I'm quite new to coding and Arduino so I apologize beforehand if I have any trouble understanding. I just wanted some assistance as to why my code won't compile.
Arduino: 1.8.15 (Windows 10), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\nz450\OneDrive\Documents\Arduino\adafruitio_15_temp_humidity\adafruitio_15_temp_humidity.ino:7:
C:\Users\nz450\OneDrive\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO_FONA.h:75:16: error: extra qualification 'AdafruitIO_FONA::' on member 'networkStatus' [-fpermissive]
75 | aio_status_t AdafruitIO_FONA::networkStatus() {
Multiple libraries were found for "Dhcp.h"
Used: C:\Users\nz450\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Ethernet
Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
option enabled in File -> Preferences.
It certainly looks like a strange line of code to me, but I was not able to reproduce the error. Have you made any modifications to the ESP8266 boards platform, Adafruit IO Arduino library, or adafruitio_15_temp_humidity example sketch?
To my knowledge, I have not made any changes to the library and the only changes to the humidity sketch would be the necessary edits (such as the Wifi name/password as well as the Adafruit keys). The only difference is that I have moved my data pin to 12 instead of 2 as shown on the website I sent.
Looks like the problem is in a library. Maybe a version conflict?
I would check Tools->Board:->Boards manager... to see if there is an update for the ESP8266 boards and check Tools->Manage Libraries... to see if there is an update for the Adafruit_IO_Arduino library.
Notice that networkStatus() is being defined inline in the AdafruitIO_FONA class. From my understanding, this makes the AdafruitIO_FONA:: scoping prefix on the function signature superfluous at the very least.
