Error compiling with Adafruit_L3GD20_U-master libary
whenever I try to compile the following example from the Adafruit_L3GD20_U-master library I get the message “exit status 1
Error compiling for board Arduino/Genuino Uno.” What do I do?
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_L3GD20_U.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_L3GD20_Unified gyro = Adafruit_L3GD20_Unified(20);
void displaySensorDetails(void)
sensor_t sensor;
gyro.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print (“Driver Ver: “); Serial.println(sensor.version);
Serial.print (“Unique ID: “); Serial.println(sensor.sensor_id);
Serial.print (“Max Value: “); Serial.print(sensor.max_value); Serial.println(” rad/s”);
Serial.print (“Min Value: “); Serial.print(sensor.min_value); Serial.println(” rad/s”);
Serial.print (“Resolution: “); Serial.print(sensor.resolution); Serial.println(” rad/s”);
Serial.println(”------------------------------------”);
Serial.println(””);
void setup(void)
Serial.println(“Gyroscope Test”); Serial.println("");
/* Enable auto-ranging */
gyro.enableAutoRange(true);
/* Initialise the sensor /
if(!gyro.begin())
There was a problem detecting the L3GD20 … check your connections */
Serial.println(“Ooops, no L3GD20 detected … Check your wiring!”);
while(1);
/* Display some basic information on this sensor */
displaySensorDetails();
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
gyro.getEvent(&event);
/* Display the results (speed is measured in rad/s) */
Serial.print("X: “); Serial.print(event.gyro.x); Serial.print(” ");
Serial.print("Y: “); Serial.print(event.gyro.y); Serial.print(” ");
Serial.print("Z: “); Serial.print(event.gyro.z); Serial.print(” ");
Serial.println("rad/s ");
It is unlikely that "exit status 1" is the ONLY message.
Post links to the non-standard libraries that you are using.
I was using this library: GitHub - adafruit/Adafruit_L3GD20_U: Unified sensor driver for the L3GD20 Gyroscope
but now I’m using this library: GitHub - adafruit/Adafruit_L3GD20: Driver for Adafruit's L3GD20 I2C Gyroscope Breakout
And it seems to work for now.
