Error compiling
i am relativly new to c++ and ardunio so this is tricky for me
i wrote a sketch to control a motor with a IR controller but got this error code -
robot_test.ino:33:37: error: invalid suffix “DA0” on floating constant
i don’t know what it means and i would appreciate any information about a fix anyone has
thanks
My sketch:
#include <IRremote.h>
#include <AFMotor.h>
AF_DCMotor motor(4);
int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
if ((irrecv.decode(&results)) = 5E419DA0);
motor.run(FORWARD);
sigh, please use [ code] and [ / code]
0x5E419DA0
if( something() == constant)
sorry but i dont realy know what you mean by that pls talk me though it thanks
A hex constant is prefixed "0x", and a comparison operator is "==", not "="
Code tags make your code look like this//your code here
5E419DA0
The compiler sees this as a float constant 5x10419, with an unrecognized suffix “DA0”, hence the message.
Should read 0x5E419DA0, and the “=” should be “==”
i have made the alterations that you suggested and it now compilies :slight_smile:
but now when i run the code the controller still sends the receiver 5E419DA0 and this is printed in the serial monitor. this is what i wanted
but now i wish for the signal from the controller to run the motor which is what i have tried to do but it will not run the motor
any suggestions on how to change the code to do that because im a bit stuck now
thanks
int RECV_PIN = 2;
    if (irrecv.decode(&results) == 0x5E419DA0);
       motor.run(FORWARD);
Ever seen any of the examples of an “if” written like that?
