error compiling
#include <Keypad.h>
#include<LiquidCrystal.h>
#include<EEPROM.h>
LiquidCrystal lcd(9,8,7,6,5,4);
char password[4];
char pass[4],pass1[4];
int i=0;
char customKey=0;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char hexaKeys[ROWS][COLS] = {
{‘1’,‘2’,‘3’,‘A’},
{‘4’,‘5’,‘6’,‘B’},
{‘7’,‘8’,‘9’,‘C’},
{’*’,‘0’,’#’,‘D’}
byte rowPins[ROWS] = {A0,A1,A2,A3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A4,A5,3,2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int led;
int buzzer = 10;
int m11;
int m12;
pinMode(11, OUTPUT);
lcd.begin(16,2);
pinMode(led, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(m11, OUTPUT);
pinMode(m12, OUTPUT);
lcd.print(" Electronic “);
Serial.print(” Electronic “);
lcd.setCursor(0,1);
lcd.print(” Keypad Lock “);
Serial.print(” Keypad Lock ");
delay(2000);
lcd.clear();
lcd.print(“Enter Ur Passkey:”);
Serial.println(“Enter Ur Passkey:”);
lcd.setCursor(0,1);
for(int j=0;j<4;j++)
EEPROM.write(j, j+49);
pass[j]=EEPROM.read(j);
digitalWrite(11, HIGH);
customKey = customKeypad.getKey();
if(customKey==’#’)
change();
if (customKey)
password[i++]=customKey;
lcd.print(customKey);
Serial.print(customKey);
beep();
if(i==4)
delay(200);
if(!(strncmp(password, pass,4)))
digitalWrite(led, HIGH);
beep();
lcd.clear();
lcd.print(“Passkey Accepted”);
Serial.println(“Passkey Accepted”);
digitalWrite(11, LOW);
delay(2000);
lcd.setCursor(0,1);
lcd.print("#.Change Passkey");
Serial.println("#.Change Passkey");
delay(2000);
lcd.clear();
lcd.print(“Enter Passkey:”);
Serial.println(“Enter Passkey:”);
lcd.setCursor(0,1);
i=0;
digitalWrite(led, LOW);
digitalWrite(buzzer, HIGH);
lcd.clear();
lcd.print(“Access Denied…”);
Serial.println(“Access Denied…”);
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
lcd.setCursor(0,1);
i=0;
digitalWrite(buzzer, LOW);
void change()
int j=0;
lcd.clear();
lcd.print(“UR Current Passk”);
Serial.println(“UR Current Passk”);
lcd.setCursor(0,1);
while(j<4)
char key=customKeypad.getKey();
if(key)
pass1[j++]=key;
lcd.print(key);
Serial.print(key);
beep();
key=0;
if((strncmp(pass1, pass, 4)))
lcd.clear();
lcd.print(“Wrong Passkey…”);
Serial.println(“Wrong Passkey…”);
lcd.setCursor(0,1);
lcd.print(“Better Luck Again”);
Serial.println(“Better Luck Again”);
j=0;
lcd.clear();
lcd.print(“Enter New Passk:”);
Serial.println(“Enter New Passk:”);
lcd.setCursor(0,1);
while(j<4)
if(key)
pass[j]=key;
lcd.print(key);
Serial.print(key);
EEPROM.write(j,key);
j++;
beep();
lcd.print(" Done…");
Serial.println(" Done…");
lcd.clear();
lcd.print(“Enter Ur Passk:”);
Serial.println(“Enter Ur Passk:”);
lcd.setCursor(0,1);
customKey=0;
void beep()
delay(20);
can someone help me
when i run this code it show me
error compiling
Roll-back the last modification you made, so that you get to code that does compile.
Is that the complete error message ?
Have you got the correct board selected ?
When I compiled it all I got was
Archiving built core (caching) in: C:\Users\Bob\AppData\Local\Temp\arduino_cache_249427\core\core_arduino_avr_uno_f6a42fc7c4fa8c4f7d5e83b05984621b.a
Sketch uses 5444 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 592 bytes (28%) of dynamic memory, leaving 1456 bytes for local variables. Maximum is 2048 bytes.
ie, no error
i got this
C:\Users\SONY\Desktop\hidayah\sem 6\CAO\PROJEK\Arduino_keypad\Arduino_keypad.ino:1:20: fatal error: Keypad.h: No such file or directory
#include <Keypad.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
Looks like the library is not installed or installed incorrectly
abidah93:
UKHeliBob:
There is no simple keyboard support for Arduino/Genuino Uno.
Whandall:
Keyboard ?
My bad. :wink:
Whandall:
My bad. :wink:
BTDTGTTS
