Error Correction
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino: In function 'void loop()':
sketch_sep11a:38: error: expected primary-expression before 'else'
else (x > backward) // Change the value for adjusting sensitivity
sketch_sep11a:38: error: expected ';' before 'else'
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino: At global scope:
sketch_sep11a:1: error: expected unqualified-id before numeric constant
#define forward 340 // Change this value to change senstivity for forward direction /-Default 340-/ X
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino:58:6: note: in expansion of macro 'forward'
void forward()
sketch_sep11a:2: error: expected unqualified-id before numeric constant
#define backward 340 // Change this value to change senstivity for backward direction /-Default 400-/ X
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino:68:6: note: in expansion of macro 'backward'
void backward()
sketch_sep11a:3: error: expected unqualified-id before numeric constant
#define left 340 // Change this value to change senstivity for left direction /-Default 340-/ Y
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino:78:6: note: in expansion of macro 'left'
void left()
sketch_sep11a:4: error: expected unqualified-id before numeric constant
#define right 340 // Change this value to change senstivity for right direction /-Default 400-/ Y
C:\Users\PRITHV~1\AppData\Local\Temp\arduino_modified_sketch_879284\sketch_sep11a.ino:88:6: note: in expansion of macro 'right'
void right()
exit status 1
option enabled in File -> Preferences.
You have a name collision between your macro (#define) names and your function names.
You need to use unique names.
It's common practice to make macro names ALL_UPPERCASE_WITH_UNDERSCORES to clearly identify them as macros. Following that practice would have avoided the name collision. However, these names "forward", "right" aren't very descriptive. I recommend giving them names that clearly describe their meaning. In this way the code becomes self-documenting.
You'd get better help if you showed us your code but
That should probably be something a bit more like
else if (x > backward) // etc
pert:
Thanks buddy i figured out the mistake
