Hey all,
Sorry to post such a simple thing. I've read, re-read, and re-read (about 10 times) and just can;t see where I'm going wrong. If you can, I'd owe you a million dollars if you help (after I build my first robot huge corporation).
Here's my error message:
sketch_apr12a.ino: In function 'void loop()':
sketch_apr12a.ino:45:2: error: 'esle' was not declared in this scope
sketch_apr12a.ino:45:7: error: expected ';' before 'if'
sketch_apr12a.ino:55:10: error: expected ';' before 'if'
Error compiling.
Here's my code:
const int sensorPin = A0;
const float baselineTemp = 20.0;
void setup (){
Serial.begin(9600); // open a serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
//convert the ADC reading to voltage
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print(" , Volts: ");
Serial.print(voltage);
Serial.print(", degrees C: ");
// convert the voltage to temperature in degrees
float temperature = (voltage - .5) * 100;
Serial.println(temperature);
if(temperature < baselineTemp)
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
else if(temperature >= baselineTemp+2 &&
temperature < baselineTemp+4)
digitalWrite(2, HIGH);
esle if (temperature >= baselineTemp+4 &&
temperature < baselineTemp+6)
digitalWrite(3, HIGH);
esle if (temperature >= baselineTemp+6)
digitalWrite(4, HIGH);
delay(1);
