hey guys! just need from anyone who can help..
i am compiling this code when it comes with this kind of error;
#include <NewSoftSerial.h> //Software Serial Port
#define RxD 2
#define TxD 3
NewSoftSerial blueToothSerial(RxD,TxD);
Serial.begin(9600); //Serial port for debugging, Comment this line if not required
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
if(blueToothSerial.read() == 'a')
blueToothSerial.println("You are connected to Bluetooth Bee");
//You can write you BT communication logic here
void setupBlueToothConnection()
Serial.print("Setting up Bluetooth link"); //For debugging, Comment this line if not required
blueToothSerial.begin(9600); //Set BluetoothBee BaudRate to default baud rate 38400
sendBlueToothCommand("\r\n+STWMOD=0\r\n");
sendBlueToothCommand("\r\n+STNA=modem\r\n");
sendBlueToothCommand("\r\n+STAUTO=0\r\n");
sendBlueToothCommand("\r\n+STOAUT=1\r\n");
sendBlueToothCommand("\r\n+STPIN=0000\r\n");
delay(2000); // This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n");
Serial.print("Setup complete");
void sendBlueToothCommand(char command[])
char a;
blueToothSerial.print(command);
Serial.print(command); //For debugging, Comment this line if not required
while(blueToothSerial.available()) //For debugging, Comment this line if not required
{ //For debugging, Comment this line if not required
Serial.print(char(blueToothSerial.read())); //For debugging, Comment this line if not required
} //For debugging, Comment this line if not required
ERROR COMPILING:
In file included from code2.cpp:1:
D:\shielarose's personal files\installers\Installers\arduino-1.0.1\libraries\NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
D:\shielarose's personal files\installers\Installers\arduino-1.0.1\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
what must be the possible answer for this error? can anyone help me please.. thanks!
