Error compiling
When we tried to compile our code,and a message saying "exit status 1
Error compiling." appears. What to do? Thanks.
here's our code
 * TimeAlarmExample.pde
 * This example calls alarm functions at 8:30 am and at 5:45 pm (17:45)
 * and simulates turning lights on at night and off in the morning
 * A weekly timer is set  for Saturdays at 8:30:30
 * A timer is called every 15 seconds
 * Another timer is called once only after 10 seconds
 * At startup the time is set to Jan 1 2011  8:29 am
// Questions?  Ask them here:
// http://forum.arduino.cc/index.php?topic=66054.0
#include "Time.h"
#include "TimeLib.h"
#include "TimeAlarms.h"
#include <Wire.h>
#include <LiquidCrystal.h>
#include "Bounce2.h"
#define buttonIncrease 2 // general purpose increase for alarm set, time set
#define buttonDecrease 3 // general purpose decrease for alarm set, time set
#define buttonOK 8
#define alarmSpeaker 9
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
int Menuposition = 0;
int mathValOne = 0;
int mathValTwo = 0;
int mathValThree = 0;
int inputAnswer = 100;
int realAnswer = 0;
int toneOn = 0;
long previousMillis = 0;
int x = 0;
long interval = 70;
long interval2 = 500;
int debounceIncrease;
int debounceDecrease;
Bounce increase = Bounce();
Bounce decrease = Bounce();
Bounce OK = Bounce();
void Alaarm() {
  Menuposition == 1;
void alarmNoiseOn(){
  if(currentMillis - previousMillis > interval && x < 8) {
    if (toneOn == 0) {
      toneOn = 2048;
      toneOn = 0;
    tone(9, toneOn);
    if(toneOn == 0)
      noTone(9);
    x++;
  if(currentMillis - previousMillis > interval2 && x == 8) {
    noTone(9);
    x = 0;
  lcd.begin(16, 2);
  setTime(20,34,0,10,07,16); // set time to Saturday 8:29:00am Jan 1 2011
  // create the alarms, to trigger at specific times
  Alarm.alarmRepeat(20,35,0, Alaarm);  // 8:30am every day
  //Alarm.alarmRepeat(17,45,0,EveningAlarm);  // 5:45pm every day
  //Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm);  // 8:30:30 every Saturday
  // create timers, to trigger relative to when they're created
  // Alarm.timerRepeat(15, Repeats);           // timer for every 15 seconds
  //id = Alarm.timerRepeat(2, Repeats2);      // timer for every 2 seconds
  //Alarm.timerOnce(10, OnceOnly);            // called once after 10 seconds
  Wire.begin();
pinMode(buttonIncrease, INPUT);
pinMode(buttonDecrease, INPUT);
pinMode(buttonOK, INPUT);
increase .attach(buttonIncrease);
increase .interval(10);
decrease .attach(buttonDecrease);
decrease .interval(10);
OK .attach(buttonOK);
OK .interval(10);
pinMode(alarmSpeaker, OUTPUT);
randomSeed(analogRead(2));
void Clock() {
  // digital clock display of the time
  lcd.print(hour());
  printDigits(minute());
  printDigits(second());
  lcd.println("     ");
void printDigits(int digits) {
  lcd.print(":");
  if (digits < 10)
    lcd.print('0');
  lcd.print(digits);
lcd.noDisplay();
lcd.display();
while (Menuposition == 0) {
  lcd.setCursor(0, 0);
  Clock();
  Alarm.delay(1000); // wait one second between clock display
  // Turn off the display:
  lcd.noDisplay();
  // Turn on the display:
  lcd.display();
while(Menuposition == 1) {
    lcd.noDisplay();
    lcd.display();
    alarmNoiseOn();
    increase.update();
    decrease.update();
    int debounceIncrease = increase.read();
    int debounceDecrease = decrease.read();
    mathValOne = random(11, 15);
    mathValTwo = random(9, 15);
    mathValThree = random(20, 150);
    inputAnswer = (mathValOne * mathValTwo + mathValThree) - random(5, 10);
    realAnswer = mathValOne * mathValTwo + mathValThree;
    lcd.print(" Hello!"); // wakeup message
    lcd.setCursor(0, 1);
    lcd.print(mathValOne);
    lcd.print("*");
    lcd.print(mathValTwo);
    lcd.print("+");
    lcd.print(mathValThree);
    lcd.print(" = ");
    lcd.print(inputAnswer);
    lcd.print(" ?");
    delay(100);
    if(debounceIncrease == HIGH) {
      inputAnswer++;
    if(debounceDecrease == HIGH) {
      inputAnswer--;
    if(digitalRead(buttonOK) == HIGH && inputAnswer != realAnswer) {
      mathValOne = random(1, 10);
      mathValTwo = random(1, 10);
      mathValThree = random(1, 20);
    if(digitalRead(buttonOK) == HIGH && inputAnswer == realAnswer) {
      noTone(9);
      lcd.noDisplay();
      lcd.print(" Good Morning!");
      delay(5000);
      Menuposition = 0;
      mathValOne = 0;
      mathValTwo = 0;
      mathValThree = 0;
Post your code and provide more of the error message.
jajajaoda:
In menu File -> Preferences set verbose output during compile to get ALL error messages.
The "exit status 1" is just an end note saying you got "trouble in River City. "
Jim
Board arduino:avr:atmega8_diy_atmega8a_8MHz_bootloader doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA8_DIY_ATMEGA8A_8MHZ_BOOTLOADER
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: C:\Users\JOHNCA~1\AppData\Local\Temp\build7f52d528909c94f862269fab97a3bbd9.tmp/jajaja.ino.elf section .text' will not fit in region text'
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: region `text' overflowed by 1206 bytes
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling.
Re-read reply #1 and post EVERYTHING asked for there.
It appears, though, that you are trying to stuff 5 pounds of crap in a 1 pound sack.
