Hey,
I'm using the on/off button code for a adafruit 2.8 TFT screen(2.8 TFT Touch Shield for Arduino with Resistive Touch Screen : ID 1651 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits) and the code works fine but when I added a second button to the screen and a second bit of code to run if it is pushed I get an error (expected primary-expression before 'void') at the void double(); line of code in my second button.
I have looked around but it's hard to look for something when you don't know what to search for so if anyone can point me in the right direction I would appreciate it.
Here's the code
#include <Wire.h>
#include <Stepper.h>
Stepper myStepper1 = Stepper(200, 5, 6); //table slider pin 5 and 6
Stepper myStepper2 = Stepper(200, 3, 4); //substrate rotate pin 8 and 9
const int gluemac = 7; // pin to actuate glue machine relay
const int button = 2; // pin button is on
int val = 0; // current button state
int old_val = 0;
int state = 0;
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
boolean RecordOn = false;
#define FRAME_X 10
#define FRAME_Y 10
#define FRAME_W 50
#define FRAME_H 50
#define FRAME2_X 10
#define FRAME2_Y 70
#define FRAME2_W 50
#define FRAME2_H 50
#define SINGLEBUTTON_X FRAME_X
#define SINGLEBUTTON_Y FRAME_Y
#define SINGLEBUTTON_W FRAME_W
#define SINGLEBUTTON_H FRAME_H
#define SING2BUTTON_X FRAME_X
#define SING2BUTTON_Y FRAME_Y
#define SING2BUTTON_W FRAME_W
#define SING2BUTTON_H FRAME_H
#define DBL_X FRAME2_X
#define DBL_Y FRAME2_Y
#define DBL_W FRAME2_W
#define DBL_H FRAME2_H
#define DBL2_X FRAME2_X
#define DBL2_Y FRAME2_Y
#define DBL2_W FRAME2_W
#define DBL2_H FRAME2_H
void drawFrame()
tft.drawRect(FRAME_X, FRAME_Y, FRAME_W, FRAME_H, ILI9341_WHITE);
tft.drawRect(FRAME2_X, FRAME2_Y, FRAME2_W, FRAME2_H, ILI9341_WHITE);
void singleBtn()
tft.fillRect(SINGLEBUTTON_X, SINGLEBUTTON_Y, SINGLEBUTTON_W, SINGLEBUTTON_H, ILI9341_RED);
tft.fillRect(SING2BUTTON_X, SING2BUTTON_Y, SING2BUTTON_W, SING2BUTTON_H, ILI9341_GREEN);
drawFrame();
tft.setCursor(SING2BUTTON_X + 75 , SING2BUTTON_Y + (SING2BUTTON_H / 2));
tft.setTextColor(ILI9341_WHITE);
tft.setTextSize(2);
tft.println("1 INCH & BUTTON");
RecordOn = false;
void sing2Btn()
drawFrame();
tft.setCursor(SINGLEBUTTON_X + 75 , SINGLEBUTTON_Y + (SINGLEBUTTON_H / 2));
tft.setTextSize(2);
RecordOn = true;
void dblBtn()
tft.fillRect(DBL_X, DBL_Y, DBL_W, DBL_H, ILI9341_GREEN);
tft.fillRect(DBL2_X, DBL2_Y, DBL2_W, DBL2_H, ILI9341_RED);
drawFrame();
tft.setCursor(DBL2_X + 75 , DBL2_Y + (DBL2_H / 2));
tft.setTextSize(2);
tft.println("DOUBLE W/ BUTTON");
RecordOn = false;
void dbl2Btn()
drawFrame();
tft.setCursor(DBL_X + 75 , DBL_Y + (DBL_H / 2));
tft.setTextSize(2);
RecordOn = true;
void setup(void)
pinMode(button, INPUT_PULLUP);
pinMode(gluemac, OUTPUT);
digitalWrite(gluemac, HIGH); //relay is active low
myStepper1.setSpeed(3000); // table slide
myStepper2.setSpeed(300); //substrate rotate
tft.begin();
if (!ts.begin()) {
Serial.println("Unable to start touchscreen.");
else {
Serial.println("Touchscreen started.");
tft.fillScreen(ILI9341_BLACK);
// origin = left,top landscape (USB left upper)
tft.setRotation(1);
singleBtn();
dblBtn();
// See if there's any touch data for us
if (!ts.bufferEmpty())
// Retrieve a point
TS_Point p = ts.getPoint();
// Scale using the calibration #'s
// and rotate coordinate system
p.x = map(p.x, TS_MINY, TS_MAXY, 0, tft.height());
p.y = map(p.y, TS_MINX, TS_MAXX, 0, tft.width());
int y = tft.height() - p.x;
int x = p.y;
if (RecordOn)
if ((x > SINGLEBUTTON_X) && (x < (SINGLEBUTTON_X + SINGLEBUTTON_W))) {
if ((y > SINGLEBUTTON_Y) && (y <= (SINGLEBUTTON_Y + SINGLEBUTTON_H))) {
Serial.println("SINGLE ONe");
singleBtn();
single();
else //Record is off (RecordOn == false)
if ((x > SING2BUTTON_X) && (x < (SING2BUTTON_X + SING2BUTTON_W))) {
if ((y > SING2BUTTON_Y) && (y <= (SING2BUTTON_Y + SING2BUTTON_H))) {
delay(15);
Serial.println("SINGLE two");
sing2Btn();
if (RecordOn)
if ((x > DBL_X) && (x < (DBL_X + DBL_W))) {
if ((y > DBL_Y) && (y <= (DBL_Y + DBL_H))) {
delay(15);
Serial.println("DOUBLE ON");
dblBtn();
dblros();
if ((x > DBL2_X) && (x < (DBL2_X + DBL2_W))) {
if ((y > DBL2_Y) && (y <= (DBL2_Y + DBL2_H))) {
Serial.println("DOUBLE OFF");
dbl2Btn();
Serial.println(RecordOn);
void single()
val = digitalRead(button); //read input value and store it
if ((val == LOW) && (old_val == HIGH)) { //check if there was a transition
state = 1 - state;
delay(15); //button debounce
old_val = val; //store old value
if (state == 1) {
myStepper1.step(6000); //slide table in
Serial.println("clockwise");
delay(25);
digitalWrite(gluemac, LOW); //turn glue machine on
Serial.println("relay_on");
delay(300);
myStepper2.step(1600); //rotate 1 time
Serial.println("rotate");
digitalWrite(gluemac, HIGH); //turn glue off
Serial.println("relayoff");
myStepper1.step(-6000); // slide table out
Serial.println("counterclockwise");
state = 0; //turn everything off
void dblros()
state = 1 - state;
if (state == 1) {
delay(25);
delay(300);
myStepper1.step(6400); // slide table in
delay(25);
delay(300);
myStepper1.step(-6400); // slide table out
