Error Correction (Help ME out with this error)
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#define RightMotorSpeed D5 //14
#define RightMotorDir D6 //12
#define LeftMotorSpeed D7 //13
#define LeftMotorDir D8 //15
const int trigPin = 9;
const int echoPin = 10;
char auth = “uwbrmQt90lmjBZSlHdHn4pftvz2k2zqH”; //Blynk Authentication Token
char ssid = “PKA”; //WIFI Name
char pass = “angrybird”; //WIFI Password
int minRange = 312;
int maxRange = 712;
int minspeed = 450;
int maxspeed = 1020;
int nospeed = 0;
void moveControl(int x, int y)
//Move Forward
if (y >= maxRange && x >= minRange && x <= maxRange)
digitalWrite( RightMotorDir, HIGH);
digitalWrite(LeftMotorDir, HIGH);
analogWrite(RightMotorSpeed, maxspeed);
analogWrite(LeftMotorSpeed , maxspeed);
//Move Forward Right
else if (x >= maxRange && y >= maxRange)
analogWrite(RightMotorSpeed, minspeed);
//Move Forward Left
else if (x <= minRange && y >= maxRange)
analogWrite(LeftMotorSpeed , minspeed);
//No Move
else if (y < maxRange && y > minRange && x < maxRange && x > minRange)
analogWrite(RightMotorSpeed, nospeed);
analogWrite(LeftMotorSpeed , nospeed);
//Move Backward
else if (y <= minRange && x >= minRange && x <= maxRange)
digitalWrite( RightMotorDir, LOW);
digitalWrite(LeftMotorDir, LOW);
//Move Backward Right
else if (y <= minRange && x <= minRange)
//Move Backward Left
else if (y <= minRange && x >= maxRange)
Blynk.begin(auth, ssid, pass);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(RightMotorSpeed, OUTPUT);
pinMode(LeftMotorSpeed , OUTPUT);
pinMode( RightMotorDir, OUTPUT);
pinMode(LeftMotorDir, OUTPUT);
digitalWrite(RightMotorSpeed, LOW);
digitalWrite(LeftMotorSpeed , LOW);
long duration, distance;
Blynk.run();
BLYNK_WRITE(V1)
int x = param[0].asInt();
int y = param[1].asInt();
moveControl(x, y);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration / 58.2;
if (distance < 20) // When distance of Obstacle is less than 20 cm then turn LEFT
digitalWrite(RightMotorSpeed, LOW); // For the bot to make a RIGHT turn instead of LEFT turn change (HIGH to LOW) and (LOW to HIGH)
digitalWrite(LeftMotorSpeed, LOW);
digitalWrite(RightMotorDir, LOW);
else // When there is no obstacle under 20cm then the bot moves forward.
digitalWrite(RightMotorSpeed, HIGH);
digitalWrite(LeftMotorSpeed, HIGH);
digitalWrite(RightMotorDir, HIGH);
sketch_sep15a.ino (3.64 KB)
What error would that be ?
Please follow the advice on posting code in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and using code tags when posting code here
UKHeliBob:
Arduino: 1.6.9 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\Prithvi K A\Documents\Arduino\sketch_sep15a\sketch_sep15a.ino: In function 'void loop()':
sketch_sep15a:117: error: a function-definition is not allowed here before '{' token
C:\Users\Prithvi K A\Documents\Arduino\sketch_sep15a\sketch_sep15a.ino: At global scope:
sketch_sep15a:124: error: expected unqualified-id before '{' token
exit status 1
option enabled in File -> Preferences.
Like this
char auth[] = "uwbrmQt90lmjBZSlHdHn4pftvz2k2zqH";  //Blynk Authentication Token
char ssid[] = "PKA";           //WIFI Name
char pass[] = "angrybird";           //WIFI Password
int minRange = 312;
int maxRange = 712;
int minspeed = 450;
int nospeed = 0;
  //Move Forward
  //Move Forward Left
  //No Move
  //Move Backward
    Blynk.run();
  BLYNK_WRITE(V1)
    moveControl(x, y);
  BLYNK_WRITE(V1)
I am not familiar with the BLYNK library, but what is this line of code intended to do ?
