbit</p>";
webPage += "<p>Chip Size: ";
webPage += ESP.getFlashChipSize()/1024;
webPage += "<p>Chip Flash Speed: ";
webPage += ESP.getFlashChipSpeed()/1000000;
webPage += " MHz</p>";
webPage += "<p>Chip Work Speed: ";
webPage += ESP.getCpuFreqMHz();
webPage += "<p>Chip Mode: ";
webPage += ESP.getFlashChipMode();
webPage += "</p>";
webPage += "<p>LED state <a href=\"LedON\"><button>ON</button></a> <a href=\"LedOFF\"><button>OFF</button></a></p>";
// подключение к WiFi
WiFi.begin(ssid, password);
Serial.println("");
// ожидание соединения:
Serial.print(".");
Serial.println("");
Serial.print("Connected to "); //
Serial.println(ssid);
Serial.print("IP address: "); //
// Проверка запуска MDNS
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", [](){
server.send(200, "text/html", webPage);
server.on("/LedON", [](){
digitalWrite(led_pin, HIGH);
Serial.println("[ON]");
server.on("/LedOFF", [](){
Serial.println("[OFF]");
server.begin();
Serial.println("HTTP server started");
void loop(void){
server.handleClient();
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
In file included from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266mDNS\src/LEAmDNS.h:109,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266mDNS\src/ESP8266mDNS.h:48,
from E:\ENGINEERING\DIY\Electronic\ARDUINO\mega2560_wifi\Arduino Mega Wifi\Program_blynk_ESP_Test\Program_blynk_ESP_Test.ino:4:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP8266WiFi\src/include/UdpContext.h: In member function 'bool UdpContext::sendTimeout(const ip_addr_t*, uint16_t, esp8266::polledTimeout::timeoutTemplate<false, esp8266::polledTimeout::YieldPolicy::DoNothing, esp8266::polledTimeout::TimePolicy::TimeUnit<esp8266::polledTimeout::TimePolicy::TimeSourceCycles, 1000> >::timeType)':
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP8266WiFi\src/include/UdpContext.h:414:13: error: 'esp_yield' was not declared in this scope
414 | esp_yield();
exit status 1
Error compiling for board LOLIN(WEMOS) D1 mini Pro.
option enabled in File -> Preferences.
