hola que tal amigos tengo problemas al compilar en el programa de arduino !!
me da los siguientes errores :
ProyectoFinal.pde: In function ‘void setup()’:
ProyectoFinal:103: error: a function-definition is not allowed here before ‘{’ token
ProyectoFinal:320: error: expected `}’ at end of input
les agradeceria su ayuda soy nuevo en esto y no se porque me da el error
aqui les dejo el codigo !
les agradecere su ayuda graciaaas!
#if defined(ARDUINO) && ARDUINO >= 100
#include “Arduino.h”
#include “Platform.h”
#include “SoftwareSerial.h”
#ifndef CDC_ENABLED
// Shield Jumper on SW
SoftwareSerial port(12,13);
#else
// Shield Jumper on HW (for Leonardo)
#define port Serial1
#endif
#else // Arduino 0022 - use modified NewSoftSerial
#include “WProgram.h”
#include “NewSoftSerial.h”
NewSoftSerial port(12,13);
#endif
#include “EasyVR.h”
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_ENCENDER = 0,
enum Group1
G1_PORTON = 0,
G1_GARAGE = 1,
G1_SALA = 2,
G1_ESTUDIO = 3,
G1_COMEDOR = 4,
G1_GRADAS = 5,
G1_LAVANDERIA = 6,
G1_BANO = 7,
G1_COCINA = 8,
G1_JARDIN = 9,
G1_DORMITORIO1 = 10,
G1_DORMITORIO2 = 11,
G1_DORMITORIO3 = 12,
G1_BANO1 = 13,
G1_BANO2 = 14,
G1_SALON = 15,
EasyVRBridge bridge;
int8_t group, idx;
#ifndef CDC_ENABLED
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
Serial.println(“Bridge not started!”);
#else
// bridge mode?
if (bridge.check())
port.begin(9600);
bridge.loop(port);
Serial.println(“Bridge connection aborted!”);
#endif
port.begin(9600);
while (!easyvr.detect())
Serial.println(“EasyVR not detected!”);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println(“EasyVR detected!”);
easyvr.setTimeout(5);
easyvr.setLanguage(4);
group = EasyVR::TRIGGER; //<-- start group (customize)
for(int i=2; i<=3; i++){
pinMode(i, OUTPUT);
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; ← jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: “);
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(” = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println(“Timed out, try again…”);
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_ENCENDER:
// write your action code here
group = GROUP_1;
case GROUP_1:
switch (idx)
case G1_PORTON:
if(digitalRead(2) == LOW){
digitalWrite(2, HIGH);
else{
digitalWrite(2, LOW);
group = GROUP_0;
case G1_GARAGE:
if(digitalRead(3) == LOW){
digitalWrite(3, HIGH);
else{
digitalWrite(3, LOW);
group = GROUP_0;
case G1_SALA:
if(digitalRead(4) == LOW){
digitalWrite(4, HIGH);
else{
digitalWrite(4, LOW);
group = GROUP_0;
case G1_ESTUDIO:
if(digitalRead(5) == LOW){
digitalWrite(5, HIGH);
else{
digitalWrite(5, LOW);
group = GROUP_0;
case G1_COMEDOR:
if(digitalRead(6) == LOW){
digitalWrite(6, HIGH);
else{
digitalWrite(6, LOW);
group = GROUP_0;
case G1_GRADAS:
if(digitalRead(7) == LOW){
digitalWrite(7, HIGH);
else{
digitalWrite(7, LOW);
group = GROUP_0;
case G1_LAVANDERIA:
if(digitalRead(smiley-cool == LOW){
digitalWrite(8, HIGH);
else{
digitalWrite(8, LOW);
group = GROUP_0;
case G1_BANO:
if(digitalRead(9) == LOW){
digitalWrite(9, HIGH);
else{
digitalWrite(9, LOW);
group = GROUP_0;
case G1_COCINA:
if(digitalRead(10) == LOW){
digitalWrite(10, HIGH);
else{
digitalWrite(10, LOW);
group = GROUP_0;
case G1_JARDIN:
if(digitalRead(11) == LOW){
digitalWrite(11, HIGH);
else{
digitalWrite(11, LOW);
group = GROUP_0;
case G1_DORMITORIO1:
if(digitalRead(12) == LOW){
digitalWrite(12, HIGH);
else{
digitalWrite(12, LOW);
group = GROUP_0;
case G1_DORMITORIO2:
if(digitalRead(13) == LOW){
digitalWrite(13, HIGH);
else{
digitalWrite(13, LOW);
group = GROUP_0;
case G1_DORMITORIO3:
if(digitalRead(14) == LOW){
digitalWrite(14, HIGH);
else{
digitalWrite(14, LOW);
group = GROUP_0;
case G1_BANO1:
if(digitalRead(15) == LOW){
digitalWrite(15, HIGH);
else{
digitalWrite(15, LOW);
group = GROUP_0;
case G1_BANO2:
if(digitalRead(16) == LOW){
digitalWrite(16, HIGH);
else{
digitalWrite(16, LOW);
group = GROUP_0;
case G1_SALON:
if(digitalRead(17) == LOW){
digitalWrite(17, HIGH);
else{
digitalWrite(17, LOW);
group = GROUP_0;
