Error Creating Arrays
Hi. I'm trying create a 2D array, but all the time I have error when I compile the code. The error say
test.ino: In function 'void setup()':
test:71: error: expected primary-expression before '{' token
test:71: error: expected `;' before '{' token
test:93: error: expected `}' at end of input
and the code for create the array is
  int numberSections = 4 ;
  String sections[numberSections][2];
  sections = {{'S', totalSSec},{'B', totalBSec},{'R',totalRSec},{'T',totalTSec}};
Where is the problem because I see different pages for see example of arrays and use the same but without error and now I am a bit confused
I can't see properly, but are those single quotes?
Ups yes. I change for try and I completely forgot to change again for copy the code here.
  sections = {{"S", totalSSec},{"B", totalBSec},{"R",totalRSec},{"T",totalTSec}};
So why aren't you initialising the array when you declare it?
Because I have another error. The first time I try to declare the array and assign values to them in the first line and error.
  String sections[numberSections][2]  = {{"S", totalSSec},{"B", totalBSec},{"R",totalRSec},{"T",totalTSec}};
and error
test:70: error: variable-sized object 'sections' may not be initialized
OK, just post your code.
  int totalSSec = 324453;
  int totalBSec = 324234;
  int totalRSec = 897645;
  int totalTSec = totalSSec + totalBSec + totalRSec;
  String sections[numberSections][2]  = {{"S", totalSSec},{"Bike", totalBSec},{"Run",totalRSec},{"Total",totalTSec}};
  for (int count = 0; count < 5; count++){
    Serial.println(sections[count][2]);
You can't initialize with a variable number of elements.
  const int numberSections = 4 ;
Why are you putting numbers into String? String is inefficient at the best of times.
I did’nt know that. I am starting learning. I change the code and I make two arrays one for the string and another for the int values.
  int totalSSec = 1111;
  int totalBSec = 2222;
  int totalRSec = 3333;
  String sections[numberSections]  = {"S","B","R","T"};
  int sectionsSec[numberSections] = {totalSSec,totalBSec,totalRSec,totalTSec};
  for (int count = 0; count < 4; count++){
    Serial.print(sections[count]);
    Serial.print(" is ");
    Serial.print(sectionsSec[count]);
First, while the String class (note the capital 'S') brings a lot of functionality to the party, it often costs more memory than it's worth. Usually a simple char array that is null terminated ('\0') is more efficient. Second, if you need an array that has dissimilar data types (what I call arrays for adults), use a structure:
struct Data {
   char myArray[16];
   int myInteger;
struct Data myData[20];
The struct above creates an array of 20 Data structures named myData which you can access with syntax like:
myData[0].myInteger = 10;
This allows you to have a single array, but with different data types as members of that struct array. Note that the max "string" size you can have is 15 characters because you need the null byte at the end of the string. You can also initialize them, but I'll let you discover how to do that.
Jota_sk:
In that case try to learn using char arrays rather than “string”. It’ll save you some grief in the long run.
