I wrote and debugged a lot of code in a header file. I wanted to make it into a library so I followed the tutorial at: http://arduino.cc/en/Hacking/LibraryTutorial. I got a lot of errors so I decided to make an ultra simple library to familiarize myself with the problems. Unfortunately even the ultra simple code gave error messages like: error: no matching function for call to 'testRTC::testRTC()' where testRTC should have been my constructor, not a function call.
My sketch:
// test real time clock library
#ifndef testRTC_h
#define testRTC_h
#include <Arduino.h>
#include <Wire.h>
#define RTC_ADDRESS 0x68
#define ENABLE_SQ_WAVE_REG 0x07
#define ENABLE_SQ_WAVE 0x10 // default for 1 HZ output
// alternatives are: 0x10=1 HZ, 0x11=4 KHZ, 0x12=8 KHZ, 0x13=32 KHZ
class testRTC // Real Time Clock
public:
testRTC(byte freqSQwave); // constructor
void setClock(byte *clockSetting); // set clock with array
void getClock(byte *clockSetting); // put clock in array
void enableSQwave(boolean enable, byte freq); // enable/disable SQ wave
protected:
byte decToBcd(byte val);
byte bcdToDec(byte val);
#endif
The beginning of my .cpp file located in my library directory:
// Local real time clock
#ifndef testRTC_h
#define testRTC_h
#endif
#include <Wire.h>
//#include "testRTC.h" // for real time clock
testRTC::testRTC(byte freqSQwave = 0) {;} // constructor
void testRTC::setClock(byte *clockSetting) // points to setting
byte value;
Wire.beginTransmission(RTC_ADDRESS);
Wire.write( (byte) 0); // register pointer value
for (int i = 0; i < 7; i++) // write the setting
value = clockSetting[6 - i]; // start with seconds value
if (value == 255) break;
Wire.write(decToBcd(value)); // convert as writing to RTC
Wire.write( (byte) 0); // may be to reset register pointer
Wire.endTransmission();
The full error message was:
aaa:5: error: no matching function for call to 'testRTC::testRTC()'
C:\Arduino-IDE\libraries\testRTC/testRTC.h:16:
note: candidates are: testRTC::testRTC(byte)
C:\Arduino-IDE\libraries\testRTC/testRTC.h:14:
note: testRTC::testRTC(const testRTC&)
In the sketch (aaa.ino) if I comment out "testRTC rtc;" it will compile but then there is no instance of the class I want to use. Seems as soon as the class is instantiated it tries to call a constructor and does not find the one I provided.
turbosnail:
Well yeah, there's no testRTC::testRTC(), there's only testRTC::testRTC(byte freqSQwave)
I am not sure what you mean when you say "there's no testRTC::testRTC(), there's only testRTC::testRTC(byte freqSQwave)". That is what the IDE says but I do not have a function call to testRTC(). That is what the IDE is looking for, and it is NOT in my code. The error message states "no matching function for call to 'testRTC::testRTC()'" but I do NOT have a function call, only a constructor. The error message calls it a function but a constructor is not a function so I do not know what the error message indicates the IDE wants.
P.S.
The code I distilled the aaa.ino from worked fine as long as the constructor, methods and functions remained in the header file, it was only when I tried to separate out the class, constructor and methods into a .h and .cpp file that I ran into the errors.
Pardon my density, I have only been programming C++ for a few weeks, but when you say "There is no mention there of a default argument." Where do you mean, in the sketch or in the class definition? In the class definition I do have a parameter in the constructor and I tried putting one in the instantiation of the class with " testRTC rtc(0);" but I still get the errors. I tried "testRTC rte((byte) 0);" and still get errors. I added a constructor in the header file that does not require a parameter: " but still get errors. I took all code from the .cpp file and put it in the .h header file, commented out the code in the .cpp and compiled with NO errors. As far as I can tell what I have done is just like the tutorial but I get errors.
If someone could be more specific as to what is wrong it would help me a lot.
Yes I know the instantiation is calling a constructor but the IDE does not seem to recognize any of the code in my .cpp file which is in my library file with the header file.
turbosnail:
This seems like it should be correct. Now show the code and explain what errors you get.
C:\Arduino-IDE\libraries\testRTC\testRTC.cpp:11:
error: 'testRTC' has not been declared
C:\Arduino-IDE\libraries\testRTC\testRTC.cpp:11: error:
ISO C++ forbids declaration of 'testRTC' with no type
C:\Arduino-IDE\libraries\testRTC\testRTC.cpp:12: error:
'testRTC' is not a class or namespace
C:\Arduino-IDE\libraries\testRTC\testRTC.cpp:14: error:
In function 'void setClock(byte*)':
C:\Arduino-IDE\libraries\testRTC\testRTC.cpp:17:
error: 'RTC_ADDRESS' was not declared in this scope
etc. etc. etc.
I do not know why but the IDE does not seem to be recognizing the .cpp file and maybe not the .h file.
HELP!
OK, I was right; I was doing something fundamentally wrong. All I did to make it compile was change the .cpp file in the library directory. I commented out this:
#ifndef testRTC_h
#define testRTC_h
#endif
And it compiled. Tomorrow I will test the compile and research the correct way to use those preprocessor directives. Right now it is bedtime. I do not know how to mark the thread as solved; maybe tomorrow.
Thanks to all who tried to help. If any of you know of a link to info on the preprocessor stuff I would thank you imensely.
That #ifndef bit should only be in the .h file for a class, to prevent the declaration of the class being included twice. The first two lines go at the top and the last line ( #endif ) should be at the end of the file.
You don't put that into the .cpp file for the class.
