Error Correction
Arduino: 1.6.9 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
Build options changed, rebuilding all
C:\Users\Prithvi K A\Downloads\WIFI_Controlled_Car\WIFI_Controlled_Car.ino: In function ‘void setup()’:
WIFI_Controlled_Car:41: error: ‘HTTP_handleRoot’ was not declared in this scope
server.on ( “/”, HTTP_handleRoot );
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
WIFI_Controlled_Car.ino (4.45 KB)
Help me out with this error
prithvi_k_a:
Please post your code and all your error messages.
TheMemberFormerlyKnownAsAWOL:
#define ENA 14 // Enable/speed motors Right GPIO14(D5)
#define ENB 12 // Enable/speed motors Left GPIO12(D6)
#define IN_1 15 // L298N in1 motors Right GPIO15(D8)
#define IN_2 13 // L298N in2 motors Right GPIO13(D7)
#define IN_3 2 // L298N in3 motors Left GPIO2(D4)
#define IN_4 0 // L298N in4 motors Left GPIO0(D3)
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
String command; //String to store app command state.
int speedCar = 800; // 400 - 1023.
int speed_Coeff = 3;
int ledPin = 4; // choose pin for the LED
int inputPin = 5; // choose input pin (for Infrared sensor)
int val = 0;
const char* ssid = “NodeMCU Car”;
ESP8266WebServer server(80);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(IN_1, OUTPUT);
pinMode(IN_2, OUTPUT);
pinMode(IN_3, OUTPUT);
pinMode(IN_4, OUTPUT);
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare Infrared sensor as
// Connecting WiFi
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
// Starting WEB-server
server.onNotFound ( HTTP_handleRoot );
server.begin();
void goAhead(){
digitalWrite(IN_1, LOW);
digitalWrite(IN_2, HIGH);
analogWrite(ENA, speedCar);
digitalWrite(IN_3, LOW);
digitalWrite(IN_4, HIGH);
analogWrite(ENB, speedCar);
void goBack(){
digitalWrite(IN_1, HIGH);
digitalWrite(IN_2, LOW);
digitalWrite(IN_3, HIGH);
digitalWrite(IN_4, LOW);
void goRight(){
void goLeft(){
void goAheadRight(){
analogWrite(ENA, speedCar/speed_Coeff);
void goAheadLeft(){
analogWrite(ENB, speedCar/speed_Coeff);
void goBackRight(){
void goBackLeft(){
void stopRobot(){
val = digitalRead(inputPin); // read input value
if (val == HIGH)
{ // check if the input is HIGH
digitalWrite(ledPin, LOW); // turn LED OFF
digitalWrite(ledPin, HIGH); // turn LED ON
server.handleClient();
command = server.arg(“State”);
if (command == “F”) goAhead();
else if (command == “B”) goBack();
else if (command == “L”) goLeft();
else if (command == “R”) goRight();
else if (command == “I”) goAheadRight();
else if (command == “G”) goAheadLeft();
else if (command == “J”) goBackRight();
else if (command == “H”) goBackLeft();
else if (command == “0”) speedCar = 400;
else if (command == “1”) speedCar = 470;
else if (command == “2”) speedCar = 540;
else if (command == “3”) speedCar = 610;
else if (command == “4”) speedCar = 680;
else if (command == “5”) speedCar = 750;
else if (command == “6”) speedCar = 820;
else if (command == “7”) speedCar = 890;
else if (command == “8”) speedCar = 960;
else if (command == “9”) speedCar = 1023;
else if (command == “S”) stopRobot();
void HTTP_handleRoot(void) {
if( server.hasArg(“State”) ){
Serial.println(server.arg(“State”));
server.send ( 200, “text/html”, “” );
delay(1);
prithvi_k_a:
int val = 0;
// Connecting WiFi
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid);
server.begin();
void goAhead(){
void goBack(){
void goRight(){
void goLeft(){
void goAheadLeft(){
void goBackRight(){
void goBackLeft(){
void stopRobot(){
if (val == HIGH)
delay(1);
exit status 1
// these are the errors
Did you forget the () at the end of HTTP_handleRoot()?
Steve
slipstick:
Steve
