Error Device code: 0x44
Egal ob ich ein selber geschriebenes Projekt auf meinen Arduino Leonardo hochladen will oder eins der Beispiele es kommt immer dieser Error:
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
und hier noch immer der ganze Log von der Geschichte:
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian "C:\Users\aaron\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\aaron\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega32u4 -cavr109 "-PCOM9" -b57600 -D "-Uflash:w:C:\Users\aaron\AppData\Local\Temp\arduino-sketch-2AAB337D5DDC3F64C6FA30C557D32164/KeyboardMessage.ino.hex:i"
Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\aaron\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM9
     Using Programmer              : avr109
     Overriding Baud Rate          : 57600
     AVR Part                      : ATmega32U4
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PA0
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : butterfly
     Description     : Atmel AppNote AVR109 Boot Loader
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\aaron\AppData\Local\Temp\arduino-sketch-2AAB337D5DDC3F64C6FA30C557D32164/KeyboardMessage.ino.hex"
avrdude: writing flash (5994 bytes):
Writing | ################################################## | 100% 0.47s
avrdude: 5994 bytes of flash written
avrdude: verifying flash memory against C:\Users\aaron\AppData\Local\Temp\arduino-sketch-2AAB337D5DDC3F64C6FA30C557D32164/KeyboardMessage.ino.hex:
avrdude: load data flash data from input file C:\Users\aaron\AppData\Local\Temp\arduino-sketch-2AAB337D5DDC3F64C6FA30C557D32164/KeyboardMessage.ino.hex:
avrdude: input file C:\Users\aaron\AppData\Local\Temp\arduino-sketch-2AAB337D5DDC3F64C6FA30C557D32164/KeyboardMessage.ino.hex contains 5994 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.05s
avrdude: verifying ...
avrdude: 5994 bytes of flash verified
avrdude done. Thank you.
und hat das Hochladen funktioniert ?
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden. Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
Ah tut mir Leid danke
Nein
Versuchst Du da einen Leonardo, einen Micro oder den USB-Controller von einem UNO zu flashen?
Und vor allem was ist da in Verwendung? Ist das ne IDE 2.0.x?
Ich versuche einen Standart Tastatureingabe code auf den Arduino zu laden.
Ja IDE 2.0.2.
Verwende eine Arduino Leonardo.
Dan versuch doch mit der 1.8.19 IDE, ist ein wenig unten, sehr viele finden die 2,xx noch nicht ausgereift
Ja, das habe ich rausgelesen.
Aber das beantwortet meine Frage nicht.
Ansonsten kann ich nix finden, was ungewöhnlich ist.
Laut dem log sollte das eigentlich sauber durchgelaufen sein.
Ggfls. vielleicht hier noch einmal gegenlesen: Cannot upload anything to Arduino Leonardo - #10 by ptillisch
Zeig mal dein Sketch nicht das du must SerialMonitor einschalten
ICh werde es versuchen
Also nein ich versuche nichts zu flashen aber das problem liegt dabei das der code wegen dem fheler nicht hochgeladen wird bzw auch nicht funktioniert...
Du bist verwirrt!
Natürlich musst du flashen!
Oben drauf:
Sogar das verify ist erfolgreich.
Ja aber ich meine nicht von einem anderen
Wenn ja alles erfolgreich ist warum funktioniert der Test code von Arduino selber nicht?
KA!
Der ist ja geheim...
Spiel mal den ordinären Blink-Sketch aus den Beispielen auf.
Der sollte eigentlich problemlos die LED zum blinken bringen.
Wie soll da jemand etwas dazu sagen, wenn Du den Code geheim hälst?
Sezue ihn in Codetags hier rein. Wie das geht, steht hier.
Gruß Tommy
  Keyboard Message test
  For the Arduino Leonardo and Micro.
  Sends a text string when a button is pressed.
  The circuit:
  - pushbutton attached from pin 4 to +5V
  - 10 kilohm resistor attached from pin 4 to ground
  created 24 Oct 2011
  modified 27 Mar 2012
  by Tom Igoe
  modified 11 Nov 2013
  by Scott Fitzgerald
  This example code is in the public domain.
  https://www.arduino.cc/en/Tutorial/BuiltInExamples/KeyboardMessage
#include "Keyboard.h"
const int buttonPin = 4;         // input pin for pushbutton
int previousButtonState = HIGH;  // for checking the state of a pushButton
int counter = 0;                 // button push counter
  // make the pushButton pin an input:
  pinMode(buttonPin, INPUT);
  // initialize control over the keyboard:
  Keyboard.begin();
  // read the pushbutton:
  int buttonState = digitalRead(buttonPin);
  // if the button state has changed,
  if ((buttonState != previousButtonState)
      // and it's currently pressed:
      && (buttonState == HIGH)) {
    // increment the button counter
    counter++;
    // type out a message
    Keyboard.print("You pressed the button ");
    Keyboard.print(counter);
    Keyboard.println(" times.");
  // save the current button state for comparison next time:
  previousButtonState = buttonState;
Kurze Frage: Wie angeschlossen?
