Uncomment the MPU6050.h include. The include may not be necessary from a C compiler standpoint but the IDE magic to get the necessary libraries for the linker may need it.
Thanks for your answer sir but it is still showing an error message its different than the previous one
ERROR MESSAGE-
Arduino: 1.8.5 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (3M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 9600"
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'float Quaternion::getMagnitude()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:74:46: error: 'sqrt' was not declared in this scope
return sqrt(w*w + x*x + y*y + z*z);
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: At global scope:
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:94:9: error: 'int16_t' does not name a type
int16_t x;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:95:9: error: 'int16_t' does not name a type
int16_t y;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:96:9: error: 'int16_t' does not name a type
int16_t z;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:104:29: error: expected ')' before 'nx'
VectorInt16(int16_t nx, int16_t ny, int16_t nz) {
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In constructor 'VectorInt16::VectorInt16()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:99:13: error: 'x' was not declared in this scope
x = 0;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:100:13: error: 'y' was not declared in this scope
y = 0;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:101:13: error: 'z' was not declared in this scope
z = 0;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'float VectorInt16::getMagnitude()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:111:25: error: 'x' was not declared in this scope
return sqrt(x*x + y*y + z*z);
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:111:31: error: 'y' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:111:37: error: 'z' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:111:40: error: 'sqrt' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'void VectorInt16::normalize()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:116:13: error: 'x' was not declared in this scope
x /= m;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:117:13: error: 'y' was not declared in this scope
y /= m;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:118:13: error: 'z' was not declared in this scope
z /= m;
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'VectorInt16 VectorInt16::getNormalized()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:122:27: error: 'x' was not declared in this scope
VectorInt16 r(x, y, z);
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:122:30: error: 'y' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:122:33: error: 'z' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'void VectorInt16::rotate(Quaternion*)':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:138:29: error: 'x' was not declared in this scope
Quaternion p(0, x, y, z);
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:138:32: error: 'y' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:138:35: error: 'z' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'VectorInt16 VectorInt16::getRotated(Quaternion*)':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:153:27: error: 'x' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:153:30: error: 'y' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:153:33: error: 'z' was not declared in this scope
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp: In member function 'float VectorFloat::getMagnitude()':
C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050\helper_3dmath.h.cpp:178:40: error: 'sqrt' was not declared in this scope
Multiple libraries were found for "Wire.h"
Used: C:\Users\JOBIN JESSI\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\Wire
Not used: C:\Users\JOBIN JESSI\Documents\Arduino\libraries\MPU6050
Multiple libraries were found for "EEPROM.h"
Used: C:\Users\JOBIN JESSI\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\EEPROM
Not used: C:\Users\JOBIN JESSI\Documents\Arduino\libraries\arduino-NVM
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Invalid library found in C:\Users\JOBIN JESSI\Documents\Arduino\libraries\Arduino-PID-Library-master: C:\Users\JOBIN JESSI\Documents\Arduino\libraries\Arduino-PID-Library-master
option enabled in File -> Preferences.
My library manager doesn't offer an "MPU6050" library for installation, the only match I have is for MPU6050_tockn but that doesn't include a Wire.h file. It seems that you produced a mess in your library folder.
