Revised accordingly
I'm fairly new at this, but every time I try to compile I get the following errors. It has to do with the libraries I believe, but I'm not exactly sure what I need to do to fix the problem. Any help would be appreciated. Also I know there have been other posts about this similar error, but it can be from many things for different people. So I figured it wouldn't hurt to post my particular error. Thanks everybody.
Library links
Error Messages & Code the Error Refers to
C:\Users\Admin\Documents\Arduino\Jig_Test_Program\Jig_Test_Program.ino: In function 'mixer_test()':
In file included from C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:19:0:
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:803:0: warning: "read8" redefined
#define read8(x) x=read8fn()
#ifdef read8isFunctionalized
#endif
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:183:0: note: this is the location of the previous definition
#define read8 read8inline
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::init()':
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::begin(uint16_t)':
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:401:21: warning: large integer implicitly truncated to unsigned type [-Woverflow]
hi = (d) >> 8; lo = (d); CD_DATA ; write8(hi); write8(lo); }
#define writeRegister16inline(a, d) { \
uint8_t hi, lo; \
hi = (a) >> 8; lo = (a); CD_COMMAND; write8(hi); write8(lo); \
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:187:29: note: in expansion of macro 'writeRegister16inline'
#define writeRegister16 writeRegister16inline
C:\Users\Admin\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:283:5: note: in expansion of macro 'writeRegister16'
writeRegister16(ILI9341_VCOMCONTROL1, 0x2B2B);
writeRegister8(ILI9341_POWERCONTROL1, 0x23);
writeRegister8(ILI9341_POWERCONTROL2, 0x10);
writeRegister8(ILI9341_VCOMCONTROL2, 0xC0);
writeRegister8(ILI9341_MEMCONTROL, ILI9341_MADCTL_MY | ILI9341_MADCTL_BGR);
writeRegister8(ILI9341_PIXELFORMAT, 0x55);
writeRegister16(ILI9341_FRAMECONTROL, 0x001B);
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
