Error defining function when splitting up tabs
Hello everyone,
recently I discovered that you can use concatenation with the IDE tabs.
I have a somewhat large code and would like to use this function to create a more elegant and easily accessible code.
Currently my tabs look like this:
Where
c - h : creation of objects and some pin definitions
i : creation of a function
The other tabs are fairly self explanatory.
Now the problem is the following...
First I do #include "CN0391.h" in the a_include_libraries tab.
I then redefine one of the functions in this library in the i_Read_channel tab by deleting it from the .cpp file and defining it there.
Before when I had all of the tabs (except for CN0391.h and CN0391.cpp) combined this worked just fine, but now when they are concatenated I get the following error message:
conflicting declaration of 'int32_t CN0391_read_channel(int)' with 'C' linkage
Here is also an image of the function definition:
Worst case scenario I can just have all my code in one tab, this is not a deal breaker or necessity.
However it would be nice to be able to split the code up in this fashion and also to understand why this error is occurring.
All answers will be appreciated
/ Einar
Note, I get the same problem doing a simplified version of this setup:
Your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem :wink:
I can not quite follow you description but does your function prototype in the .h file match the function in the .cpp file?
Maybe relevant might be the board that you compile for.
Why an image? If we would ask for your complete code, are you going to give us a few hundred screenshots? Why don't you just post it (using code-tags).
Could it be that you are mixing C and C++? Do all of your files have a .cpp (or a .h) suffix?
All of the .ino files are merged together into one. Your one .cpp file stands alone and knows nothing about the rest of your sketch that you don't tell it.
It looks like this function is declared twice. What is in the file "CN0391.h"?
Hi sterretje,
sorry for the wrong categorisation, thanks for moving it!
And I took the image because i thought it was a neat way to include both the tabs, the code, and the error message.
Hi jfjlaros,
The file types are:
.cpp
.h
.ino
That's it.
Hi John,
yes I understand this concept
I have removed the definition of this function in the CN0391.cpp tab.
It is in my tab Read_channel and also in the CN0391.h tab:
int32_t CN0391_read_channel(int ch);
As I mentioned this setup does work when the .ino files are not seperated... :thinking:
/ Einar
See My Post #5 Here for some basic guidelines to breaking a project up into .h / .cpp files.
Where is CN0391.h included? Is it included in your CN0391.cpp? That would be a declaration in addition to the one in your .ino files.
Thanks @gfvalvo!
@johnwasser The CN0391.h is included both in my a_include_libraries tab and also in the CN0391.cpp file.
Please show me the entire a_include_libraries.ino file.
sure:
#include <ModbusRtu.h>
#include <AccelStepper.h>
#include <SPI.h>
#include <PID_v1.h>
#include "CN0391.h"
#include "Communication.h"
#include "Thermocouple.h"
#include "RTD.h"
#include "AD7124.h"
That looks fine. Would you please show me what is in CN0391.h and CN0391.cpp?
sure (but they are quite large):
CN0391.h :
* Copyright 2016(c) Analog Devices, Inc.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
*  - Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
*  - Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in
*    the documentation and/or other materials provided with the
*    distribution.
*  - Neither the name of Analog Devices, Inc. nor the names of its
*    contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
*  - The use of this software may or may not infringe the patent rights
*    of one or more patent holders.  This license does not release you
*    from the requirement that you obtain separate licenses from these
*    patent holders to use this software.
*  - Use of the software either in source or binary form, must be run
*    on or directly connected to an Analog Devices Inc. component.
* THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#ifndef _CN0391_H_
#define _CN0391_H_
#include "AD7124.h"
#include "PROGMEM_readAnything.h"
#ifdef  __cplusplus
extern "C" {
#endif
typedef enum
	CHANNEL_P1 = 0,
	CHANNEL_P2,
	CHANNEL_P3,
	CHANNEL_P4
}channel_t;
typedef enum
  ERR_UNDER_RANGE = 1,
  ERR_OVER_RANGE,
  NO_ERR
}error_code;
float CN0391_data_to_voltage(int32_t data, uint8_t channel);
float CN0391_data_to_resistance(int32_t data);
void CN0391_calc_rtd_temperature(channel_t ch, float *temp);
void CN0391_calc_th_temperature(channel_t ch, float cjTemp, float *buffer);
void CN0391_enable_channel(int channel);
void CN0391_disable_channel(int channel);
void CN0391_enable_current_source(int current_source_channel);
void CN0391_start_single_conversion();
void CN0391_reset();
void CN0391_setup();
void CN0391_init();
void CN0391_calibration(uint8_t channel);
void CN0391_read_reg(void);
void CN0391_set_calibration_mode(uint16_t mode);
void CN0391_set_power_mode(int mode);
void CN0391_set_data(void);
void CN0391_display_data(void);
#define YES    1
#define NO     0
#define R5      1600.0  //ohmi
#define I_EXT   0.75    //mA
#define VREF_EXT    (R5*I_EXT)  //mV
#define VREF_INT     2500.0     //mV
#define _2_23     8388608.0
#define RTD_CHANNEL    0
#define TH_CHANNEL     1
#define GAIN_RTD       1  //GAIN1
#define GAIN_TH        32  //GAIN32
#define POLY_CALC(retVal, inVal, coeff_array) \
    float expVal = 1.0f; \
    const float* coeff = coeff_array; \
    retVal = 0.0f; \
    while(*coeff != 1.0f)\
        retVal += *coeff * expVal; \
        expVal *= inVal; \
        coeff++; \
#define USE_RTD_CALIBRATION  YES  // Set YES to enable calibration on RTD channel, otherwise set to NO
#define USE_TH_CALIBRATION   YES   // Set YES to enable calibration on TC channel, otherwise set to NO
#define DISPLAY_REFRESH     (1000)   //ms
#define TC_OFFSET_VOLTAGE    0.00    // mV compensation for system offset
#ifdef  __cplusplus
#endif // __cplusplus
#endif
CN0391.cpp :
*   @file     CN0391.cpp
*   @brief    Application file for the CN0391 project
*   @author   Analog Devices Inc.
*    distribution.
#include "Arduino.h"
#include "CN0391.h"
#include "RTD.h"
#include "AD7124.h"
#include <stdio.h>
#include <math.h>
int32_t _ADCValue0[4], _ADCValue1[4];
float rRtdValue[4], temp0[4], temp1[4];
float cj_Voltage[4], th_Voltage_read[4], th_Voltage[4];
extern float channelTemp[4];
static const unsigned char thermocouple_type[] = { 'T', 'J', 'K', 'E', 'S', 'R', 'N', 'B' };
uint8_t th_types[4];
error_code errFlag[4] = {NO_ERR, NO_ERR, NO_ERR, NO_ERR};
#define ms_delay (1)
float CN0391_data_to_voltage(int32_t data, uint8_t channel) {
	float voltage;
	if(channel == RTD_CHANNEL){
	      voltage = (VREF_EXT*(data - _2_23))/(_2_23 *GAIN_RTD);
	} else{
	      voltage = (VREF_INT*(data - _2_23))/(_2_23*GAIN_TH);
	return voltage;
   float rRtd;
   rRtd = (R5*(data - _2_23))/(_2_23 *GAIN_RTD);
   return rRtd;
	enum ad7124_registers regNr = static_cast<enum ad7124_registers> (AD7124_Channel_0 + channel); //Select _ADC_Control register
	uint32_t setValue = AD7124_ReadDeviceRegister(regNr);
	setValue |= (uint32_t)AD7124_CH_MAP_REG_CH_ENABLE;  //Enable channel0
	setValue &= 0xFFFF;
	AD7124_WriteDeviceRegister(regNr, setValue);    // Write data to _ADC
	delay(ms_delay);
	setValue &= (~(uint32_t) AD7124_CH_MAP_REG_CH_ENABLE);  //Enable channel0
	setValue &= 0xFFFF;
	delay(ms_delay);
	enum ad7124_registers regNr = AD7124_IOCon1; //Select _ADC_Control register
	setValue &= ~(AD7124_IO_CTRL1_REG_IOUT_CH0(0xF));
	setValue |= AD7124_IO_CTRL1_REG_IOUT_CH0(2*current_source_channel + 1);// set IOUT0 current
	setValue &= 0xFFFFFF;
	delay(ms_delay);
	enum ad7124_registers regNr = AD7124_ADC_Control; //Select _ADC_Control register
	AD7124_WriteDeviceRegister(regNr, 0x0584);    // Write data to _ADC
void CN0391_reset() {
	AD7124_Reset();
	Serial.println(F("Reseted AD7124\n"));
void CN0391_setup() {
	AD7124_Setup();
void CN0391_init() {
	uint32_t setValue;
	int i;
	enum ad7124_registers regNr;
	CN0391_setup();
	delay(ms_delay);
	//Setup 0 -> RTD
	// Set Config_0 0x19
	regNr = AD7124_Config_0;               //Select Config_0 register
	setValue |= AD7124_CFG_REG_BIPOLAR;     //Select bipolar operation
	setValue |= AD7124_CFG_REG_BURNOUT(0);  //Burnout current source off
	setValue |= AD7124_CFG_REG_REF_BUFP;
	setValue |= AD7124_CFG_REG_REF_BUFM;
	setValue |= AD7124_CFG_REG_AIN_BUFP;
	setValue |= AD7124_CFG_REG_AINN_BUFM;
	setValue |= AD7124_CFG_REG_REF_SEL(1); //Select REFIN2(+)/REFIN2(-)
	setValue |= AD7124_CFG_REG_PGA(0);  //GAIN1
	setValue &= 0xFFFF;
   // Set AD7124_Filter_0 0x21
   regNr = AD7124_Filter_0;
   setValue |= AD7124_FILT_REG_FILTER(2);                     // set SINC3
   setValue |= AD7124_FILT_REG_FS(384);                     //FS = 48 => 50 SPS LOW power
   AD7124_WriteDeviceRegister(regNr, setValue);// Write data to _ADC
   for(i = 0; i < 4; i++){
      // Set Channel_0 register 0x09
      regNr = static_cast<enum ad7124_registers>(AD7124_Channel_0 + i);
      setValue &= (~(uint32_t)AD7124_CH_MAP_REG_CH_ENABLE); //Disable channel
      setValue |= AD7124_CH_MAP_REG_SETUP(0);             // Select setup0
      setValue |= AD7124_CH_MAP_REG_AINP(2*i + 1);         // Set AIN1+, AIN3+, AIN5+, AIN7+
      if(i == 3){
            setValue |= AD7124_CH_MAP_REG_AINM(2*i - 1);   //AIN5-
      } else{
            setValue |= AD7124_CH_MAP_REG_AINM(2*i + 3);  //AIN3-, AIN5-, AIN7-
      setValue &= 0xFFFF;
      delay(ms_delay);
   // Set IO_Control_1 0x03
   regNr = AD7124_IOCon1;               //Select IO_Control_1 register
   setValue |= AD7124_IO_CTRL1_REG_IOUT0(5);// set IOUT0 current to 750uA
   //Setup 1 -> Thermocouple
  // Set Config_1
   regNr = AD7124_Config_1;
   setValue |= AD7124_CFG_REG_REF_SEL(2); //internal reference
   setValue |= AD7124_CFG_REG_PGA(5);  //GAIN32
   setValue &= 0xFFFF;
   regNr = AD7124_Filter_1;
      regNr = static_cast<enum ad7124_registers>(AD7124_Channel_4 + i);
      setValue |= AD7124_CH_MAP_REG_SETUP(1);             // Select setup0
      setValue |= AD7124_CH_MAP_REG_AINP(2*i);         // Set AIN0+, AIN2+, AIN4+, AIN6+
      setValue |= AD7124_CH_MAP_REG_AINM(15);         // Set AIN15 as negative
      setValue &= 0xFFFF;
      delay(ms_delay);
	// Set _ADC_Control 0x01
	setValue |= AD7124_ADC_CTRL_REG_DATA_STATUS; // set data status bit in order to check on which channel the conversion is
	setValue |= AD7124_ADC_CTRL_REG_REF_EN;
	setValue |= AD7124_ADC_CTRL_REG_POWER_MODE(0);  //set low power mode
	setValue &= 0xFFFF;
	delay(ms_delay);
   th_types[CHANNEL_P1] = P1_TYPE;
   th_types[CHANNEL_P2] = P2_TYPE;
   th_types[CHANNEL_P3] = P3_TYPE;
   th_types[CHANNEL_P4] = P4_TYPE;
   channel_t i;
  for(i = CHANNEL_P1; i <= CHANNEL_P4; i = static_cast<channel_t>(i+1)){
        CN0391_enable_current_source(i);
        _ADCValue0[i] = CN0391_read_channel(i);
        //Serial.println( _ADCValue0[i]);
        _ADCValue1[i] = CN0391_read_channel((i + 4));
        //Serial.println( _ADCValue1[i]);
        rRtdValue[i] = CN0391_data_to_resistance(_ADCValue0[i]);
        //Serial.println( rRtdValue[i]);
        CN0391_calc_rtd_temperature(i, &temp0[i]);
        CN0391_calc_th_temperature(i, temp0[i], &temp1[i]);
        channelTemp[i] = temp1[i];
   channel_t i;
         Serial.print(F("P")); Serial.print(i+1); Serial.print(F("channel (Type ")); Serial.print(thermocouple_type[th_types[i]]); Serial.println(F(")"));
         Serial.print(F("\t_ADC CJ code = ")); Serial.println((int)_ADCValue0[i]);
         Serial.print(F("\tR_rtd = ")); Serial.print(rRtdValue[i]); Serial.println(F(" ohmi"));
         Serial.print(F("\tcj_Temp = ")); Serial.println(temp0[i]);
         Serial.print(F("\tcj_Voltage = ")); Serial.print(cj_Voltage[i]); Serial.println(F(" mV"));
         Serial.print(F("\t_ADC TC code = ")); Serial.println((int)_ADCValue1[i]);
         Serial.print(F("\tth_Voltage_read = ")); Serial.print(th_Voltage_read[i]); Serial.println(F(" mV"));
         Serial.print(F("\tth_Voltage = ")); Serial.print(th_Voltage[i]); Serial.println(F(" mV"));
         if(errFlag[i] == ERR_UNDER_RANGE){
            Serial.println("");
            Serial.println(F("\tWARNING: Linearized temperature value is not available -> exceeds lower limit!!!"));
            Serial.print(F("\t\t Supported temperature range for thermocouple Type ")); Serial.print(thermocouple_type[th_types[i]]); Serial.print(F(" [")); Serial.print(PROGMEM_getAnything(&thTempRange[th_types[i]][0])); Serial.println(PROGMEM_getAnything(&thTempRange[th_types[i]][1])); Serial.println(F("]."));
            errFlag[i] = NO_ERR;
          } else{
                if(errFlag[i] == ERR_OVER_RANGE){
                  Serial.println("");
                  Serial.println(F("\tWARNING: Linearized temperature value is not available -> exceeds upper limit!!!"));
                  Serial.print(F("\t\t Supported temperature range for thermocouple Type ")); Serial.print(thermocouple_type[th_types[i]]); Serial.print(F("is [")); Serial.print(PROGMEM_getAnything(&thTempRange[th_types[i]][0])); Serial.println(PROGMEM_getAnything(&thTempRange[th_types[i]][1])); Serial.println(F("]."));
                else{
                  Serial.print(F("\tth_temp = ")); Serial.print(temp1[i]); Serial.println(F(" °C"));
   Serial.println("");
   Serial.println("");
     float rRtd;
     rRtd = (R5*(_ADCValue0[ch] - _2_23))/(_2_23 *GAIN_RTD);
      if(rRtd > R0) {
        *temp = (-COEFF_A + sqrt(COEFF_A_A - COEFF_4B_R0*(R0 - rRtd)))/COEFF_2B;
         POLY_CALC(*temp, rRtd/10.0, &cjPolyCoeff[0]);
void CN0391_calc_th_temperature(channel_t ch, float cjTemp, float *_buffer)
    float cjVoltage, thVoltage;
    const temp_range thCoeff = PROGMEM_getAnything(&thPolyCoeff[th_types[ch]]);
    thVoltage = ((VREF_INT*(_ADCValue1[ch] - _2_23))/(_2_23*GAIN_TH)) + TC_OFFSET_VOLTAGE;
    th_Voltage_read[ch]= thVoltage;
      if(cjTemp <  PROGMEM_getAnything(&cjTempRange[th_types[ch]][1])) {
         POLY_CALC(cjVoltage, cjTemp, thCoeff.neg_temp);
        if(cjTemp <=  PROGMEM_getAnything(&cjTempRange[th_types[ch]][2])){
          POLY_CALC(cjVoltage, cjTemp, thCoeff.pos_temp1);
          if(th_types[ch] == TYPE_K){
             cjVoltage += COEFF_K_A0*exp(COEFF_K_A1*(cjTemp - COEFF_K_A2)*(cjTemp - COEFF_K_A2));
        } else{
          POLY_CALC(cjVoltage, cjTemp, thCoeff.pos_temp2);
      cj_Voltage[ch] = cjVoltage;
      thVoltage += cjVoltage;
      th_Voltage[ch] = thVoltage;
      if(thVoltage < PROGMEM_getAnything(&thVoltageRange[th_types[ch]][0])) {
            errFlag[ch] = ERR_UNDER_RANGE;
      } else{
            if(thVoltage < PROGMEM_getAnything(&thVoltageRange[th_types[ch]][1])) {
              POLY_CALC(*_buffer, thVoltage, thCoeff.neg_voltage);
                if(thVoltage <= PROGMEM_getAnything(&thVoltageRange[th_types[ch]][2])) {
                  POLY_CALC(*_buffer, thVoltage, thCoeff.pos_voltage1);
                }else{
                   if((thVoltage <= PROGMEM_getAnything(&thVoltageRange[th_types[ch]][3])) && (thCoeff.pos_voltage2[0] != 1.0f)) {
                    POLY_CALC(*_buffer, thVoltage, thCoeff.pos_voltage2);
                  }else{
                        if(thCoeff.pos_voltage3[0] != 1.0f){
                           if(thVoltage <= PROGMEM_getAnything(&thVoltageRange[th_types[ch]][4])){
                                 POLY_CALC(*_buffer, thVoltage, thCoeff.pos_voltage3);
                           else{
                                 errFlag[ch] = ERR_OVER_RANGE;
                        else{
                 CN0391_enable_current_source(1);
                 CN0391_enable_channel(0);
                 CN0391_set_calibration_mode(0x514);
                 while(AD7124_ReadDeviceRegister(AD7124_ADC_Control) != 0x0510);  //wait for idle mode
                 CN0391_disable_channel(0);
      } else{
                  CN0391_enable_channel(4);
                  AD7124_WriteDeviceRegister(AD7124_Offset_1, 0x800000);
                  CN0391_set_calibration_mode(0x518);
                  CN0391_disable_channel(4);
      AD7124_WriteDeviceRegister(AD7124_ADC_Control, 0x588);
   for(regNr = AD7124_Status; regNr < AD7124_REG_NO;regNr = static_cast<enum ad7124_registers>(regNr + 1)) {
   convFlag = 1;
   digitalWrite(CS_PIN, LOW);
   AD7124_WriteDeviceRegister(AD7124_ADC_Control, mode);
   if (AD7124_WaitForConvReady(100000) == -3) {
        Serial.println("TIMEOUT");
   convFlag = 0;
   digitalWrite(CS_PIN, HIGH);
   enum ad7124_registers regNr = AD7124_ADC_Control;            //Select ADC_Control register
   setValue |= AD7124_ADC_CTRL_REG_POWER_MODE(mode);  //set low power mode
   setValue &= 0xFFFF;
   AD7124_WriteDeviceRegister(regNr, setValue);    // Write data to ADC
   delay(ms_delay);
Hope that helps!
Note:
Is a line I've added to CN0391.cpp and included later down in the CN0391_set_data( ) function.
There's your problem. The CN0391.h file is telling everyone that the function CN0391_read_channel() is in a .c file. You renamed CN0391.c to CN0391.cpp so now you have the same function using two different naming conventions.
With CN0391.c changed to CN0391.cpp you should remove the extern "C" { from the .h file.
Remove these parts from CN0391.h:
#ifdef  __cplusplus
extern "C" {
#endif
and
#ifdef  __cplusplus
Hello John,
thanks for your reply/explanation.
However I am certain I have not renamed CN0391.c to .cpp.
Here is the original code:
But this does indeed get rid of the error message!
How come this was not a problem when all the .ino files were merged? :thinking:
/Einar
I don't know. The example SHOULD have had the same error.
Huh, very strange :thinking:
Another mystery of the CN0391 temp shield I guess :laughing:
Anyhow, thanks again for the help!
/ Einar
