Error compiling for board NodeMCU 1.0 (ESP-12E Module).
]Hello, I’m writting the code where i use the NODE MCU with ESP8266. When i try to compile it the message (in the subject) appear. There is my code under. I also copy the error message. I ask you for a help.
Arduino:1.8.12 (Windows 10), Plošča:“NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200”
In file included from C:\Users\alen\AppData\Local\Temp\arduino_modified_sketch_704537\sketch_may07c.ino:40:0:
C:\Users\alen\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.0\libraries\SPI/SPI.h:39:15: error: expected constructor, destructor, or type conversion before ‘SPI_MODE0’
const uint8_t SPI_MODE0 = 0x00; ///< CPOL: 0 CPHA: 0
C:\Users\alen\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.0\libraries\SPI/SPI.h: In constructor ‘SPISettings::SPISettings()’:
C:\Users\alen\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.0\libraries\SPI/SPI.h:46:66: error: ‘SPI_MODE0’ was not declared in this scope
SPISettings() :_clock(1000000), _bitOrder(LSBFIRST), _dataMode(SPI_MODE0){}
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
#include <Blynk.h>
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <SPI.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h>
#include <DHT.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth = “PjsrgvfMwwyxv_cFj-DYE3d76LVEZGLp”; //Enter the Auth code which was send by Blink
// Your WiFi credentials.
// Set password to “” for open networks.
char ssid = “T-2_67f9aa”; //Enter your WIFI Name
char pass = “INNBOX2842500605”; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
// Uncomment whatever type you’re using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
SimpleTimer timer;
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// You can send any value at any time.
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
Serial.begin(9600); // See the connection status in Serial Monitor
Blynk.begin(auth, ssid, pass);
dht.begin();
// Setup a function to be called every second
timer.setInterval(1000L, sendSensor);
Blynk.run(); // Initiates Blynk
timer.run(); // Initiates SimpleTimer
this is actually indicating an error the the SPI library file, SPI.h.
it could be due to the preceding include file. You might try swapping their order
