Error Compiling
Electronic_Die.ino:11:1: error: expected unqualified-id before ‘{’ token
Error compiling.
Can some one please try to fix this because i don’t know what the error means
Thx
randomSeed(analogRead(0)); // seed the random number generator
for ( int z = 1 ; z < 7 ; z++ ) // LEDs on pins 1-6 are output
pinMode(z, OUTPUT);
void randomLED(int del);
int r; // get a random number from 1-6
digitalWrite(r, HIGH); // output to the matching LED on digital pin 1-6
if (del > 0);
delay(del); // hold the LED on for the delay received
else if (del == 0);
do // the delay entered was zero, hold the LED on
forever
while (1);
digitalWrite(r, LOW); // turn the LED off
int a;
// cycle the LEDs around for effect
for ( a = 0 ; a < 100 ; a++ )
randomLED(50);
// slow down
for ( a = 1 ; a <= 10 ; a++)
randomLED( a * 100);
// and stop at the final random number and LED
randomLED(0);
Electronic_Die.ino (927 Bytes)
 if (del > 0);
The semicolon ( ; ) after your if statement should be removed.
Same...check all your code because you have more of those issues
WonderTiger:
 if (del > 0);
The semicolon (;) after your if statement should be removed.
thx :stuck_out_tongue:
HafsaEN:
Try this one :
    pinMode(z, OUTPUT);
  if (del > 0)
    else if (del == 0)
    while (1);
  int a;
    randomLED(50);
  // slow down
  randomLED(0);
but what do you want to mean by this line :
I’m going off by what the Arduino workshop book said
and thx for the code it worked
