error complilng for board sanguino
I have a problem installing a firmware for a 3D printer error complilng for board sanguino ,
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
Ghaneem22:
I have a solution. Since you didn't post your problem, there is no need for me to post the solution.
C:\Users\abo-f\Downloads\Marlin-1.1.x\Marlin-1.1.x\Marlin\Marlin.ino:1:20: fatal error: U8glib.h: No such file or directory
#include <U8glib.h>
compilation terminated.
exit status 1
Error compiling for board Sanguino.
When you see a "No such file or directory" error it almost always means you need to install the library that contains the missing file.
Often the code you're compiling will come with documentation (either a comment or separate document) that tells you where to get the library dependencies.
In other cases the author of the code will not have been so kind and you'll need to go on a hunt for the missing library.
A good place to start is the Arduino IDE's Library Manager:
  • Sketch > Include Library > Manage Libraries...
  • In the "Filter your search..." box, type some keywords you have gleaned from the missing file name.
  • Scroll through the results for the right library. Click on it.
  • Click "Install".
  • Wait for installation to finish.
  • Click "Close".
  • Try compiling your code again.
If you have no luck in Library Manager then load up your favorite search engine and do a search for the missing filename. You will often get multiple results. If you have a lot of results you might add "arduino" as an additional search keyword. I will usually prefer results on github.com since that is where most Arduino libraries are hosted and downloading from there is fast and easy. In some cases there will be multiple libraries that contain the given filename and you'll need to do some evaluation to determine which seems the most appropriate, then try it out. After downloading the library you found you'll need to install it. This requires a different process than the Library Manager installation. You will find instructions here:
I'm also having a similar issue compiling the latest Marlin firmware for an Ender 3. Can't get it to verify even. I get the following error:
Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
C:\Users\Ste\Documents\Arduino\libraries\U8glib\src\clib\u8g_font.c: In function 'u8g_font_GetFontStartEncoding':
C:\Users\Ste\Documents\Arduino\libraries\U8glib\src\clib\u8g_font.c:167:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See http://gcc.gnu.org/bugs.html for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
c:/program files/windowsapps/arduinollc.arduinoide_1.8.15.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
option enabled in File -> Preferences.
Any idea what my problem could be?
Lionel_Glitchy:
Not really similar at all.
Lionel_Glitchy:
This is some problem with the latest compiler version released by Arduino. Unfortunately, there has been no progress on determining the cause or the solution:
The workaround is to roll back to the Arduino AVR Boards that uses the last known-good avr-gcc version:
  • Tools > Board > Boards Manager
  • Wait for downloads to finish.
  • When you move the mouse pointer over "Arduino AVR Boards", you will see a "Select version" dropdown menu appear. Select "1.6.21".
  • Click "Install".
  • Click "Close".
If you have File > Preferences > Check for updates on startup checked, the Arduino IDE may occasionally notify you that a new version of Arduino AVR Boards is available, you'll need to refrain from updating back to the new Arduino AVR Boards version, otherwise you'll be back to seeing the segmentation fault error again.
I am have a similar problem trying to boatload to a Ender 5, can someone help?
<Arduino: 1.8.9 (Mac OS X), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): unknown response=0x12
Error while burning bootloader.>
Juanc32:
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Tools > Burn Bootloader
  • After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
/Users/kikis/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/kikis/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega1284p -carduino -P/dev/cu.wchusbserial1420 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/kikis/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
         User configuration file is "/Users/kikis/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.wchusbserial1420
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: 425479
         Firmware Version: 16803844.-1451118764
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done.  Thank you.
here is the report pls help me
Try connecting a 10 uF capacitor between the reset and ground pins on the board you're using as an Arduino as ISP programmer. Once you're done using that board as an ISP programmer, make sure to remove the capacitor, since it will prevent you from being able to upload to the board.
hey i get error on compiling for marlin 1.1.9 with BLTouch conf for ender 5, a friend did it form me before but the printer suddenly turned blank, i asked around and they said to try to re-upload marlin with the BLTouch but its not workin, is it the laptop or another problem, i am using a macbook pro, pls help
here are 2 of the errors it says when upoalding
         Using Port                    : /dev/cu.wchusbserial14410
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf8
An error occurred while uploading the sketch
         Using Port                    : /dev/cu.wchusbserial14210
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Firmware Version: 5.0
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading input file "/var/folders/g5/mqr6xnp11qs38gcp9x69qmy00000gn/T/arduino_build_9070/Marlin.ino.hex"
avrdude: writing flash (126620 bytes):
Writing | ################################################## | 100% 35.79s
avrdude: 126620 bytes of flash written
avrdude: verifying flash memory against /var/folders/g5/mqr6xnp11qs38gcp9x69qmy00000gn/T/arduino_build_9070/Marlin.ino.hex:
avrdude: load data flash data from input file /var/folders/g5/mqr6xnp11qs38gcp9x69qmy00000gn/T/arduino_build_9070/Marlin.ino.hex:
avrdude: input file /var/folders/g5/mqr6xnp11qs38gcp9x69qmy00000gn/T/arduino_build_9070/Marlin.ino.hex contains 126620 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 33.27s
avrdude: verifying ...
avrdude: 126620 bytes of flash verified
The second output indicates a successful upload. Congratulations! Carry on.
