Hello every one, i have an issue uploading the sketch code from my arduino to ESP8266…
I'am a newbie and i want take data from the sensor and send it to the firebase but I have this error I’m not sure why is doesn’t work ?
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
c:/users/vienp/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\firebase-arduino-master\FirebaseArduino.cpp.o: in function `void std::__shared_ptr<FirebaseHttpClient, (__gnu_cxx::_Lock_policy)0>::reset(FirebaseHttpClient*)':
c:\users\vienp\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr_base.h:891: undefined reference to `FirebaseHttpClient::create()'
c:/users/vienp/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\firebase-arduino-master\FirebaseArduino.cpp.o:(.text._ZN15FirebaseArduino10initStreamEv+0x1d): undefined reference to `FirebaseHttpClient::create()'
c:/users/vienp/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\firebase-arduino-master\FirebaseArduino.cpp.o: in function `FirebaseArduino::stream(String const&)':
C:\Users\vienp\OneDrive\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.cpp:155: undefined reference to `FirebaseHttpClient::create()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
