Error compiling message
Hi! This is my first attempt at coding and have no idea what the code I keep getting means. Any help is much appreciated.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Devon\AppData\Local\Temp\cc9WIrSj.ltrans0.ltrans.o: In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `setup'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Always show us your ‘current’ compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
#include <LiquidCrystal.h>
#include <EEPROM.h>
//*************** User defined variables **************************//
//pH meter Analog output to Arduino Analog Input 0
int PHPin = A5;
//The calibration constant for the PH probe
float K_PH=3.64;
//used for min/max logs
float MinPH=10;
float MaxPH=0;
//************** Some values for working out the ph*****************//
float Kn=0;
float phValue=0;
int i=0;
long reading=0;
unsigned long sum=0;
float average=0;
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key    = 0;
int adc_key_in  = 0;
int button =0;
#define btnRIGHT  1
#define btnUP    2
#define btnDOWN  3
#define btnLEFT  4
#define btnSELECT 5
#define btnRST  6
int Screen =1;
//Max number of screens on lcd
const int Last_Screen_no =4;
//used to debounce input button
int buttonLast=0;
//******************** Main Loops runs Forver ************************************//
//All these functions are put below the main loop, keeps the loop logic easy to see
read_LCD_buttons();
ReadPH();
CalibratePH();
PrintReadings();
delay(100);
//*************************Startup display **************************//
void startupinfo(){
Serial.println("pH Probe Script for Chemistry 114");
Serial.println("Dr. Windman's Class");
Serial.println("Devon von Lichtenstein");
Serial.println("How to Use:");
Serial.println("1:Place Probe into pH7 calibration fluid, open serial");
Serial.println("2:Take Recomened cell constant and change it in the top of code");
Serial.println("3:Rinse Probe and place in pH4 calibration fluid");
Serial.println("4:Adjust potentiometer on pH meter shield until ph reading in serial is 4");
Serial.println("    ");
Serial.println("That's it you're calibrated and your readings are accurate!");
//*************************Take Ten Readings And Average ****************************//
void ReadPH(){
  i=1;
  sum=0;
  while(i<=100){
  reading=analogRead(PHPin);
  sum=sum+reading;
    delay(20);
    i++;
average=sum/i;
//converting the average to PH 3.5 part convers mv to ph
phValue=average*K_PH*5/1024;
//****************************** Reading LCD Buttons ****************************//
void read_LCD_buttons(){
  adc_key_in = analogRead(0);      // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000)  button =0;
else if (adc_key_in < 50)   button =1;
else if (adc_key_in < 250)  button =2;
else if (adc_key_in < 450)  button =3;
else if (adc_key_in < 650)  button =4;
else if (adc_key_in < 850)  button =5;
//Second bit stops us changing screen multiple times per input
if(button==2&&buttonLast!=button){
Screen++;
else if (button==3&&buttonLast!=button){
Screen--;
if (Screen>=Last_Screen_no) Screen=Last_Screen_no;
if(Screen<=1) Screen=1;
buttonLast=button;
//************************** Just Some basic Definitions used for the Up Time LOgger ************//
long Day=0;
int Hour =0;
int Minute=0;
int Second=0;
int HighMillis=0;
int Rollover=0;
//***************** Specifying where to sotre the calibration value [non volatile memory **//
int value; //we use this to check if memory has been writen or not
int addresCalibrationPH=50;
//************************** Printing somthing useful to LCD on start up **************************//
void Splash_Screen(){
lcd.begin(16, 2);              // start the library
lcd.setCursor(0,0);
lcd.print("PH meter      ");
lcd.setCursor(0,1);
lcd.print("Devon von Lichtenstein");
  lcd.setCursor(0,0);
lcd.print("To Navigate        ");
  lcd.setCursor(0,1);
lcd.print("Use Up-Down    ");
delay(3000);
  lcd.setCursor(0,0);
lcd.print("To Calibrate      ");
  lcd.setCursor(0,1);
lcd.print("Hold Select      ");
delay(3000);
void Read_Eprom(){
//************** Restart Protection Stuff ********************//
  //the 254 bit checks that the adress has something stored to read [we dont want noise do we?]
  value = EEPROM.read(addresCalibrationPH);
  if (value <=254) K_PH=value*0.02;
//******************************* Checks if Select button is held down and enters Calibration routine if it is ************************************//
void CalibratePH(){
//we check if we are on ph screen and the select button is held
if(Screen!=4) return;
if(button!=5) return;
else delay(1000);
read_LCD_buttons();
//we need to stop in this loop while the user calibrates
while(1){
read_LCD_buttons();
lcd.setCursor(0,0);
lcd.print("Ph Probe in pH7  ");
lcd.setCursor(0,1);
lcd.print("Press Right            ");
//user pressed right?
if(button==1) break;
delay(100);
lcd.setCursor(0,0);
lcd.print("Calibrating              ");
lcd.setCursor(0,1);
lcd.print("pH Probe                ");
//let probe settle
delay(2000);
//read the ph probe
ReadPH();
Kn=((7*1024)/(average*5));
while (1) { // wee need to keep this function running until user opts out with return function
  read_LCD_buttons();
  if(button==4) return; //exits the loop without saving becauser user asked so
  if (button==5){
  K_PH=Kn; //saving the new cell constant
  //*******Saving the new value to EEprom**********//
  value=Kn/0.02;
  EEPROM.write(addresCalibrationPH, value);
  lcd.setCursor(0,0);
  lcd.print("Saved Calibration        ");
  lcd.setCursor(0,1);
  lcd.print("K:                        ");
  lcd.setCursor(3,1);
  lcd.print(Kn);
  delay(2000);
  lcd.setCursor(0,0);
  lcd.print("Now pH4 and          ");
  lcd.setCursor(0,1);
  lcd.print("Adjust Pot                      ");
  delay(4000);
  //Put back to main screen and exit calibration
    Screen=1;
  return;
if(millis()%4000>=2000){
      ReadPH();
    lcd.setCursor(0,0);
    lcd.print("Calibrated        ");
      lcd.setCursor(0,1);
      lcd.print("PH:                      ");
      lcd.setCursor(3,1);
      lcd.print(phValue);
else{
      lcd.setCursor(0,0);
      lcd.print("Select To Save      ");
      lcd.setCursor(0,1);
      lcd.print("Down to Exit          ");
//******************************* LOGS Min/MAX Values*******************************//
                          void Log_Min_MaxPH(){
                            if(phValue>=MaxPH) MaxPH=phValue;
                            if(phValue<=MinPH) MinPH=phValue;
void PrintReadings(){
                Serial.print("pH: ");
                Serial.print(phValue);
//** First Screen Shows pH **//
if(Screen==1){
lcd.setCursor(0,0);
lcd.print("Arduino pH  ");
lcd.setCursor(0,1);
lcd.print("pH:              ");
lcd.setCursor(3,1);
lcd.print(phValue);
//**Second Screen Shows Min and Max **//
else if(Screen==2){
lcd.setCursor(0,0);
lcd.print("Min:              ");
lcd.setCursor(4,0);
lcd.print(MinPH);
lcd.setCursor(0,1);
lcd.print("Max:              ");
lcd.setCursor(4,1);
lcd.print(MaxPH);
lcd.setCursor(9,1);
else if(Screen==3){
lcd.setCursor(0,0);
lcd.print("Uptime Counter:              ");
lcd.setCursor(0,1);
lcd.print("                                    ");//Clearing LCD
lcd.setCursor(0,1);
lcd.print(Day);
lcd.setCursor(3,1);
lcd.print("Day");
lcd.setCursor(8,1);
lcd.print(Hour);
lcd.setCursor(10,1);
lcd.print(":");
lcd.setCursor(11,1);
lcd.print(Minute);
lcd.setCursor(13,1);
lcd.print(":");
lcd.setCursor(14,1);
lcd.print(Second);
else if(Screen==4){
lcd.setCursor(0,0);
lcd.print("Calibrate pH          ");
lcd.setCursor(0,1);
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool. I recommend you to use the standard IDE instead.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we're trying to read your code.
Every Arduino sketch must contain a setup() and loop() function, even if they are left empty.
Thank you for the tips on posting and for the simple, yet easily overlooked mistake!
