Hi all,
I have a weird problem with my wemos D1 mini. If i try to upload the blink code from the example everything works fine, but whenever i try to upload some other code i get the "Error compiling for board" message.
It does compile for the uno board. Just not for the wemos board
Any idea why this is?
Added the error message in a text file since it will exceed the 9000 caracters
here the code borrowed from the internet:
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include "U8glib.h"
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect SDA to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Adafruit_BMP085 bmp;
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send AC
//U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI
//U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST); // Fast I2C / TWI
//U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send AC
float pressure = 0.0;
float tempC = 0.0;
float altitude = 0.0;
void BmpSensorRead(float* pressure, float* tempC, float* altitude);
void DisplayPresTemp(float* pressure, float* tempC, float* altitude);
void setup(void)
// assign default color value
if (u8g.getMode() == U8G_MODE_R3G3B2)
u8g.setColorIndex(255); // white
else if (u8g.getMode() == U8G_MODE_GRAY2BIT)
u8g.setColorIndex(3); // max intensity
else if (u8g.getMode() == U8G_MODE_BW)
u8g.setColorIndex(1); // pixel on
else if (u8g.getMode() == U8G_MODE_HICOLOR)
u8g.setHiColorByRGB(255, 255, 255);
for (int a = 0; a < 30; a++)
u8g.firstPage();
do
u8g.setFont(u8g_font_fub11);
u8g.setFontRefHeightExtendedText();
u8g.setDefaultForegroundColor();
u8g.setFontPosTop();
u8g.drawStr(4, a, "MAKER . PRO ");
while (u8g.nextPage());
delay(3000);
if (!bmp.begin())
u8g.firstPage();
do
u8g.drawStr(4, 0, "BMP085 Sensor");
u8g.drawStr(4, 20, " ERROR!");
Serial.println("BMP085 sensor, ERROR!");
while (1) {}
void loop(void)
BmpSensorRead(&pressure, &tempC, &altitude);
DisplayPresTemp(&pressure, &tempC, &altitude);
u8g.firstPage();
do
u8g.drawStr(2, 0, "Pressure");
u8g.setPrintPos(75, 0);
u8g.print(*pressure);
u8g.drawStr(4, 20, "Temp C");
u8g.setPrintPos(75, 20);
u8g.print(*tempC);
u8g.drawStr(4, 40, "Altitude");
u8g.setPrintPos(75, 40);
u8g.print(*altitude);
*tempC = bmp.readTemperature();
Serial.print("Temperature = ");
Serial.print(*tempC);
Serial.println(" *C");
*pressure = bmp.readPressure() / 100.0;
Serial.print("Pressure = ");
Serial.print(*pressure / 100.0);
Serial.println(" hPa");
// Calculate altitude assuming 'standard' barometric
// pressure of 1013.25 millibar = 101325 Pascal
*altitude = bmp.readAltitude();
Serial.print("Altitude = ");
Serial.print(*altitude);
Serial.println(" meters");
However, it does not matter what code i use from the internet always the same error message
error.txt (624 KB)
