Error:conflicting declaration 'using SoftwareSerial = using UART =class EspSoftwareSerial::BasicUART<EspSoftwareSerial::GpioCapabilities>'>
I'm using Arduino IDE to proglam M5stack. When I trying to use ESPSoftwareSerial library,the error written in the title has occurred.
Full text of error is
C:\Users\ts200\Arduino Document\libralies\EspSoftwareSerial.h:432:47 error:conflicting declaration 'using SoftwareSerial = using UART =class EspSoftwareSerial::BasicUART<EspSoftwareSerial::GpioCapabilities>'>
using SoftwareSerial = EspSoftwareSerial::UART;
I'm using the board manager 'm5stack_core_esp32'.
I haven't rewritten any libraries.
Here is the sketch I tried to run.But evenafter deleting the contents of the setup function and loop function,the same error occurred.
#include<M5Stack.h>
#include<SoftwareSerial.h>
SoftwareSerial myserial(17, 16);
  // Power ON Stabilizing...
  M5.begin();
  M5.Lcd.setTextColor(GREEN);
  M5.Lcd.setTextSize(4);
  M5.Lcd.clear(BLACK);
  M5.update();
  if (M5.BtnA.wasPressed())
    M5.Lcd.setCursor(0, 0);
    M5.Lcd.println("POWER ON");
  if (M5.BtnB.wasPressed())
    M5.Lcd.println("POWER OFF");
I want to know how to fix this error.
I would appreciate any help, thank you.
Not sure what it's complaining about but here's what I'm doing on an ESP32 based display board
Can you use pins 17 & 18 instead? Those can be used as hardware serial port.
const int RX_PIN = 17;
const int TX_PIN = 18;
    setupUI();
    Serial2.begin(9600, SERIAL_8N1, RX_PIN, TX_PIN);
