Heine
November 13, 2019, 4:26pm
1
It's simple, I have an integer with a variableName R1M, and a value of 10.
In the function I have to read R1P, and therefore have to convert the variableName to a string, and change the last letter.
So I have a String, containing "R1P", and i need to digitalRead(myString), which will not work.
How do i convert myString containing "R1P" to a variableName?
(Yes, I have been googling like crazy :o )
TL;DR:
digitalRead(myString) will not work. How do I convert a String to variableName?
Why use variables with different names ?
If they must be different then set R1P equal to R1M
If you need more help then please post a full example of what your code is doing
Heine
November 13, 2019, 4:40pm
3
Thanks for your reply.
I am doing a function to test a set of motors with corresponding sensors.
Motor R1M -> Sensor R1P
Motor R2M -> Sensor R2P
Motor R3M -> Sensor R3P
I need to call the function by the motor name, and then it needs to check the corresponding sensor.
void testMotor(String motor) {
int startMillis;
int currentMillis;
String pos = motor;
pos.replace("P", "S");
int sensPos = digitalRead(pos);
if (sensPos == LOW) {
Serial.println("Roller in position, rotating to next position...");
delay(4000);
digitalWrite(motor, LOW);
startMillis = millis();
while (sensPos == LOW && currentMillis <= startMillis + 4000) {
currentMillis = millis();
if (sensPos == HIGH) {
Serial.println("Motor and sensor OK")
Serial.println("ERROR! Motor timed out!")
Serial.println("Roller NOT in position, positioning rotor...");
delay(4000);
Serial.println("Rotor in position, rotating to next position...")
Serial.println("ERROR! Motor timed out, could not sense position!")
delay(4000);
digitalRead takes an integer value as an argument, NOT a String. At runtime, variable names no longer exist, so passing a variable name as a function argument CANNOT ever work.
Regards,
Ray L.
If that is what you really want to do then pass the motor name as a String and test it in the function to determine which sensor to test
if (motor == "this")
sensor = X;
if (motor == "that")
sensor = Y;
//code to read sensor etc
However, given more details I suspect that we will be able to provide a more elegant solution
