Hi.
I find that Arduino ISP start compiling with the errors .
It's my old programs, it was compiled and work in real hardware projects. And it was after some times, while i don't use arduino projects, but i remark, that windows makes few updates and even changed from 8.1 to 10.
ANd i just try to start edit project, and it compile with error!
I think, that possible arduino board attaced don't correct?
And find, that it don't defined as "Duemilanove", but just as "com3" (before it define it on com7,
So, I try
-reboot
-detach and attach board - nothing happened.
So, I download the new arduino version -nightly.
It's don't need to install, if i understright, so, I just install AMD64 drivers (because when tryed to 486, it says that this is for 32bit)
it install OK, but when I start to compile the sample sketch (which is autoload after programs start)
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}", automatically converted to recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{preprocessed_file_path}". Consider upgrading this core.
would be fine if somebody knows, how to solve the problem?
P.S.
All other are works, for example - serial monitor find the board, and read the data and makes exchange with the board.
Thanks.
