Under W10, starting the IDE finishes by declaring that there is an error creating the sketch directory, and no file can be loaded. Nothing can be done since then.
Hi @shaell. I'm sorry to hear that Arduino IDE 2.x is giving you trouble.
Would you mind posting the full and exact text of the error message here. You should be able to select the text and then copy and paste it into a reply here on the forum.
Hi @pert , these are the error messages:
Request loadSketch failed with message: 14 UNAVAILABLE: No connection established.
There was an error creating the sketch directory. See the log for more details. The application will probably not work as expected.
It only happens in Windows and it takes NO LESS THAN 5 MINUTES TO START, at least. In Linux it works perfectly. I have to say that it has never worked, so I uninstalled any previous version of Arduino just in case. Thanks for your help!
I'll ask you to run it from the command line and share the output in case we get more details on the cause of the problem.
Please do this:
- Start File Explorer (AKA "Windows Explorer").
- Open the Arduino IDE's installation folder (usually
C:\Program Files\Arduino IDE
orC:\Users\<user name>\AppData\Local\Programs\Arduino IDE
). - In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
- From the context menu, click "Open PowerShell window here". PowerShell will now open with the current directory set to the Arduino IDE installation folder.
- Type
& ".\Arduino IDE"
. - Press Enter. Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
- Wait for the Arduino IDE to finish starting, or failing to start.
- Switch back to the PowerShell window if the Arduino IDE window took the focus.
- Right click on the title bar of the PowerShell window.
- Click Edit > Select All. This will select all the text in the PowerShell window.
- Press Ctrl+C. This will copy the contents of the PowerShell window to the clipboard.
- In this Arduino forum thread, click on the reply field.
- Click the
button on the forum toolbar. This will add the forum's code tags markup (```
) to your reply, making it easier for us to read. - Press Ctrl+V. This will paste the output between the code tags.
- Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the "Reply" button.
Hopefully that will give us some information we can use to help you with the problem.
Windows PowerShell
Copyright (C) Microsoft Corporation. Todos los derechos reservados.
Prueba la nueva tecnología PowerShell multiplataforma https://aka.ms/pscore6
PS C:\Users\jorov> cd /
PS C:\> cd '.\Archivos de programa\'
PS C:\Archivos de programa> dir
dir : Acceso denegado a la ruta de acceso 'C:\Archivos de programa'.
En línea: 1 Carácter: 1
+ dir
+ CategoryInfo : PermissionDenied: (C:\Archivos de programa:String) [Get-ChildItem], UnauthorizedAccessEx
ception
+ FullyQualifiedErrorId : DirUnauthorizedAccessError,Microsoft.PowerShell.Commands.GetChildItemCommand
Even running as administrator.
I have reinstalled it into another directory, just in case is a matter of permissions but it seems to be NOT working at all. It complains with the same messages.
+ CategoryInfo : ObjectNotFound: (daemon:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 1.2.1]
daemon : El término 'daemon' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
ejecutable. Compruebe si escribió correctamente el nombre o, si incluyó una ruta de acceso, compruebe que dicha ruta
es correcta e inténtelo de nuevo.
+ daemon INFO Loaded tool [tool: Version: 1.2.1]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading package esp8266 from: C:\Users\jorov\AppData\Local\Arduino15\packages\esp8266\hardware
+ daemon INFO Loading package esp8266 from: C:\Users\jorov\AppData\Loca ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded platform [platform: {ID:"esp8266:esp8266",Installed:"2.7.4",Latest:"2.7.4",Name:"ESP8266 Boards (2.7.4)"}]
En línea: 1 Carácter: 61
+ daemon INFO Loaded platform [platform: {ID:"esp8266:esp8266",Installe ...
Falta un argumento en la lista de parámetros.
+ CategoryInfo : ParserError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : MissingArgument
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking existence of 'tools' path: C:\Users\jorov\AppData\Local\Arduino15\packages\esp8266\tools
+ daemon INFO Checking existence of 'tools' path: C:\Users\jorov\AppDat ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading tools from dir: C:\Users\jorov\AppData\Local\Arduino15\packages\esp8266\tools
+ daemon INFO Loading tools from dir: C:\Users\jorov\AppData\Local\Ardu ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 2.5.0-4-fe5bb56]
+ daemon INFO Loaded tool [tool: Version: 2.5.0-4-fe5bb56]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 2.5.0-4-b40a506]
+ daemon INFO Loaded tool [tool: Version: 2.5.0-4-b40a506]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 3.7.2-post1]
+ daemon INFO Loaded tool [tool: Version: 3.7.2-post1]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Adding libraries dir [dir: C:\Users\jorov\Documents\Arduino\libraries, location: user]
+ daemon INFO Adding libraries dir [dir: C:\Users\jorov\Documents\Ardui ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Adding libraries dir [dir: C:\Users\jorov\AppData\Local\Arduino15\packages\SparkFun\hardware\avr\1.1.13\libraries, location: platform]
+ daemon INFO Adding libraries dir [dir: C:\Users\jorov\AppData\Local\A ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Adding libraries dir [dir: C:\Users\jorov\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries, location: platform]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Adding libraries dir [dir: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries, location: platform]
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend CommonFrontendContribution.configure is slow, took: 3188.7 ms
root : El término 'root' no se reconoce como nombre de un cmdlet, función, archivo de script o programa ejecutable.
Compruebe si escribió correctamente el nombre o, si incluyó una ruta de acceso, compruebe que dicha ruta es correcta e
inténtelo de nuevo.
+ root WARN Frontend CommonFrontendContribution.configure is slow, took ...
+ CategoryInfo : ObjectNotFound: (root:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend commands.onStart is slow, took: 755.8 ms
inténtelo de nuevo.
+ root WARN Frontend commands.onStart is slow, took: 755.8 ms
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Using Git [2.30.1.windows.1] from the PATH. (C:\Program Files\Git\cmd\git.exe)
C:\Program : El término 'C:\Program' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
En línea: 1 Carácter: 56
+ ... INFO Using Git [2.30.1.windows.1] from the PATH. (C:\Program Files\G ...
+ CategoryInfo : ObjectNotFound: (C:\Program:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend keybindings.onStart is slow, took: 9349.8 ms
inténtelo de nuevo.
+ root WARN Frontend keybindings.onStart is slow, took: 9349.8 ms
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend TabBarToolbarRegistry.onStart is slow, took: 192.8 ms
inténtelo de nuevo.
+ root WARN Frontend TabBarToolbarRegistry.onStart is slow, took: 192.8 ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend JsonSchemaStore.onStart is slow, took: 638.3 ms
inténtelo de nuevo.
+ root WARN Frontend JsonSchemaStore.onStart is slow, took: 638.3 ms
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend ElectronMenuContribution.onStart is slow, took: 353.2 ms
inténtelo de nuevo.
+ root WARN Frontend ElectronMenuContribution.onStart is slow, took: 35 ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR DefaultJsonSchemaContribution.registerSchemas is taking more than 500.0 ms, new schemas are ignored.
inténtelo de nuevo.
+ root ERROR DefaultJsonSchemaContribution.registerSchemas is taking mo ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO URL: https://downloads.arduino.cc/packages/package_index.json
+ daemon INFO URL: https://downloads.arduino.cc/packages/package_index. ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Updating index [url: https://downloads.arduino.cc/packages/package_index.json]
+ daemon INFO Updating index [url: https://downloads.arduino.cc/package ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Updating index: package_index.json completed.
inténtelo de nuevo.
+ root INFO Updating index: package_index.json completed.
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Updating index: package_index.json.sig completed.
inténtelo de nuevo.
+ root INFO Updating index: package_index.json.sig completed.
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking signature [error: opening signature file: open C:\Users\jorov\AppData\Local\Temp\416450199.sig: El sistema no puede encontrar el archivo especificado., index: C:\Users\jorov\AppData\Local\Temp\416450199, signaturefile: C:\Users\jorov\AppData\Local\Temp\416450199.sig]
+ daemon INFO Checking signature [error: opening signature file: open C ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking signature [index: C:\Users\jorov\AppData\Local\Arduino15\package_index.json, signaturefile: C:\Users\jorov\AppData\Local\Arduino15\package_index.json.sig, trusted: true]
+ daemon INFO Checking signature [index: C:\Users\jorov\AppData\Local\A ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading hardware from: C:\Users\jorov\AppData\Local\Arduino15\packages
+ daemon INFO Loading hardware from: C:\Users\jorov\AppData\Local\Ardui ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading package SparkFun from: C:\Users\jorov\AppData\Local\Arduino15\packages\SparkFun\hardware
+ daemon INFO Loading package SparkFun from: C:\Users\jorov\AppData\Loc ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded platform [platform: {ID:"SparkFun:avr",Installed:"1.1.13",Latest:"1.1.13",Name:"SparkFun AVR Boards"}]
En línea: 1 Carácter: 58
+ daemon INFO Loaded platform [platform: {ID:"SparkFun:avr",Installed:" ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading package arduino from: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\hardware
+ daemon INFO Loading package arduino from: C:\Users\jorov\AppData\Loca ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking signature [error: opening signature file: open C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json.sig: El sistema no puede encontrar el archivo especificado., index: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json, signaturefile: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json.sig]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded platform [platform: {ID:"arduino:avr",Installed:"1.8.3",Latest:"1.8.3",Name:"Arduino AVR Boards"}]
En línea: 1 Carácter: 57
+ daemon INFO Loaded platform [platform: {ID:"arduino:avr",Installed:"1 ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking existence of 'tools' path: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\tools
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading tools from dir: C:\Users\jorov\AppData\Local\Arduino15\packages\arduino\tools
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 1.3.0 Systems: [OS: i686-linux-gnu, OS: x86_64-linux-gnu, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: i386-apple-darwin11, OS: i686-mingw32]]
+ daemon INFO Loaded tool [tool: Version: 1.3.0 Systems: [OS: i686-linu ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 7.3.0-atmel3.6.1-arduino7 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin14, OS: i686-mingw32, OS: i686-linux-gnu, OS: x86_64-linux-gnu]]
+ daemon INFO Loaded tool [tool: Version: 7.3.0-atmel3.6.1-arduino7 Sys ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 6.3.0-arduino17 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin12, OS: x86_64-linux-gnu, OS: i686-linux-gnu, OS: i686-mingw32]]
+ daemon INFO Loaded tool [tool: Version: 6.3.0-arduino17 Systems: [OS: ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading package builtin from: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin
+ daemon INFO Loading package builtin from: C:\Users\jorov\AppData\Loca ...
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Checking existence of 'tools' path: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin\tools
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loading tools from dir: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin\tools
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 5.8-arduino11]
+ daemon INFO Loaded tool [tool: Version: 5.8-arduino11]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 1.0.0]
+ daemon INFO Loaded tool [tool: Version: 1.0.0]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Loaded tool [tool: Version: 1.1.0]
+ daemon INFO Loaded tool [tool: Version: 1.1.0]
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Updating libraries index
+ daemon INFO Updating libraries index
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Updating index: library_index.json completed.
inténtelo de nuevo.
+ root INFO Updating index: library_index.json completed.
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Error during sketch processing: Filesystem bottom is too deep (directory recursion or filesystem really deep): c:\Users\jorov\Documents\Arduino\BMP280_con_LCD_i2C\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h
directory : El término 'directory' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
En línea: 1 Carácter: 76
+ ... g sketch processing: Filesystem bottom is too deep (directory recursi ...
+ CategoryInfo : ObjectNotFound: (directory:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> daemon ERROR Error during sketch processing: Filesystem bottom is too deep (directory recursion or filesystem really deep): c:\Users\jorov\Documents\Arduino\BMP280_con_LCD_i2C\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h
En línea: 1 Carácter: 77
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Uncaught Exception:
inténtelo de nuevo.
+ root ERROR Uncaught Exception:
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET
inténtelo de nuevo.
+ root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 trigge ...
PS C:\Users\jorov\Desktop\Arduino IDE> at Object.callErrorFromStatus (C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
C:\Users\jorov\Desktop\Arduino : El término 'C:\Users\jorov\Desktop\Arduino' no se reconoce como nombre de un cmdlet,
función, archivo de script o programa ejecutable. Compruebe si escribió correctamente el nombre o, si incluyó una ruta
de acceso, compruebe que dicha ruta es correcta e inténtelo de nuevo.
En línea: 1 Carácter: 36
+ ... at Object.callErrorFromStatus (C:\Users\jorov\Desktop\Arduino IDE\res ...
+ CategoryInfo : ObjectNotFound: (C:\Users\jorov\Desktop\Arduino:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at Object.onReceiveStatus (C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:387:49)
En línea: 1 Carácter: 32
+ at Object.onReceiveStatus (C:\Users\jorov\Desktop\Arduino IDE\res ...
PS C:\Users\jorov\Desktop\Arduino IDE> at Object.onReceiveStatus (C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:299:181)
PS C:\Users\jorov\Desktop\Arduino IDE> at C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:145:78
El comando AT está desusado. Use en su lugar schtasks.exe.
El comando no es válido.
El comando AT programa la ejecución de comandos y programas en un equipo a
una hora y fecha especificadas. El servicio de programación debe estar en
ejecución para utilizar el comando AT.
AT [\\equipo] [ [id] [/DELETE] | /DELETE [/YES]]
AT [\\equipo] hora [/INTERACTIVE]
[ /EVERY:fecha[,...] | /NEXT:fecha[,...]] "comando"
\\equipo Especifica un equipo remoto. Si se omite este
parámetro, los comandos se programan en el equipo
local.
id Es un número de identificación asignado al comando
programado.
/delete Cancela un comando programado. Si se omite id, se
cancelarán todos los comandos programados en el equipo.
/yes Se usa con el comando de cancelación de todos los
trabajos cuando no se desea ninguna confirmación.
/interactive Permite a la tarea interactuar con el escritorio del
usuario cuya sesión coincide con el momento de
ejecución de la tarea.
/every:fecha[,...] Ejecuta el comando cada día de la semana o mes
especificado. Si se omite la fecha, se asume que es el
día actual del mes.
/next:fecha[,...] Ejecuta el comando especificado la próxima vez que
aparezca ese día (por ejemplo, el próximo jueves). Si
se omite la fecha, se asume que es el día actual del
mes.
"comando" Es el comando de Windows NT o programa por lotes que se
va a ejecutar.
PS C:\Users\jorov\Desktop\Arduino IDE> at processTicksAndRejections (internal/process/task_queues.js:76:11)
internal/process/task_queues.js:76:11 : El término 'internal/process/task_queues.js:76:11' no se reconoce como nombre
de un cmdlet, función, archivo de script o programa ejecutable. Compruebe si escribió correctamente el nombre o, si
incluyó una ruta de acceso, compruebe que dicha ruta es correcta e inténtelo de nuevo.
En línea: 1 Carácter: 35
+ ... at processTicksAndRejections (internal/process/task_queues.js:76:11)
+ CategoryInfo : ObjectNotFound: (internal/process/task_queues.js:76:11:String) [], CommandNotFoundExcept
ion
PS C:\Users\jorov\Desktop\Arduino IDE> daemon INFO Daemon exited with exit code: 1.
+ daemon INFO Daemon exited with exit code: 1.
PS C:\Users\jorov\Desktop\Arduino IDE> monitor-service INFO >>> Disposing monitor service...
En línea: 1 Carácter: 24
+ monitor-service INFO >>> Disposing monitor service...
Falta la especificación de archivo después del operador de redirección.
El flujo de salida de este comando ya está redirigido.
+ FullyQualifiedErrorId : MissingFileSpecification
PS C:\Users\jorov\Desktop\Arduino IDE> monitor-service INFO <<< Disposed monitor service.
En línea: 1 Carácter: 23
+ monitor-service INFO <<< Disposed monitor service.
En línea: 1 Carácter: 22
El operador '<' está reservado para uso futuro.
PS C:\Users\jorov\Desktop\Arduino IDE> root FATAL Failed to determine the sketch directory: Error: Connection got disposed.
inténtelo de nuevo.
+ root FATAL Failed to determine the sketch directory: Error: Connectio ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend EditorNavigationContribution.onStart is slow, took: 424553.4 ms
inténtelo de nuevo.
+ root WARN Frontend EditorNavigationContribution.onStart is slow, took ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Checking whether '--no-optional-locks' can be used with the current Git executable. Minimum required version is '2.15.0'.
inténtelo de nuevo.
+ root INFO Checking whether '--no-optional-locks' can be used with the ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend WorkspaceService.onStart is slow, took: 1090.9 ms
inténtelo de nuevo.
+ root WARN Frontend WorkspaceService.onStart is slow, took: 1090.9 ms
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend DebugFrontendApplicationContribution.onStart is slow, took: 523.5 ms
inténtelo de nuevo.
+ root WARN Frontend DebugFrontendApplicationContribution.onStart is sl ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN Frontend BoardsDataMenuUpdater.onStart is slow, took: 205.8 ms
inténtelo de nuevo.
+ root WARN Frontend BoardsDataMenuUpdater.onStart is slow, took: 205.8 ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Board config changed:
inténtelo de nuevo.
+ root INFO Board config changed:
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request search failed with error: 14 UNAVAILABLE: No conne ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request list failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request list failed with error: 14 UNAVAILABLE: No connect ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request searchBoards failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request searchBoards failed with error: 14 UNAVAILABLE: No ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request installed failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request installed failed with error: 14 UNAVAILABLE: No co ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request getContainerBoardPackage failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request getContainerBoardPackage failed with error: 14 UNA ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO '--no-optional-locks' is a valid Git option for the current Git version: '2.30.1.windows.1'.
inténtelo de nuevo.
+ root INFO '--no-optional-locks' is a valid Git option for the current ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Changed application state from 'init' to 'started_contributions'.
inténtelo de nuevo.
+ root INFO Changed application state from 'init' to 'started_contribut ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Changed application state from 'started_contributions' to 'attached_shell'.
inténtelo de nuevo.
+ root INFO Changed application state from 'started_contributions' to ' ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO >>> Restoring the layout state...
En línea: 1 Carácter: 13
+ root INFO >>> Restoring the layout state...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO <<< The layout has been successfully restored.
En línea: 1 Carácter: 12
+ root INFO <<< The layout has been successfully restored.
En línea: 1 Carácter: 11
inténtelo de nuevo.
inténtelo de nuevo.
inténtelo de nuevo.
inténtelo de nuevo.
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Sync of 5 plugins took: 24494.2 ms
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Sync of 5 plugins to ...
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No connection established
inténtelo de nuevo.
+ root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No c ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
inténtelo de nuevo.
+ root INFO Changed application state from 'attached_shell' to 'initial ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][marus25.cortex-debug]: Loaded contributions.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][marus25.cortex-debug ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][arduino.vscode-arduino-tools]: Loaded contributions.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][arduino.vscode-ardui ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.cpp]: Loaded contributions.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.cpp]: Loaded ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json]: Loaded contributions.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json]: Loaded ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json-language-features]: Loaded contributions.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json-language ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Load contributions of 5 plugins took: 38.4 ms
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Load contributions o ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
inténtelo de nuevo.
+ root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' ...
PS C:\Users\jorov\Desktop\Arduino IDE> root WARN a registered grammar configuration for 'cpp' language is overridden
inténtelo de nuevo.
+ root WARN a registered grammar configuration for 'cpp' language is ov ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452) starting instance
inténtelo de nuevo.
+ root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452) starting instance
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR Error: Request 'loadSketch' failed
inténtelo de nuevo.
+ root ERROR Error: Request 'loadSketch' failed
PS C:\Users\jorov\Desktop\Arduino IDE> at Proxy.<anonymous> (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/bundle.js:64108:33)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/bundle.js:64108:33 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/bundle.js:64108:33' no se reconoce como nombre de un
cmdlet, función, archivo de script o programa ejecutable. Compruebe si escribió correctamente el nombre o, si incluyó
En línea: 1 Carácter: 27
+ ... anonymous> (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/ap ...
+ CategoryInfo : ObjectNotFound: (file:///C:/User...dle.js:64108:33:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3425:65)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3425:65 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3425:65' no se reconoce como nombre de un
En línea: 1 Carácter: 49
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:3425:65:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at step (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3022:23)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3022:23 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3022:23' no se reconoce como nombre de un
En línea: 1 Carácter: 14
+ ... at step (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/ap ...
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:3022:23:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at Object.next (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3003:53)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3003:53 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3003:53' no se reconoce como nombre de un
En línea: 1 Carácter: 21
+ ... bject.next (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/ap ...
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:3003:53:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:2997:71
local.
programado.
día actual del mes.
mes.
va a ejecutar.
PS C:\Users\jorov\Desktop\Arduino IDE> at new Promise (<anonymous>)
< : El término '<' no se reconoce como nombre de un cmdlet, función, archivo de script o programa ejecutable.
inténtelo de nuevo.
+ at new Promise (<anonymous>)
+ CategoryInfo : ObjectNotFound: (<:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.__awaiter (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:2993:12)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:2993:12 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:2993:12' no se reconoce como nombre de un
En línea: 1 Carácter: 106
+ ... .__awaiter (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/ap ...
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:2993:12:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at ArduinoFrontendContribution.push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.ArduinoFrontendContribution.openSketchFiles (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3417:16)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3417:16 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3417:16' no se reconoce como nombre de un
En línea: 1 Carácter: 168
+ ... ketchFiles (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/ap ...
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:3417:16:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3376:26)
file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3376:26 : El término
'file:///C:/Users/jorov/Desktop/Arduino%20IDE/resources/app/lib/55.bundle.js:3376:26' no se reconoce como nombre de un
+ CategoryInfo : ObjectNotFound: (file:///C:/User...ndle.js:3376:26:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Changed application state from 'initialized_layout' to 'ready'.
inténtelo de nuevo.
+ root INFO Changed application state from 'initialized_layout' to 'rea ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): PluginManagerExtImpl/init()
En línea: 1 Carácter: 80
+ ... hosted-plugin: 11452] PLUGIN_HOST(11452): PluginManagerExtImpl/init()
Se esperaba una expresión después de '('.
+ FullyQualifiedErrorId : ExpectedExpression
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): initializing(cortex-debug@0.3.10 with C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
cortex-debug@0.3.10 : El término 'cortex-debug@0.3.10' no se reconoce como nombre de un cmdlet, función, archivo de
script o programa ejecutable. Compruebe si escribió correctamente el nombre o, si incluyó una ruta de acceso,
En línea: 1 Carácter: 67
+ ... : 11452] PLUGIN_HOST(11452): initializing(cortex-debug@0.3.10 with C: ...
+ CategoryInfo : ObjectNotFound: (cortex-debug@0.3.10:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] Debugger contribution has been registered: cortex-debug
inténtelo de nuevo.
+ root INFO [hosted-plugin: 11452] Debugger contribution has been regis ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): initializing(vscode-arduino-tools@0.0.1-beta.1 with C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
vscode-arduino-tools@0.0.1-beta.1 : El término 'vscode-arduino-tools@0.0.1-beta.1' no se reconoce como nombre de un
+ ... N_HOST(11452): initializing(vscode-arduino-tools@0.0.1-beta.1 with C: ...
+ CategoryInfo : ObjectNotFound: (vscode-arduino-tools@0.0.1-beta.1:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): initializing(cpp@1.52.1 with C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
cpp@1.52.1 : El término 'cpp@1.52.1' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
+ ... ed-plugin: 11452] PLUGIN_HOST(11452): initializing(cpp@1.52.1 with C: ...
+ CategoryInfo : ObjectNotFound: (cpp@1.52.1:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): initializing(json@1.46.1 with C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
json@1.46.1 : El término 'json@1.46.1' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
+ ... d-plugin: 11452] PLUGIN_HOST(11452): initializing(json@1.46.1 with C: ...
+ CategoryInfo : ObjectNotFound: (json@1.46.1:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): initializing(json-language-features@1.46.1 with C:\Users\jorov\Desktop\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
json-language-features@1.46.1 : El término 'json-language-features@1.46.1' no se reconoce como nombre de un cmdlet,
+ ... LUGIN_HOST(11452): initializing(json-language-features@1.46.1 with C: ...
+ CategoryInfo : ObjectNotFound: (json-language-features@1.46.1:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [hosted-plugin: 11452] PLUGIN_HOST(11452): PluginManagerExtImpl/loadPlugin(C:\Users\jorov\Desktop\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
En línea: 1 Carácter: 86
+ ... luginManagerExtImpl/loadPlugin(C:\Users\jorov\Desktop\Arduino IDE\res ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][marus25.cortex-debug]: Started plugin.
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][arduino.vscode-arduino-tools]: Started plugin.
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.cpp]: Started plugin.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.cpp]: Started ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json]: Started plugin.
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json]: Starte ...
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7][vscode.json-language-features]: Started plugin.
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root ERROR [hosted-plugin: 11452] ApplicationInsights:CorrelationIdManager [
inténtelo de nuevo.
+ root ERROR [hosted-plugin: 11452] ApplicationInsights:CorrelationIdMa ...
PS C:\Users\jorov\Desktop\Arduino IDE> Error: getaddrinfo ENOTFOUND dc.services.visualstudio.com
Error: : El término 'Error:' no se reconoce como nombre de un cmdlet, función, archivo de script o programa
+ Error: getaddrinfo ENOTFOUND dc.services.visualstudio.com
+ CategoryInfo : ObjectNotFound: (Error::String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
>> errno: 'ENOTFOUND',
>> code: 'ENOTFOUND',
>> syscall: 'getaddrinfo',
>> hostname: 'dc.services.visualstudio.com'
dns.js:60:26 : El término 'dns.js:60:26' no se reconoce como nombre de un cmdlet, función, archivo de script o
programa ejecutable. Compruebe si escribió correctamente el nombre o, si incluyó una ruta de acceso, compruebe que
En línea: 1 Carácter: 55
+ at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
+ CategoryInfo : ObjectNotFound: (dns.js:60:26:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> ]
] : El término ']' no se reconoce como nombre de un cmdlet, función, archivo de script o programa ejecutable.
inténtelo de nuevo.
+ CategoryInfo : ObjectNotFound: (]:String) [], CommandNotFoundException
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Start of 5 plugins took: 9102.1 ms
inténtelo de nuevo.
+ root INFO [c02aa10f-92d5-4e74-b44d-ef22de06ace7] Start of 5 plugins t ...
inténtelo de nuevo.
inténtelo de nuevo.
PS C:\Users\jorov\Desktop\Arduino IDE> root INFO Failed to start language server for arduino:avr:uno
inténtelo de nuevo.
+ root INFO Failed to start language server for arduino:avr:uno
inténtelo de nuevo.
inténtelo de nuevo.
inténtelo de nuevo.
Fixed. It seems a directory concatenation was preventing the IDE from starting correctly.
Under Windows 10 I haven't been capable of making it work. It takes a very, very, very long time to start and then complains and nothing can done. Here are some screen captures:
And, through PowerShell I have these:
PS C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit> & '.\Arduino IDE.exe'
Starting backend process. PID: 2836
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root WARN please install @theia/electron@1.12.0-next.1a1d7afc as a runtime dependency
root INFO Configuration directory URI: 'file:///c%3A/Users/jorov/.theia'
root INFO Theia app listening on http://localhost:59674.
root WARN The local plugin referenced by local-dir:/c%3A/Users/jorov/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/jorov/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\jorov\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.1-beta.1" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Deploying backend plugin "cortex-debug@0.3.10" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\cortex-debug\extension\dist\extension"
root INFO Deploying backend plugin "vscode-arduino-tools@0.0.1-beta.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle"
root INFO Deploying backend plugin "cpp@1.52.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-cpp\extension"
root INFO Deploying backend plugin "json@1.46.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json\extension"
root INFO Deploying backend plugin "json-language-features@1.46.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain"
root INFO Deploy plugins list took: 1316.4 ms
root WARN Backend ConfigServiceImpl.onStart is slow, took: 1590.3 ms
daemon INFO Starting daemon from C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
daemon INFO Using config file: c:\Users\jorov\.arduinoIDE\arduino-cli.yaml
daemon INFO arduino-cli.exe version 0.18.1
daemon INFO Setting up Prometheus metrics on :9090/metrics
daemon INFO Starting daemon on TCP address 127.0.0.1:50051
daemon INFO Daemon is now listening on 127.0.0.1:50051...
daemon INFO Daemon is running.
root INFO Git askpass helper is listening on http://127.0.0.1:59681.
root WARN Frontend CommonFrontendContribution.configure is slow, took: 438.9 ms
root WARN Failed to resolve module: @types/body-parser
root WARN Failed to resolve module: @types/cookie
root WARN Failed to resolve module: @types/express
root WARN Failed to resolve module: @types/fs-extra
root WARN Failed to resolve module: @types/lodash.debounce
root WARN Failed to resolve module: @types/lodash.throttle
root WARN Failed to resolve module: @types/react
root WARN Failed to resolve module: @types/react-dom
root WARN Failed to resolve module: @types/react-virtualized
root WARN Failed to resolve module: @types/route-parser
root WARN Failed to resolve module: @types/safer-buffer
root WARN Failed to resolve module: @types/ws
root WARN Failed to resolve module: @types/yargs
root WARN Failed to resolve module: @theia/monaco
root WARN Failed to resolve module: @theia/editor
root WARN Failed to resolve module: @types/rimraf
root WARN Failed to resolve module: @types/tar-fs
root WARN Failed to resolve module: @types/uuid
root WARN Failed to resolve module: @theia/navigator
root WARN Failed to resolve module: @types/p-queue
root WARN Failed to resolve module: @theia/preferences
root WARN Failed to resolve module: @theia/electron
root WARN Failed to resolve module: @theia/keymaps
root WARN Failed to resolve module: @theia/messages
root WARN Failed to resolve module: @types/diff
root WARN Failed to resolve module: @types/dompurify
root WARN Failed to resolve module: @types/mime
root WARN Failed to resolve module: @types/request
root WARN Failed to resolve module: @types/dateformat
root WARN Failed to resolve module: @types/deepmerge
root WARN Failed to resolve module: @types/glob
root WARN Failed to resolve module: @types/google-protobuf
root WARN Failed to resolve module: @types/js-yaml
root WARN Failed to resolve module: @types/ncp
root WARN Failed to resolve module: @types/ps-tree
root WARN Failed to resolve module: @types/react-select
root WARN Failed to resolve module: @types/react-tabs
root WARN Failed to resolve module: @types/sinon
root WARN Failed to resolve module: @types/temp
root WARN Failed to resolve module: @types/which
root WARN Failed to resolve module: js-yaml
root WARN Failed to resolve module: temp
daemon INFO Checking if CLI is Bundled into the IDE
root WARN Frontend keybindings.onStart is slow, took: 258.6 ms
daemon INFO Checking signature [error: opening signature file: open C:\Users\jorov\AppData\Local\Temp\918371827.sig: El sistema no puede encontrar el archivo especificado., index: C:\Users\jorov\AppData\Local\Temp\918371827, signaturefile: C:\Users\jorov\AppData\Local\Temp\918371827.sig]
at Object.callErrorFromStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
at Object.onReceiveStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:387:49)
at Object.onReceiveStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:299:181)
at C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:145:78
root ERROR Request createNewSketch failed with error: 14 UNAVAILABLE: No connection established
root FATAL Failed to determine the sketch directory: Error: Request createNewSketch failed with message: 14 UNAVAILABLE: No connection established
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 92133.6 ms
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Sync of 5 plugins took: 402.4 ms
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604) starting instance
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][marus25.cortex-debug]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.cpp]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json-language-features]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Load contributions of 5 plugins took: 199.3 ms
root WARN Frontend PluginViewRegistry.onDidInitializeLayout is slow, took: 204.1 ms
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(cortex-debug@0.3.10 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(vscode-arduino-tools@0.0.1-beta.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(cpp@1.52.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(json@1.46.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(json-language-features@1.46.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): PluginManagerExtImpl/loadPlugin(C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][marus25.cortex-debug]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][arduino.vscode-arduino-tools]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.cpp]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json-language-features]: Started plugin.
at Proxy.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/bundle.js:64108:33)
at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3425:65)
at step (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3022:23)
at Object.next (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3003:53)
at file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:2997:71
at push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.__awaiter (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:2993:12)
at ArduinoFrontendContribution.push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.ArduinoFrontendContribution.openSketchFiles (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3417:16)
at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3376:26)
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Start of 5 plugins took: 1904.3 ms
Hope that helps.
Fixed. It seems that a directory concatenation was preventing the IDE from starting correctly.
please what does that mean? how did you solve the problem?
I just deleted the concatenated directories. There were one into another with same name for a very, very long way.
There was a bug in the Arduino IDE that caused it to create these recursive directory structures when you saved a sketch inside a sketch:
