Error compiling
hello
when I compile this code it,s show me Error comiling for board
/* luckylarry.co.uk Radar Screen Visualisation for Sharp GP2Y0A02 IR range finder Sends sensor readings for every degree moved by the servo values sent to serial port to be picked up by Processing */ #include // include the standard servo library
Servo leftRightServo; // set a variable to map the servo
int leftRightPos = 0; // set a variable to store the servo position
const int numReadings = 10; // set a variable for the number of readings to take
int index = 0; // the index of the current reading
float total = 0; // the total of all readings must be a float to allow totaling of float values
int average = 0; // the average
int IRpin = 1; // analog pin for reading the IR sensor
/* setup the pins, servo and serial port */
leftRightServo.attach(9);
// initialize the serial port:
/* begin rotating the servo and getting sensor values */
for(leftRightPos = 0; leftRightPos < 180; leftRightPos++) { // going left to right.
leftRightServo.write(leftRightPos);
for (index = 0; index<=numReadings;index++) { // take x number of readings from the sensor and average them
float volts = analogRead(IRpin)0.0048828125; // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
float distance = 65
pow(volts, -1.10); // worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
total = total + distance; // update total
delay(20);
average = (int) total/numReadings; // create average reading CAST TO INT!! remove the decimal places
if (index >= numReadings) { // reset the counts when at the last item of the array
index = 0;
total = 0;
Serial.print("X"); // print leading X to mark the following value as degrees
Serial.print(leftRightPos); // current servo position
Serial.print("V"); // preceeding character to separate values
Serial.println(average); // average of sensor readings
start going right to left after we got to 180 degrees
same code as above
for(leftRightPos = 180; leftRightPos > 0; leftRightPos--) { // going right to left
float distance = 65
delay(20);
index = 0;
total = 0;
Serial.print("X");
Serial.print("V");
The #include part should have been on a new line AND should have done what the comment says.
#include <Servo.h>            // include the standard servo library
With that change,
Sketch uses 6,674 bytes (20%) of program storage space. Maximum is 32,256 bytes.
Global variables use 261 bytes (12%) of dynamic memory, leaving 1,787 bytes for local variables. Maximum is 2,048 bytes.
