i have project use arduino iot web editor to program my telegram bot notification, but when i compile the program it's always error (error: 'const void*' is not a pointer-to-object type). what should i do guys?
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/00becaba-5a9d-4033-9c67-6fc6a9cfd877
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
- No variables have been created, add cloud variables on the Thing Setup page
to see them declared here
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include "DHT.h"
#define DHTPIN D1
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
// Initialize Telegram BOT
#define BOTtoken "5761670683:AAHuYxfQcGD3PtdA5tx1zaKUNFaPVIXgMAE" // diisi Token Bot (Dapat dari Telegram Botfather)
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
//Checks for new messages every 1 second.
int botRequestDelay = 1000;
unsigned long lastTimeBotRan;
void handleNewMessages(int numNewMessages) {
Serial.println("handleNewMessages");
Serial.println(String(numNewMessages));
for (int i=0; i<numNewMessages; i++) {
String chat_id = String(bot.messages[i].chat_id);
String text = bot.messages[i].text;
String from_name = bot.messages[i].from_name;
if (from_name == "") from_name = "Guest";
//Cek Pembacaan Sensor DHT11
if (text == "/statussuhu") {
int t = dht.readTemperature()-2;
String temp = "Suhu saat ini : ";
temp += int(t);
temp +=" *C\n";
bot.sendMessage(chat_id,temp, "");
if (text == "/statuskelembapan") {
int h = dht.readHumidity();
String temp = "Kelembaban: ";
temp += int(h);
temp += " %";
//Cek Command untuk setiap aksi
if (text == "/start") {
String welcome = "Welcome " + from_name + ".\n";
welcome += "/statussuhu : Status Suhu\n";
welcome += "/statuskelembapan : Status Kelembapan\n";
bot.sendMessage(chat_id, welcome, "Markdown");
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
dht.begin();
// This is the simplest way of getting this working
// if you are passing sensitive information, or controlling
// something important, please either use certStore or at
// least client.setFingerPrint
client.setInsecure();
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(SSID);
WiFi.begin(SSID, PASS);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
if (millis() > lastTimeBotRan + botRequestDelay) {
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while(numNewMessages) {
Serial.println("got response");
handleNewMessages(numNewMessages);
lastTimeBotRan = millis();
