What's wrong in this code ? Please help !
( I'm trying to make a wifi controlled car with Blynk App )
#define BLYNK_PRINT Serial
#define ENA 14 // Enable/speed motors Right GPIO14(D5)
#define ENB 12 // Enable/speed motors Left GPIO12(D6)
#define IN_1 15 // L298N in1 motors Right GPIO15(D8)
#define IN_2 13 // L298N in2 motors Right GPIO13(D7)
#define IN_3 2 // L298N in3 motors Left GPIO2(D4)
#define IN_4 0 // L298N in4 motors Left GPIO0(D3)
#include <Blynk.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
String command; //String to store app command state.
int speedCar = 165; // 93 - 255.
bool forward = 0;
bool backward = 0;
bool left = 0;
bool right = 0;
int Speed;
char auth[] = "2jY9xQ6QWcUxXWGqKlQ74EV-3HswBGiY"; //Enter your Blynk application auth token
char ssid[] = "PROJECT"; //Enter your WIFI name
char pass[] = "abcd4444"; //Enter your WIFI passowrd
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(IN_1, OUTPUT);
pinMode(IN_2, OUTPUT);
pinMode(IN_3, OUTPUT);
pinMode(IN_4, OUTPUT);
Blynk.begin(auth, ssid, pass);
BLYNK_WRITE(V0) {
forward = param.asInt();
BLYNK_WRITE(V1) {
backward = param.asInt();
BLYNK_WRITE(V2) {
left = param.asInt();
BLYNK_WRITE(V3) {
right = param.asInt();
BLYNK_WRITE(V4) {
Speed = param.asInt();
void smartcar() {
if (forward == 1) {
carforward();
Serial.println("carforward");
} else if (backward == 1) {
carbackward();
Serial.println("carbackward");
} else if (left == 1) {
carturnleft();
Serial.println("carfleft");
} else if (right == 1) {
carturnright();
Serial.println("carright");
} else if (forward == 0 && backward == 0 && left == 0 && right == 0) {
carStop();
Serial.println("carstop");
Blynk.run();
smartcar();
void goAhead(){
digitalWrite(IN_1, LOW);
digitalWrite(IN_2, LOW);
analogWrite(ENA, speedCar);
digitalWrite(IN_3, LOW);
digitalWrite(IN_4, HIGH);
analogWrite(ENB, speedCar);
void goBack(){
digitalWrite(IN_3, HIGH);
digitalWrite(IN_4, LOW);
void goRight(){
digitalWrite(IN_1, HIGH);
void goLeft(){
digitalWrite(IN_2, HIGH);
void goAheadRight(){
void goAheadLeft(){
void goBackRight(){
void goBackLeft(){
void stopRobot(){
Coppied error message -
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from G:\Documents\Arduino\libraries\Blynk\src/Blynk.h:14,
from G:\Documents\Arduino\sketch_aug22b\sketch_aug22b.ino:23:
G:\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
39 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
Multiple libraries were found for "Blynk.h"
Used: G:\Documents\Arduino\libraries\Blynk
Not used: G:\Documents\Arduino\libraries\blynk-library-master
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
