Error Compiling Sketch Mp3PlayerShield VS1053B SdFatUtil.h
Hello there, I am trying to get my mp3shield up and running again. It have worked before on another computer for about a year ago. But now i get these strange errors trying to compile them.
The Code i am using is :
  MP3 Shield Trigger
  by: Jim Lindblom
      SparkFun Electronics
  date: September 23, 2013
  This is an example MP3 trigger sketch for the SparkFun MP3 Shield.
  Pins 0, 1, 5, 10, A0, A1, A2, A3, and A4 are setup to trigger tracks
  "track001.mp3", "track002.mp3", etc. on an SD card loaded into
  the shield. Whenever any of those pins are shorted to ground,
  their respective track will start playing.
  When a new pin is triggered, any track currently playing will
  stop, and the new one will start.
  A5 is setup to globally STOP playing a track when triggered.
  If you need more triggers, the shield's jumpers on pins 3 and 4
  (MIDI-IN and GPIO1) can be cut open and used as additional
  trigger pins. Also, because pins 0 and 1 are used as triggers
  Serial is not available for debugging. Disable those as
  triggers if you want to use serial.
  Much of this code was grabbed from the FilePlayer example
  included with the SFEMP3Shield library. Major thanks to Bill
  Porter and Michael Flaga, again, for this amazing library!
#include <SPI.h>           // SPI library
#include <SdFat.h>         // SDFat Library
#include <SdFatUtil.h>     // SDFat Util Library
#include <SFEMP3Shield.h>  // Mp3 Shield Library
SdFat sd; // Create object to handle SD functions
SFEMP3Shield MP3player; // Create Mp3 library object
// These variables are used in the MP3 initialization to set up
// some stereo options:
const uint8_t volume = 0; // MP3 Player volume 0=max, 255=lowest (off)
const uint16_t monoMode = 1;  // Mono setting 0=off, 3=max
/* Pin setup */
#define TRIGGER_COUNT 9
int triggerPins[TRIGGER_COUNT] = {0, 1, 5, 10, A0, A1, A2, A3, A4};
int stopPin = A5; // This pin triggers a track stop.
int lastTrigger = 0; // This variable keeps track of which tune is playing
  /* Set up all trigger pins as inputs, with pull-ups activated: */
  for (int i=0; i<TRIGGER_COUNT; i++)
    pinMode(triggerPins[i], INPUT_PULLUP);
  pinMode(stopPin, INPUT_PULLUP);
  initSD();  // Initialize the SD card
  initMP3Player(); // Initialize the MP3 Shield
// All the loop does is continuously step through the trigger
//  pins to see if one is pulled low. If it is, it'll stop any
//  currently playing track, and start playing a new one.
    if ((digitalRead(triggerPins[i]) == LOW) && ((i+1) != lastTrigger))
      lastTrigger = i+1; // Update lastTrigger variable to current trigger
      /* If another track is playing, stop it: */
      if (MP3player.isPlaying())
        MP3player.stopTrack();
      /* Use the playTrack function to play a numbered track: */
      uint8_t result = MP3player.playTrack(lastTrigger);
      // An alternative here would be to use the
      //  playMP3(fileName) function, as long as you mapped
      //  the file names to trigger pins.
      if (result == 0)  // playTrack() returns 0 on success
        // Success
      else // Otherwise there's an error, check the code
        // Print error code somehow, someway
  // After looping through and checking trigger pins, check to
  //  see if the stopPin (A5) is triggered.
  if (digitalRead(stopPin) == LOW)
    lastTrigger = 0; // Reset lastTrigger
    // If another track is playing, stop it.
// initSD() initializes the SD card and checks for an error.
void initSD()
  //Initialize the SdCard.
  if(!sd.begin(SD_SEL, SPI_HALF_SPEED))
    sd.initErrorHalt();
  if(!sd.chdir("/"))
    sd.errorHalt("sd.chdir");
// initMP3Player() sets up all of the initialization for the
// MP3 Player Shield. It runs the begin() function, checks
// for errors, applies a patch if found, and sets the volume/
// stero mode.
void initMP3Player()
  uint8_t result = MP3player.begin(); // init the mp3 player shield
  if(result != 0) // check result, see readme for error codes.
    // Error checking can go here!
  MP3player.setVolume(volume, volume);
  MP3player.setMonoMode(monoMode);
When i use that one i get this error:
C:\Users\Sondre\Documents\Arduino\soundcode111\soundcode111.ino:31:49: fatal error: SdFatUtil.h: No such file or directory
compilation terminated.
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library SdFat at version 1.0.3 in folder: C:\Users\Sondre\Documents\Arduino\libraries\SdFat
exit status 1
Error compiling for board Arduino/Genuino Uno.
have been trying to just remove the #include <SdFatUtil.h> // SDFat Util Library but
when i use that code i get the error message :
C:\Users\Sondre\AppData\Local\Temp\arduino_build_845241\sketch\src\SdCard\SdioCardEX.cpp.o (symbol from plugin):(.text+0x0): first defined here
C:\Users\Sondre\AppData\Local\Temp\arduino_build_845241\libraries\SdFat\SdCard\SdioCardEX.cpp.o (symbol from plugin): In function `SdioCardEX::readBlock(unsigned long, unsigned char*)':
(.text+0x0): multiple definition of `SdioCardEX::writeBlock(unsigned long, unsigned char const*)'
(.text+0x0): multiple definition of `SdioCardEX::readBlocks(unsigned long, unsigned char*, unsigned int)'
(.text+0x0): multiple definition of `SdioCardEX::writeBlocks(unsigned long, unsigned char const*, unsigned int)'
collect2.exe: error: ld returned 1 exit status
Using library SFEMP3Shield in folder: C:\Users\Sondre\Documents\Arduino\libraries\SFEMP3Shield (legacy)
exit status 1
(needed to remove some of the red stuff here because of the length)
What is wrong? And how can i fix this?
Thanks for the help fellow Arduino users !
Sondre
The clue is here:
Use the library manager to install the SD card library.
But i have SdFat installed? It also says that in the Error message down here ?`
Then I guess you need this: SD/SdFatUtil.h at master · adafruit/SD · GitHub
and then probably one or more from here: SD/utility at master · adafruit/SD · GitHub
Thanks for the Answer 6v6gt. I tried to install the SdFat library you gave me there, Then it didnt find the SdFat library at all.. Then i tried to download the 1.0.3 Version of the SD fat again and put the Utility folder from the one you gave there into the SdFat folder in C:\Users\Sondre\Documents\Arduino\libraries\SdFat . Now it still says i need the SdFatUtil.h :confused:
Anyone have any clue what to do here?
Okey! FINALY did it after hours and hours!
for users that have the same problem, go into
Its an older SDfat library with the SdFatUtil.H included! Now it compiles!
Finaly!
