Can’t get this library to compile can someone have alook?
#ifndef basic
#include "pins_arduino.h"
#include "wiring_private.h"
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/signal.h>
#include <avr/delay.h>
#include <stdio.h>
#include <stdarg.h>
byte masterTemp_A;
void initPins(boolean pinDirection, boolean pinState)
/*for(byte i; i < 14; i++)
pinMode(i, OUTPUT);
digitalWrite(i, LOW);
if(pinState)
//PORTA = 255;
PORTB = 255;
PORTC = 255;
PORTD = 255;
else {
//PORTA = 0;
PORTB = 0;
PORTC = 0;
PORTD = 0;
if(pinDirection)
//DDRA = 255;
DDRB = 255;
//DDRC = 255;
DDRD = 255;
else {
//DDRA = 0;
DDRB = 0;
//DDRC = 0;
DDRD = 0;
void serialEnd()
masterTemp_A = UCSR0B;
UCSR0B = UCSR0B & B00111111;
void serialRestart()
UCSR0B = masterTemp_A;
byte flipByte(byte toFlip)
byte flipRes = 0;
for(byte i = 0; i < 8; i++)
if((toFlip & (1 << i)))
flipRes = flipRes + (B10000000 >> i);
return flipRes;
byte int2bytes(unsigned int data, boolean mostSignificantBit)
byte output;
if(mostSignificantBit)
data = data & 0xFF00; // masks LSB
data = data >> 8;
else {
data = data & 0xFF; // masks MSB
output = data;
return output;
unsigned int bytes2int(byte data1, byte data2)
unsigned int output;
output = data1;
output = (output << 8) + data2;
return output;
byte analogReadByte(uint8_t pin)
uint8_t ch = analogInPinToBit(pin);
// the low 4 bits of ADMUX select the ADC channel
ADMUX = (ADMUX & (unsigned int) 0xF0) | (ch & (unsigned int) 0x0F);
// start the conversion
//sbi(ADCSRA, ADSC);
ADCSRA |= B01000000;
// ADSC is cleared when the conversion finishes
while (bit_is_set(ADCSRA, ADSC));
//byte temp = ADCL;
return ADCH;
void analogOff()
ADCSRA = ADCSRA & B01111111;
DDRC = 0xFF;
PORTC = 0;
byte serialWaitRead()
while(Serial.available() == 0);
return Serial.read();
byte trueRange(byte data, byte _min, byte _max)
data = constrain(data, _min, _max);
float _minF = _min;
float _maxF = _max;
float dataF = data - _min;
dataF = 255 * ((dataF) / (_maxF - _minF));
if(dataF < 0)
dataF = 0;
else if(dataF > 255)
dataF = 255;
data = dataF;
return data;
#define basic
#endif
