I just got the latest version of TFT_eSPI from Github, very carefullly read everything, by good chance have the exact same ESP32 board as in the readme so did the solder mods.
Changed User_Setup.h, and have edited User_Setup_Select.h (to point to either User_Setup.h or User_Setups/Setup14_ILI9341_Parallel.h)
Arduino IDE v 1.8.13
trying to compile Read_User_Setup get the following error
"D:\XX\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp" -o "D:\TEMP\arduino_build_278695\libraries\TFT_eSPI\TFT_eSPI.cpp.o"
D:\XX\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::end_tft_write()':
D:\XX\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:87:23: error: 'SPI_BUSY_CHECK' was not declared in this scope
if(!inTransaction) {SPI_BUSY_CHECK; CS_H; SET_BUS_READ_MODE;}
Not sure what I've stuffed up...
User_Setup.h (15.6 KB)
User_Setup_Select.h (10.7 KB)
