Error correction assistance
Greetings family can someone assist on how to solve the attached error on this project:
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\Josep\Downloads\incmaincode_Hogen\incmaincode_Hogen.ino:78:0:
C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DS3232RTC/DS3232RTC.h:136:26: error: 'tmElements_t' has not been declared
     static byte read(tmElements_t &tm);
C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DS3232RTC/DS3232RTC.h:137:27: error: 'tmElements_t' has not been declared
     static byte write(tmElements_t &tm);
C:\Users\Josep\Downloads\incmaincode_Hogen\incmaincode_Hogen.ino: In function 'void showclock()':
incmaincode_Hogen:1843:8: error: request for member 'getTime' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.getTime();
incmaincode_Hogen:1845:12: error: request for member 'hour' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (clock.hour < 10) {
incmaincode_Hogen:1848:18: error: request for member 'hour' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.hour, DEC);
incmaincode_Hogen:1850:12: error: request for member 'minute' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (clock.minute < 10) {
incmaincode_Hogen:1853:18: error: request for member 'minute' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.minute, DEC);
incmaincode_Hogen:1855:12: error: request for member 'second' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (clock.second < 10) {
incmaincode_Hogen:1858:18: error: request for member 'second' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.second, DEC);
incmaincode_Hogen:1860:12: error: request for member 'month' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (clock.month < 10) {
incmaincode_Hogen:1863:18: error: request for member 'month' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.month, DEC);
incmaincode_Hogen:1865:12: error: request for member 'dayOfMonth' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (clock.dayOfMonth < 10) {
incmaincode_Hogen:1868:18: error: request for member 'dayOfMonth' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.dayOfMonth, DEC);
incmaincode_Hogen:1870:18: error: request for member 'year' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
lcd.print(clock.year + 2000, DEC);
C:\Users\Josep\Downloads\incmaincode_Hogen\incmaincode_Hogen.ino: In function 'void turnerCountForDisplay()':
incmaincode_Hogen:1904:8: error: request for member 'getTime' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.getTime();
incmaincode_Hogen:1906:26: error: request for member 'dayOfMonth' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
prev_clock_day = clock.dayOfMonth;
incmaincode_Hogen:1909:30: error: request for member 'dayOfMonth' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
if (prev_clock_day != clock.dayOfMonth) {
incmaincode_Hogen:1914:25: error: request for member 'dayOfMonth' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
C:\Users\Josep\Downloads\incmaincode_Hogen\incmaincode_Hogen.ino: In function 'void clockset()':
incmaincode_Hogen:1982:9: error: request for member 'fillByYMD' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.fillByYMD(set_year, set_month, set_day); //Jan 19,2013
incmaincode_Hogen:1983:9: error: request for member 'fillByHMS' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.fillByHMS(set_hour, set_minute, 30); //15:28 30"
incmaincode_Hogen:1984:9: error: request for member 'fillDayOfWeek' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.fillDayOfWeek(SAT);//Saturday
incmaincode_Hogen:1984:23: error: 'SAT' was not declared in this scope
incmaincode_Hogen:1985:9: error: request for member 'setTime' in 'clock', which is of non-class type 'clock_t() {aka long unsigned int()}'
clock.setTime();//write time to the RTC chip
Multiple libraries were found for "DS3232RTC.h"
Used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DS3232RTC
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DS3232RTC-1.3.0
Multiple libraries were found for "LiquidCrystal_I2C.h"
Used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\LiquidCrystal_I2C
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2
Multiple libraries were found for "EEPROM.h"
Used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\EEPROM
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\EEPROM-master
Multiple libraries were found for "DHT.h"
Used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DHT
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DHT_sensor_library
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\DHT-sensor-library-master
Not used: C:\Users\Josep\OneDrive\Documents\Arduino\libraries\Grove_Temperature_And_Humidity_Sensor
exit status 1
option enabled in File -> Preferences.
incmaincode_Hogen.ino (48.1 KB)
What is the code ending up like this?
Please post the code, using code tags, and tell us which time library you are using (and where you downloaded it).
