I'm setting up a project with the RTC library and just wanted to test some things out on my Arduino Uno. I have just some very simple test code below, but when I try to compile it gives me "exit status 1 Error compiling for board Arduino Uno". My rtclib folder is saved into Documents>Arduino>libraries and I've confirmed that my board and port are both correct, so I'm not sure what I'm missing here.
Below is my full code:
#include <RTClib.h>
#include <Wire.h>
RTC_DS1307 rtc;
if(! rtc.begin()){
Serial.println("Couldnt find RTC");
while(1);
if(! rtc.isrunning()){
Serial.println("RTC is NOT running!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.hour(), DEC);
Serial.print('/');
Serial.print(now.minute(), DEC);
And the error I'm getting is:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Xiaow\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path C:\Users\Xiaow\AppData\Local\Temp\arduino_build_720476 -warnings=none -build-cache C:\Users\Xiaow\AppData\Local\Temp\arduino_cache_978852 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Arduino\rtc_testing\rtc_testing.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Xiaow\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path C:\Users\Xiaow\AppData\Local\Temp\arduino_build_720476 -warnings=none -build-cache C:\Users\Xiaow\AppData\Local\Temp\arduino_cache_978852 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Arduino\rtc_testing\rtc_testing.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Xiaow\\AppData\\Local\\Temp\\arduino_build_720476\\sketch\\rtc_testing.ino.cpp" -o nul
Alternatives for RTClib.h: [RTClib-2.0.3@2.0.3]
ResolveLibrary(RTClib.h)
-> candidates: [RTClib-2.0.3@2.0.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Xiaow\\Documents\\Arduino\\libraries\\RTClib-2.0.3\\src" "C:\\Users\\Xiaow\\AppData\\Local\\Temp\\arduino_build_720476\\sketch\\rtc_testing.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: []
ResolveLibrary(Adafruit_I2CDevice.h)
In file included from C:\Arduino\rtc_testing\rtc_testing.ino:1:0:
-> candidates: []
C:\Users\Xiaow\Documents\Arduino\libraries\RTClib-2.0.3\src/RTClib.h:25:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
#include <Adafruit_I2CDevice.h>
compilation terminated.
Using library RTClib-2.0.3 at version 2.0.3 in folder: C:\Users\Xiaow\Documents\Arduino\libraries\RTClib-2.0.3
exit status 1
Error compiling for board Arduino Uno.
Any help would be much aprreciated!
