Error compiling
When trying to verify my code, I get an error compiling. In case if it was my code, I try doing the same to multiple "example" codes and I get the same error. Help please :cry:
The error is
Serial.ino.cpp" -o ""
avr-g++: error: missing filename after '-o'
exit status 1
Error compiling.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\City\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\City\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\City\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10606 -build-path "C:\Users\City\AppData\Local\Temp\build4a3e16cb7b4b7b1bca46ceab157a4c8f.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\03.Analog\AnalogInOutSerial\AnalogInOutSerial.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\City\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\City\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\City\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10606 -build-path "C:\Users\City\AppData\Local\Temp\build4a3e16cb7b4b7b1bca46ceab157a4c8f.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\03.Analog\AnalogInOutSerial\AnalogInOutSerial.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -M -MG -MP -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\City\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\cores\arduino" "-IC:\Users\City\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\variants\standard" "C:\Users\City\AppData\Local\Temp\build4a3e16cb7b4b7b1bca46ceab157a4c8f.tmp\sketch\AnalogInOutSerial.ino.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\City\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\cores\arduino" "-IC:\Users\City\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\variants\standard" "C:\Users\City\AppData\Local\Temp\build4a3e16cb7b4b7b1bca46ceab157a4c8f.tmp\sketch\AnalogInOutSerial.ino.cpp" -o ""
exit status 1
Error compiling.
The problem is caused by using Arduino AVR Boards 1.6.10 with Arduino IDE 1.6.6, they are incompatible. The options to fix this are:
  • Use Arduino IDE 1.6.7 or 1.6.8
  • Install Arduino AVR Boards 1.6.9 by: Tools > Board > Boards Manager... > Arduino AVR Boards(click on it) > Select version > 1.6.9 > Install. You will continue to get updatable notifications for the incompatible Arduino AVR Boards version so you might want to File > Preferences > Check for updates on startup(uncheck) to disable this notification.
